Abdul Thomas Jnr avatar
Can anyone help me with these banding across my light subs? Will like to know what's causing it (maybe rise in temperature) as it's coming to Summer months now and also how I can get rid during processing? This is the second time it has happened now and the last time I had to throw away over 3 hours of imaging time though last night the banding wasn't as bad. Thanks in advance
Rasa 8 and Zwo 183mc pro camera
Brian Diaz avatar
hi
double check your flats  and flat light panel
CS, Brian
Jon Rista avatar
Are these calibrated or uncalibrated frames? They look uncalibrated to me. This is the key reason WHY we calibrate our frames. In this case, I think its dark signal and DFPN (i.e. the pink bubble at the bottom looks like amp glow to me.) I would craft a quality master dark (say 16 or 25 dark frames), subtract that from each light, and see if things improve. I would use a good quality image calibration process, such as PixInsights, which allows you to add a pedestal, which is likely going to be necessary to avoid clipping signal to black with dark calibration…otherwise you'll really just be trading one problem for another.
Anyway, looks like some fairly rogue dark signal/DFPN issues to me, that should mostly be corrected with dark calibration.
Jon Rista:
Are these calibrated or uncalibrated frames? They look uncalibrated to me. This is the key reason WHY we calibrate our frames. In this case, I think its dark signal and DFPN (i.e. the pink bubble at the bottom looks like amp glow to me.) I would craft a quality master dark (say 16 or 25 dark frames), subtract that from each light, and see if things improve. I would use a good quality image calibration process, such as PixInsights, which allows you to add a pedestal, which is likely going to be necessary to avoid clipping signal to black with dark calibration...otherwise you'll really just be trading one problem for another.
*** These are uncalibrated subs but I have stacked the files with darks and applied both dbe and gradient correction and still the banding is there. I need to take new sets of flats tonight and see if that solves the problem***
Jon Rista avatar
Abdul Thomas Jnr:
Jon Rista:
Could you share an example with proper dark calibration? While some of the signal in the field does appear to be something that flats would correct, I don't believe the banding would be. Dark calibration should have corrected a LOT of the junk in the field here. It would be useful to see how dark calibration affects the results.
Jon Rista avatar
Also curious, what is your cooling setpoint? The 183MC Pro is cooled, right?
Jon Rista:
*** Yes, cooling is on - 10 degrees ***
Jon Rista:
Abdul Thomas Jnr:
Jon Rista:
*** I'm going to stack up again with new flats and dark flats and see if that solves it***
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Nov 8, 2025
Both posts discuss technical imaging problems encountered during astrophotography sessions.
