Batch processing in Autostakkert
13 replies329 views
Nick Grundy avatar
I'm currently working on a set of SER files captured in Sharpcap (83 x 500 frame ser's, spanning about an hour of Solar)
I've watched a few of the videos I could find out there in processing batches of files in Autostakkert and it appears fairly simple, however my process seems to stop after 3 SER's are processed. (even though 83 are selected)
Has anyone tried this or seen a similar issue? So far AS has been great for single images, but I can't seem to get this to work.
For reference, my PC specs are pretty extreme, so I wouldn't suspect any limitations there. (the 3 it processes are done in a couple minutes)
thanks!
Why would you want to do that? This is no DSO pre-processing. But, most importantly, which AS are we talking about?
Jonathan Ramos avatar
Hey Nick,
I ran into a similar issue the other day when trying to batch process (stack) a timelapse of ~100 SER files with Autostakkert 4. Funny thing was that the day before, AS4 was handling similar processes without an issue.
I then tried the same batch in AS3, and everything worked fine. Guessing it’s a bug?
Well Written Concise
Nick Grundy avatar
Jonathan Ramos:
That'd be my guess too. I'll let you know if I hear a solution
Jeff Horn avatar
I had this happen once.  It seemed that it was hanging on a single SER file.  I had to skip over that one file in the batch.  There was something that autostakkert didn't like about it.  Can't remember if I could do it solo.
Pipp also has crashed on me before and I realize it doesn't like long file names.  When file names were changed it had no problem processing hundreds of files.
Concise Supportive
Thomas avatar
You could also try running it as an administrator. I remember having to do that when using AS3 for something. Haven't done a solar time-lapse in awhile so it might have been that.
Ed Astle avatar
Hi Nick - what version of AS! are you running? 4.0.11 is the latest.
There are some similar sounding issues listed in the v4 bug fix list:
Autostakkert change notes
4.0.8 Fixed bug causing cancelling of processing during buffering and analysis stage
4.04 Fixed not stacking batch processing surface recordings with find anchor set to True
In the folder where AutoStakkert.exe lives there should be a subfolder 'debug_data' containing log.txt - maybe that can shed some light?
Nick Grundy avatar
@Ed Astle  thanks for bringing up the version, I was on 4.0.4. Just reran the stack with 4.0.11 and went all the way through!
now i just have to figure out all the rest of it :-)
Ed Astle avatar
Glad you're back in the game Nick!
Now get them animations coming smile
DerekWBuckley avatar
Im using AS v 3.1.4
Tried Batch processing 9 files , it Worked! Ser files
Tried it the next day, it didnt
Tried different set of files……….it stops after analysing one………v frustrating
Can you keep version 3 and down load Version 4 and keep both?
Tnx
Derek
Nick Grundy avatar
Im using AS v 3.1.4
Tried different set of files..........it stops after analysing one.........v frustrating
Tnx
Derek
Yes, you can just download the next version to a different folder name when you unzip it (because it runs directly from the unzipped folder and doesn’t truly “install” like a windows application)
Hi Nick
Ive downloaded As 4
Opened 4 Ser Files
It stops after the first file!…..Just analyses One.
Tnx
Derek
Ed Astle avatar
Make sure the files aren't still open in some other app.
Apps can open files for "exclusive access only". So if another app tries to open it the O/S will say "nope!".
A reboot will also clear that.
I can't think what else might cause that issue.
Regards, Ed.
Nick Grundy avatar
stops after the first file!.....Just analyses One.
I remember I hit this problem, but it went away after I upgraded to the latest version of v4
I'm assuming you are on the latest 4.0.11?
Questions about BiggSky blind deconvolution
Hi David, I just found out about this program and it gave me a pretty good result on Saturn from a 2 min .ser file. I have a couple of questions regarding this program. First I’m fairly new to planetary imaging, so some of my questions may be coming ...
BiggSky processes .ser files; may help with batch processing workflow issues.
Oct 6, 2025
