Ultra-wide-field mosaics: what am I doing wrong?
5 replies325 views
Brian Boyle avatar
As part of the Astrobin Community Survey in progress, I am attempting to put together a mosaic of the entire Southern Sky using a Sigma Art 40mm + ZWO 2400MC rig.  Elsewhere on this forum my AB friends (in particular @Jakub Korbel @GalacticRAVE ) have been really helpful on issues regarding lens/camera backfoucus issues, but I am also experiencing issues with the mosaicing. I wonder if anyone has had simpler experiences - and may have suggestions for what I am doing wrong.
Currently I have between 1.5hours and 3hours of 120-sec sub-exposures on each of 21 fields with fields centers at declination 0 or further south.  Fields with centers 7<RA<0 , dec>-75 are also missing, since I only bean this wide-field survey this past lunation.
All fields are processing using WBPP and then GraXpert and BXT applied before passing to MosaicByCoordinates and then GradientMergeMosaic [shrink radius 5 merge radius 50].  On my trust old iMac 2017 this takes a less time, but eventually I get the following lightly stretched result [binned up 4 x 4 from the original]
This is not bad for a dramatic "public" image, but seams between the fields are beginning to become visible .  If I want to go any deeper using an arcsinh/GHS stretch this is what I get
All the faint stuff is there, but so is the pattern left by the individual fields in the mosaic.
So the question is simply  What am I doing wrong?
Limited by the speed of my 4-core processor, albeit (with 48GB ram) I have tried using different post-WBPP routines including including/excluding] ABE, SPCC and and BXT (full or correct only).  I have also tried APP [failed with cryptic errors with more than 4 fields] and PTGui.  PTGui is brilliant stacking software but needs stretched images and using the STF-like PixelMath algorithm] unfortunately stretches the non-Milky Way fields disproportionately to the Milky Way fields.
Although it fails on fields that not distributed in a near-rectangular fashion, PhotometricMergeMosaic used to work quite well removing edges.  However, it appears to have disappeared on the latest release of PI.  This may have something to do with the upcoming MARRS project.  But since the PleiadesAstro team have already asked me for some of the ABC survey data to support the MARRS project in the south, it would look like a bit of a chicken and egg problem if I need to wait for the MARRS project, in order correct data needed for it. [It may be that the MARRS project have found another solution, in which case this data is not so important]
As you can see I have pretty much run out of ideas.  Perhaps I am not doing the correct order of post-WBPP processing for input to the mosaicing routines.  Or not doing the right post-WBPP processing at all.  Perhaps there are other mosaicing packages out there.   [Tried Photoshop - but it was the worst of the lot].  APP used to be my goto package, but it now fails - and I understand that there are some communication challenges with APP at the moment.
Any advice/experience gratefully received.
With many thanks in advance
Wei-Hao Wang avatar
Hi Brian,
Nice project.
I am never a fan of GradientMergeMosaic.  It never works well enough for me.  The PhotometricMosaic script is still provided by John Murphy, just not as part of the PI distribution because of competition with the PI team on similar functions.  It works very well for me if I use a very wide-field single image as a reference for the mosaic panels.
I think you correctly point out the chicken-and-egg issues.  Both the MARS project and your ABC survey can potentially provide background references for mosaics.  But who can provides a background reference for MARS or ABC?  When it comes to such extremely wide field, essentially from horizon to horizon, can a good background reference even exist?  I don't have a good answer.  Even if all the amateur astrophotographers collectively fund and launch a small camera to the orbit to avoid any atmospheric effects, it can still suffer from zodiacal light, which is seasonal.
If you ask me, I would say APP's approach to remove gradient and match the mosaic panels should still be the most promising one to come up with a quick  solution.  It should be able to produce a seamless mosaic, but the background structure is almost certainly to be wrong or inaccurate at least.
Brian Boyle avatar
Wei-Hao Wang:
Hi Brian,
Nice project.
Thanks Wei-Hao.  I think you put your finger on the issue i.e. that this is an issue which is within the community's grasp to solve [if a solution doesn't already exist'. @James Tickner who is doing the field matching for the ABC survey, is coming up against similar issues.
I just wish I could get APP to work with more than 4 images.
I note that GMM appears to overestimate background for fields with the greatest stellar density.  This suggests to me that the use of even a robust median estimator, still gives a biased (high) estimate of the background in areas with the Milky Way.  It is almost as if you need to make multiple medians across the frames and sigma clip that stack.
My last experience at writing code to reduce astronomical images was back in 1990, so I am a little out of date.
Chris Beere avatar
Hi Brian,
You absolutely want to be using PT Gui for this job. I have done all my panos with it - you can see them on my Astrobin page.
I have tried Photoshop, APP, PixInsight, Autopano Giga, ICE over the years and none of them comes close to PT Gui.
I debayer my camera raws in either RawTherapee or Photoshop and save them as Tiffs. This data is then used to setup the PT Gui project.
In your case you can debayer your 2400MC Fits files in PixInsight and then batch convert them to Tiffs.
Do not do ANY stretching or calibration/correction after you have stacked the data. Simply debayer the stacks.
I have created an example for you.
This is a 40 panel pano assembled in PT Gui. It was shot with a Canon 6D MKII.
To make the example analagous to your process I debayered the CR2 files in PixInsight and batch converted them to 16 bit Tiffs.
Here is a single iteration ArcSinH stretch in PixInsight. You can see that PT Gui has performed exceptionally well and this was on the 1/8 precision !!
I use Zero Overlap with Exposure Compensation and Find Optimum Seams at 1/1 Precision for my panos.
If there are gradients in the final result you will need to handle them manually in Photoshop.
No amount of DBE/ABE/GraXpert will help you on these big mosaics - they just dont work at all well.
I always use StarXterminator to pull the stars and then work on the starless layer in isolation. I use a lot of spot healing in Photoshop to repair any residual seam artifacts. To correct gradients and colour blotchiness i use tons of feathered curve adjustments.
I push the data extremely hard so i have to be very thorough.
Example of finished product :
Cheers
Chris
Brian Boyle avatar
Many thanks Chris.  That is very useful.  I followed your prescription with PTGui [both without and with GraXpert] and still got quite significant variations.  It may be that the data is simply not up to the task [your images are wonderful] but I will explore for a few more days.
Thank you again.
Respectful Supportive
Bray Falls avatar
The Mellinger sky survey uses data from the pioneer spacecraft for MGR. The resolution is quite small for this data set but it could work as a good background reference.
https://www.milkywaysky.com/
Mosaic creation - any good tools?
I have been trying to create wide-field (100 sq square degree+) mosaics for some time now. Although I have had some success, I am a little surprised by the lack of any good, easy tools in the various software suites. Particularly when compared to sof...
Directly addresses mosaic creation tools and wide-field mosaicing challenges.
Feb 1, 2026
Collaboration wanted to image the entire Milky Way plane
Would anyone be interested in a collaboration to image the entire plane of the Milky Way? I have already completed the Southern Milky Way plane using a Sigma Art 40mm and ASI2400MC full frame sensor. By orienting each field so the plane was parallel ...
Relevant collaboration for imaging entire Southern Sky mosaic project.
Sep 8, 2025
Takahashi FSQ106 CAA
Hi Everybody, Wondered if anyone dealt with this issue before. I am configuring my FSQ106 with an full-frame camera (QHY600). I see some flex or ‘sag’ in the system, which obviously creates some tilting issues, especially across the now bigger full-f...
Discusses optical system issues; may address field-of-view problems related to equipment setup.
Dec 9, 2022
