GSO 10" RC baffling and flats
21 replies952 views
Götz Golla avatar
I just started to take flats and calibrate the images of my new GSO 10" RC. It turns out that even when I do the flats just before or after the observation with exactly the same optical configuration and focus, one corner of the image remains significantly darker. So the flat field correction does not work.
I have read about the incorrect baffling of the GSO RCs and that this makes flat fielding impossible without an additional baffle. But I also read that the newer GSO RCs (from ~2022) dont have the problem anymore (not sure if its true). So I am a bit unsure if my problem comes from incorrect baffling or has some other reason.
What are experiences of other GSO RC users with flat fielding ? Is it mandatory to have an additional baffle (I order one already with TS) ?
Goetz
Stefano Pesci avatar
I had the same issues with my GSO 10” RC v3.
The first issue was the MoonLite focuser drawing tube which was not anodized and reflected light into the GSO optical path, bouncing to the secondary and back in the focal plane edges. The ASI2600 picked the reflection (an asymmetric ring) on long exposures. Check your focuser to see for any non black reflecting surfaces or stray light.
Second set of issues was with the OTA (truss). You need: a) close the tube with black cloth (available commercially), B) get TS baffle ring to screw in the primary baffle tube, C) get like an anti-dew extension tube or make one with thick black carton paper.
seems to work…
btw, with cmos reflections are much more evident vs old ccds ​​​​​.
stefano
Brian Boyle avatar
Same problem here with my 2024-bought RC12.  The 1ary mirror baffle is simply not long enough to prevent light from outside the field getting into the beam.  There is a great YouTube video somewhere (I can't remember the link) explaining this in detail.
I have been the otherwise happy owner of a GSO RC8 and now RC12 since 2020.  My RC8 suffered from the same problem, and so when I purchased my RC12, I asked the shop I bought it from whether this problem had been fixed.  I was assured by the shop that it had been [advice directly from GSO].
This turned out to be incorrect, and I had to purchase an extension to the baffle sold by TelescopeExpress.   It worked and it is simple to install.  It doesn't affect the collimation, and so I take it in and out each night. [Otherwise the 1ary mirror cover wouldn't go back on.  GSO sent me a replacement machined baffle [funny how they had one ready to go…] but I don't use it as the 1ary mirror cover wouldn't fit.
CS Brian
Götz Golla avatar
It sounds so unlikely that GSO says it is fixed (or some reseller said GSO has said...), but it isnt.  After all its not a difficult question, and it is likely that they have some knowledge about optics ;-)
I am therefore wondering if the baffle problem is just the result of a two big mirror spacing and therefore the telescope not reaching its design focal length of 2000mm but a much smaller value (it was 1947mm for me). In other words: if the focal point is too far in and it moves out by a 2-3 inches the problem with baffle length might go away. This is just a theory, which still would need to be verified of falsified.
@Brian Boyle : in your experience is it sufficient to use the baffle to create usable flats, or do you also use some cloth to prevent stray light to come in from the side ?
Brian Boyle avatar
Unlikely or not, it is certainly my experience.
Before the baffle, I was getting terrible scattered light into the frame.  It showed up as broad arcs of light - like a sector of a very large out-of-focus doughnut across the sensor.  After the baffle - nothing.  I bought but didn't use the tube sock.
The frames are now flatfield-able.  I use flats from the sky.  I never use anything else - otherwise you are asking for trouble.
You can check out my AB page to see the final results with this set-up.  I am really pleased with images from this set-up, indeed 90% of my images have been lucky enough to be nominated for - or received - Top Pick status.
Götz Golla avatar
i bought the buffle by TS as well, will arrive tomorrow
Freddy Meiresonne avatar
I thought this issue was solved quite some time ago. But apparently it still shows up. A polish user did not have the top baffle either on her 6' GSO RC she recently obtained. Stray light comes in and spoils the images , and cannot be corrected with flats.
Fortunately mine recently obtained 8" RC from TS, has a top baffle and does not show any issues (at least not sofar)
And even the length of those top baffles seems to be different. I can't pass mine through the spider. But an US user can with his RC 8". Bit weird all this….
Götz Golla avatar
I recently asked GSO about the need for a baffle extension and also the right focal length of the GSO RC10.
They say that the right focal length is 2000mm, and the right BWD is 239.8mm. I include the 2D layout of the RC10A GSO sent to me.
RC10A-2DL_Model.pdf
They also say that if you have the right values, there is no need for a baffle extension for newer RCs build from three years ago.
