Reccomend me a Refractor
20 replies665 views
Alien_Enthusiast avatar
Can someone recommend me a 400mm refractor that would be good for deep sky and sharp on the moon when used with a Barlow?
Samuel Fyfe avatar
I can only speak for my experience, but I have an Astro Tech AT72EDII --> https://www.astronomics.com/astro-tech-at72edii-refractor-ota-fpl-53-f-6.html
I absolutely love it, and even with some minor water damage in shipping (UPS's fault, not the seller on CN), it still gives great images. I use a 0.85x reducer/flattener, so I'm shooting at 344mm in my images, but stock, it's at 430mm. a 1x field field flattener should be perfect. It's got superior glass to most scopes in it's price range, shockingly low chromatic aberration for being a doublet (I don't correct for it in my images, and I think it speaks for itself), and the focuser is really smooth and easy to use.
Claudio Tenreiro avatar
Hi, I believe you have to narrow down a bit your question because by Barlow you have a full range between 1.5x to 5x, or even more, also you have the factor of the seeing. A decent f/7 ish refractor can do what you are asking but, the final result will depends if you match your pixel size of the camera will all the other parameters, so to achieve the sharp image at the resolution you want to.
A number of ED refractors can do the job, all the way from 80mm to 110mm or 120mm of objective diameter, but the f number is relevant too. In some "recipes" it is suggested that the final combination should be around f/20 or f/21, so the f/7.5 with a 3x barlow is fine (for sun/moon/planetary).
But in my modest experience, the atmosphere stability is the more critical part when sharpness and resolution is what you want to achieve.
I apologize if I misunderstood your question, but this is what I can contrbute. I use an ED 80mm f/7.5 like the Vixen ED80Sf, a quite cheap and decent refractor, in my opinion.
Now if you want to keep the 400 mm of focal length, which I believe normally thay are around f/5, it could be possible with a 4x barlow, and many options are available. In this case, I believe that it will depend on what else you wish to do with that scope.
Cheers and CS
Quinn Groessl avatar
A few reasonably priced options would be ZWO FF65 Apo, WO GT81 w/ 0.8 reducer, Askar 65PHQ, Askar FRA400.
I plan to use it with 3x TeleVue barlow for lunar
and no barlow for DSO
Also, it would be very helpful if I didn't have to use a flattener
Are there any scopes that are already corrected to have flat FOV?
Alien_Enthusiast:
The ZWO and both the Askar ones that I mentioned are petzval designs.
In this case I suscribe the FRA400
Leonardo Landi avatar
I'm moving my first steps with the Askar FRA 400 and I definitely love it. I used it few times at full fl and now I installed the f3.9 reducer. With the latter you have to deal with backfocus, but if you use it at 400mm the petzval design really helps. Also the mechanics is really good, the focuser is rock solid. With the GM1000 I measured a RMS between 4 and 5.6 so no major flexure detected.
Oscar H. avatar
FRA400 or 65PHQ
FRA400 is faster, but IMO gives slightly softer images than the next option
65PHQ is slower, but makes up for the slowness in sharpness; the stars taken with it are beautifully sharp and pinpoint.
pick your poison smile
In your situation, I would choose the 65PHQ.
But that's just me; I like to choose maximum sharpness for my budget, over speed.
Upd:
I got a pretty big camera that weights over half a kilogram
and the Star Adventurer Im using has a 2.5kg limit
So I need a telescope to be at least 2kg and better if its around 1.5kg
FRA weight almost 3kg
65PHQ weights 2.8kg
Does anyone know a scope within such limits?
WO Zenithstar 61 is around 1,45kg - but its only a doublet
Askar 135FMA looks nice, a tiny triplet.
Any other options?
Gilmour Dickson avatar
FRA400 or 65PHQ
pick your poison
I have been very happy with my 65phq (in my case the ZWO painted one!).  I too wanted sharpness over speed.  No complaints.  Even reduced with a full frame sensor the corner stars are not too bad.
SharpStar 50EDPH ED
Takahashi FS-60CB
Vixen FL55SS
Coolhandjo avatar
Askar V all the way for me. Never turning back
Coolhandjo avatar
Tim Ray avatar
I have a WO GT81 with the reducer I plate-solve at 384mm. Solid RP focuser, manual rotator is solid. Takes a ZWO EAF. Heavy, as most triplets are… does a solid job on the ASI2600's/571.
CS Tim
Ferenc Szabo avatar
Samuel Fyfe:
Maybe I had a horrible luck or there was a bad batch present like a year ago, but I sent 2 of these back within just a few months.   The stars were bloating in one and unable to fix, while the other had pinched optics (stars looked like clover).  After that I gave up with buying Astrotech scopes.
Samuel Fyfe avatar
Ferenc Szabo:
Samuel Fyfe:
@Ferenc Szabo
Star bloat is definitely an issue with mine! No pinched optics though, which is good haha. Thankfully I’m mostly shooting narrowband so it keeps the stars a lot more in check, as well as BXT which gets me the rest of the way. It’s definitely in the budget category of scopes in this discussion, but it’s been a great introduction for me cutting my teeth in the hobby!
Shawn avatar
Alien_Enthusiast:
 The Askar 71f Flat Field refractor has been great to me so far its new and around 600$ and already has like the name as a flat field and comes with  M64-M54, M54-M54, and M54-M48 adapters have a screw in for a 2inc filter aswell which is very nice ive been very happy so far with the scope it is 490mm focal if you don't mind that
Alien_Enthusiast:
Upd:
65PHQ weights 2.8kg
Any other options?
Great suggestions, but most of them are over 2,5kg
Takahashi FS-60CB seems to be the perfect match, but finding it on aftermarket can be easier said than done
Oscar H. avatar
Askar 71F is supposedly a no-backfocus-fuss quad astrograph and  it's relatively cheap when bought new
This is directly from the Agena website:
"By using a four-element self-flattening design, the 71F allows users to avoid calculating the back focus and buying an additional flattener or spacer. After attaching a camera and focusing, the user can immediately start imaging. This further reduces the cost and improves the overall user experience."
But the Tak is better, even though I think it's a doublet, it uses Flourite (not Fluoride, like in the toothpaste )
Fluorite IMO is the king of lens materials; it should eliminate all CA and keep everything sharp even though the whole thing is only a doublet.
Just don't forget the flattener
Based on prices too, I would guess the Askar has a lower Strehl ratio too.
Shawn avatar
ive been happy with my askar 71f so far tbh imma put a link of ngc 6888 ( Crescent nebula)  in here if you wanna take a look at what I got so far with this scope im kinda  impressed with the price point and optics so far https://www.astrobin.com/wx13w3/
My test report of the Canon EF 300mm f/4 L IS USM for astrophotography
I am by far not an expert, but, hoping to do something nice for the community, I am submitting a report that would have helped me tremendously when choosing a lens for deep-sky astrophotography. I still think even a good doublet refractor is the way ...
Tests 300mm refractor performance for astrophotography including lunar imaging.
Dec 16, 2025
Looking for a suitable telescope for a mobile setup
Hi! So, I have a spare EQ-5 pro mount, which I used the past year in my backyard observatory, however, I got an upgrade and I thought I should make a mobile, smaller setup around the mount. I have everything, except a telescope. I have a newton in th...
Discusses telescope selection for specific observing requirements and setups.
Jan 20, 2026
