Hi dear AstroBinners and ISS catchers,
I have never imaged the ISS, tho am deeply fascinated by such projects.
I will try catching it with my friend tonight, using this setup;
10" dob with FL of 1200mm at f4.7
I will use my zwo asi 533 mc osc planetary camera
I could also use barlows if needed
My friend will be manually tracking the ISS while I will be adjusting Gain/Exposure
The first question is; Which ROI/FPS to use?
Here are a few options to consider;
Option 1 - 57fps
Option 2 - 80fps
Option 3 - 97fps
Option 4 - 117fps
Also, do I need to use barlow? 2x or 3x?
Which gain-exp to use?
Any other lifehacks?
Thank you very much!
Option 1 - 57fps
Option 2 - 80fps
Option 3 - 97fps
Option 4 - 117fps