However, if the mirror distance is too large, the focal length might be much shorter (it was 1947mm in my case) which means that you need to remove the extension threads to get into focus, which in turn means that the build-in baffle seems to be not long enough to keep stray light away and you apparently need a baffle extension.
The solution in that case is not to do all that, but rather to correct the mirror spacing to get the right effective focal length of 2000mm and BWD of 239.8mm.
Since by doing this you loose the collimation, this process requires some experience in collimating RCs. The final collimation should be done on stars to reach best results, unless you are equiped to do interferometer tests.
Helpful Insightful
Brian Boyle avatar
Yes my RC8 (purchased 2020) did not show this problem, but my RC12 (purchased 2024) did.
I find it very telling that GSO sent me a longer, machined 1ary baffle within a day of my vendor raising it has an issue.  If GSO maintain this is a mirror separation problem: 1) how come they had a manufactured longer baffle "ready to go" and  2) how did they know how long it needed to be?
I would just use the baffle to see if it works, before trying to change mirror distance….
CS Brian
Helpful Insightful Concise
And about mirror spacing, it is never spot on, according to specs. Allthough a deviation from 1 or 2 percent seems not to matter much, so i read.
I would not change the mirror spacing either. Set wrong and SA may set in.
CS Freddy
Götz Golla avatar
GSO was so nice to send me the 2D design of the RC10. See the PFL above in this thread. There it can be seen that the BWD needs to be 239.8mm.
It should be easy to understand that when the BWD is much lower, there will be stray light problems. If the BWD is too large, there will excessive vignetting.
The BWD is changed by adjusting the mirror distance. According to GSO when the BWD is not 239.8mm, this is wrong and the mirror distance needs to be adjusted. This is a very clear statement I have received by them.
On the practical side, as I already said, my BWD was below 210mm. I have adjusted the mirror distance to get closer to 240mm. Afterwards I did an accurate re-collimation and tilt correction for my sensor. The resulting test images showed round stars up to the edges of my full-format ASI 6200MM sensor with a small pixel size of 3.76mm. Star sizes were uniform across the image about 2", which is seeing-limited. So there is nothing wrong with adjusting the mirror distance when its necessary. Its logical and consistent with what GSO is recommending, and the results are good.
I havent had the chance to test for stray light and how flat fielding works. Waiting for clear weather…
And of course: nobody is supposed to change the mirror distance when the pics are fine, with of without a baffle. But when a baffle is necessary for flat fielding to work and the telescope is younger than 3 years, it might be worth checking the BWD and considering to change the mirror distance. In my case, TS offered to recollimate the telescope for free if my attempts should fail, which was a nice backup, but finally not necessary.
It is always difficult to do something against the main stream opinion (at least for me), and I have to admit that it caused significant stress to get bashed by various users on CN for going against a public no-go of adjusting the mirror distance. Yet, GSO did agree with my approach, it was a valuable experience and results are worth it.
Helpful Insightful
wizzlebippi avatar
I think you drew the wrong conclusion from GSO's information. The true BWD is 300mm from the optical face of the primary mirror. There's enough play in the primary and secondary mirrors to have correct mirror spacing, but a different distance to the rear plate.
​​​​​​In my opinion, if you're not seeing SA then don't worry about it. My 10" truss tube plate solves to 1607mm with the TS Optics 0.8x reducer, passes a Ronchi eyepiece test, and produces good stars across the field.
Götz Golla avatar
The PDF sent to me by GSO (RC10A-2DL_Model.pdf) shows that the BDW  should be 239.8mm measured from the rear plate of the RC.
Tim Ray avatar
I have an Orion RC10 steel tube. Both are correct. Compressing the mirror cell springs will change the separation distance between mirrors and hense change the Back spacing. 300mm from front of mirror is tuff to measure. Thats why the 240mm distance is given from rear plate of the ota.
Some flexibility does exist in the distance between the two mirrors without degradation of image. Thats why most of us get great results and i would guess our FL's are all slightly different from each other…
A change in mirror separation distance follows close to this ratio. 1mm delta equals 10mm delta in rear distance measured from rear plate.
Hope this helps…
CS Tim.
I 3D printed a complete replacement BT to fix the inherent issue with my older OTA…
wizzlebippi avatar
Götz Golla:
For some nominal mirror placement, I don't doubt that.  The problem is neither mirror is fixed in place.  Understand that it's possible to move the primary mirror a few mm in or out on the collimation screws, just as it's possible to move the secondary mirror in or out significantly on the mirror spacing adjustment.  The mirrors can be set at 463.6mm spacing but have more or less than 239.8mm to the rear plate.  That's the primary reason why specifying 239.8mm behind the rear plate is wrong.
It's even more complex when you take off nominal mirror spacing into account.  The relationship between mirror spacing and focal length is about 10 to 1, meaning that a 1mm error in mirror spacing is 10mm in focal length.  Since my 10" RC out to about 2008mm focal length, my mirror spacing is about 0.8mm too long, putting its focal plane at about 248mm without a reducer.
Adding a reducer further complicates this since it shortens the focal length by the difference between its focal length and working distance.  My TSRCRED has an 82mm BWD and focal length of 102.5mm, so it shortens my BWD by 20.5mm.  From the nominal 239.8mm, this is 219.4mm nominal BWD with the reducer.  Off nominal mirror spacing will skew this offset as well, though I'm not sure how to determine what this would be.
As an example of this cumulative error, my 10" GSO truss tube RC comes to focus 215mm behind the rear plate, or 4.4mm shorter than that drawing says it should be.  My advice is to use 239.8mm as only a reference, not truth.  You'll be close but give yourself a tolerance either side of that number.  If you're paranoid about correctly setting mirror spacing, get a proper truth source.  Either plate solve against a dense starfield or use a 10L/mm Ronchi Eyepiece.  Otherwise, if you're not seeing any spherical aberration, don't worry about it too much.
Edited 1st paragraph for clarity
Helpful Insightful
Rafał Szwejkowski avatar
My RC10 required a baffle - it's very evident how it does by looking from the front and back of the OTA.  It has nothing to do with mirror spacing.
Miguel avatar
Brian Boyle:
***Hello, I just found your post and would like to know what you did to get GSO to send you the tube. I have e-mailed them twice through their web page but never got a response. ***
Götz Golla:
RC10A-2DL_Model.pdf
This might be what i now are experiencing...
My mirror moved somehow so i had to recollimate the scope. Now i have these circular strays in my images...which i had not before. Plate solving reported that now my FL has change to 1596 mm in stead of the 1618 mm i used to have. (8 inch scope) spec of GSO says 1600 mm
But it is now a bit unclear to me on how to proceed , should i move my primary backward or forward?
wizzlebippi avatar
Increasing distance between the mirrors decreases focal length, and it's about 1mm of adjustment for 10mm of focal length. However, I wouldn't touch mirror spacing for a 4mm error. Instead I'd look for spherical aberration under the stars.
Thanks for confirming.
Yes, on second thoughts indeed i wonder if the mirror spacing is the culprit. But i suspect that some stray light comes in. I have a baffle with a extension when i bought it last year. It screws on and off , still i wonder if it is long enough considering the concentric circles in the image. Or it is the filter holder, that is the only thing that i added recently. I did not put a filter in. Guess i should try to remove it and see what i get. Hard to believe that would be the culprit but it is always possible. I don't think i see any SA on the stars. Besides, testing tilt with ASTAP reports 2 to 4 percent "none" and the median hfd is 1.8 ". That seems quite good…
David Russell avatar
Buckey Eyes Stargazer sells a custom 3D printed adapter that extends the baffle and stops direct light entering the focuser.
only reflected light should enter the focuser. Buckey has a web site, and also sells through Agena I believe.
I feel one of the problems is that people who dont really know what they are doing TINKER with their RCs, and when they still cant make them work properly, they sell them off.
then the next guy buys something with incorrect mirror spacing etc etc…
Back on topic, I had issues with flats, and bright circular rings, and after adding Buckeys adapter things looked good again.
wizzlebippi avatar
If you're concerned about the baffle, for the 6 and 8" GSO scopes it's pretty easy to tell if you have the OEM fix.  If your baffle tube has a second, thread on section that's about 2" (5cm) long, then your scope was fixed at the factory.  Try looking down the front of your scope around the secondary mirror housing to see if you can look directly at the camera sensor.  You might need a carefully aimed flashlight to confirm this.
Well Written Helpful Concise
Issue in frames calibration?
Hi everyone, this is a long post, but it’s needed to provide proper context. Thanks in advance to anyone willing to read through it and help me figure things out! I’ve been struggling for days with what seems to be a calibration issue (or possibly a ...
Jul 8, 2025
Both posts describe astronomers experiencing technical difficulties with image calibration processes for their telescopes.
Looking for advice on removing vertical streaks in my Blue channel (M45)
Hey everyone, I’m running into a calibration/processing issue with my Blue channel on M45 and could use some help from people who’ve seen this before. My B-subs are showing strong vertical streaks coming off the brightest stars (example frame attache...
Nov 28, 2025
Both posts discuss technical problems with astrophotography image calibration where standard correction methods are failing to properly address optical issues in their telescope systems.
