Affinity Photo OSC Dual Narrowband Workflow Help
15 replies306 views
AppalachianAstroworks avatar
Good day, titans of the astro world!
I just got an L-eXtreme filter which has been fun to play with.  I was incredibly impressed by what was showing up even from the AAP preview! I got everything stacked in Affinity yet I encountered a problem with my flat frames.  Issues with my lightbox I think, yet I'll be keeping the lovely 300s light frames I took.
This leads me to my real issue.  After stacking, I realized I haven't the slightest idea where to start with my data.  I've followed James Ritson's tutorials but I don't know how to split the channels for my data.  Since it's a OSC with a dual band filter, it's not like I have separate files for each band–just one picture.  I want to create lovely bi-color gold and blue nebula pictures like the ones I've seen on here but I'm a loss at how to go about doing this.
Does anyone have a workflow writeup I could follow for how to do this in Affinity?  I may try to get a PI trial but I'd prefer to use what I've already got.
Thanks, fellow astrophiles.
Respectful Engaging
I don't know about affinity photo, but as I read it you are just starting out. Why not try processing your data in RGB as is for now? The gold blue images you see are really more easily possible with mono narrowband. You can come pretty close with an OSC as I did some in the palette you describe with an OSC that come a bit closer to the gold blue you are describing but it took me a while to get there. If I where you I would start out with just your 'regular' stack for learning and then ask to do some more advanced editing of a bi color image. Splitting RGB is just the beginning;)
For PI:
https://www.astrobin.com/forum/post/38477/
Yeah, I am just starting out.  I've had some success in processing RGB, but with limited data due to time/weather.  I was able to get 2 hours of data recently which is what prompted my little foray into trying a bi-color image.  Thanks for the link, I'll try to apply those steps to my workflow once I get my flats fixed and hopefully get some more lights to go with them.  Thanks!
Good luck! You will get there, enjoy the progression you will make  hope those steps can get you a bit further!
Clear Skies
allan
Thank you, I appreciate it!  It's been a lot of fun experimenting with all of this.  I just got a new computer to handle processing better.  It was a lot more experimentation with my last one but it was 7 years old and couldn't keep up.
falke2000 avatar
The free software Siril has a built-in stacking option wich extracts Ha and O-III from a set of color images. Stretch both of the resulting images and finally combine them in Affinity using the JR macros.
Oh awesome thanks!  I have Siril but I haven’t tried to use it like that. I also have the macros from James. Should I stretch in Siril then export to Affinity or just stack in Siril and import both of the images?
Tim Ray avatar
I do the following post Stacking and calibration:
Crop
Remove gradients (Background extraction…smile
Background Neutralization
CC
Deconvolution
Mask Stretch
Starnet++ to remove the stars and creates 2 RGB images (Stars and Starless) name the image with Stars "Stars"
Then break up your image into RGB channels
Do a mask stretch again to get the levels fairly equal between the 3 images (RGB)
Rename R channel as Ha
Using PI I us Pixel Math and create a new image with the G and B channels named Oiii  G*.8+B*.2 is the formula. adjust the ratios to taste
now you have a Ha monochrome image and a Oiii monochrome image
Using a formula from and article by  The Coldest Nights website on Pixelmath and NB combinations use
PixelMath
R=Ha
G=((Oiii*Ha)^~(Oiii*Ha))*Ha + ~((Oiii*Ha)^~(Oiii*Ha))*Oiii
B=Oiii
make sure a new image is selected and RGB is the color space (or you will get a very nice monochrome image)
Name it Starless
Run some noise reduction and sharpening to taste
Curves,  boost the Sat, S curve the RGB/K, Slight increase on R an B from the middle of the curve, Slight decrease green   Hit apply
Invert image
Run SCNR to reduce green
Invert image back to regular
Should have something to like at this point.
I typically hit the Stars image with just a touch of Sat from curves
then in Pixel Math
Stars+Starless     make sure a new image is selected
Enjoy
@Tim Ray Thanks so much!  This is precisely what I’m after. I think I’ll need to give PixInsight another try. I’ve gotten my capturing flows down, I still get hung up in the processing though.
Tim Ray avatar
Perfect,  I am happy this info helps. This "recipe" works for just about everything. The same workflow is used with RGB (- a few steps). Now several steps can be very challenging. Deconvolution for example can take minutes, hours or days to get it just right. It will take time but I agree with you wanting to give PI another try. It is the Gold Standard of IP software. Once mastered, (i have been using PI for about 14 months) which will take sometime, your astrophotos will thank you for your efforts. Besides, an entire planet is using PI so you have a great resource in Astrobin and the knowledge its members process can help accelerate your learning curve with PI.
Give that article a look from thecoldestnights.com website. Its a winner and will breakdown the "False Color" mapping of channels.  NB imaging is so much fun. It really is the area of astrophotography that allows the astrophotographer to play with HOW your image will look…  with RGB imaging you are competing with your own eyes for what this image looks like because that is how our eyes see an object.
You are going to have so much fun with your images.
Enjoy
Tim Ray avatar
Also I wanted to say something about Siril. It is, for lack of a better phrase, "PI-Lite". I know that might offend members of the community, but I say this with Peace and Love. A friend of mind is slowly reconnecting with the hobby and is using Siril. Now he and I speak almost daily and have found Siril to be a very powerful IP application! But what I like about the Siril app is that so much of the knowledge gained by using Siril ports directly into PI. The "feel" of the interface, the names of the processing routines, etc are shared with PI so any time spent with Siril is practically time spent with PI.  The price is right for Siril and it will do everything needed to produce False Color NB images from OSC cameras and much more. I don't feel comfortable recommending how good people should spend their money, so forgive me if I was pushing PI a little too much in my previous post. Any IP software, once "Mastered" generally will provide decent results…
Thanks
Tim
Tim Ray:
Also I wanted to say something about Siril. It is, for lack of a better phrase, "PI-Lite". I know that might offend members of the community, but I say this with Peace and Love. A friend of mind is slowly reconnecting with the hobby and is using Siril. Now he and I speak almost daily and have found Siril to be a very powerful IP application! But what I like about the Siril app is that so much of the knowledge gained by using Siril ports directly into PI. The "feel" of the interface, the names of the processing routines, etc are shared with PI so any time spent with Siril is practically time spent with PI.  The price is right for Siril and it will do everything needed to produce False Color NB images from OSC cameras and much more. I don't feel comfortable recommending how good people should spend their money, so forgive me if I was pushing PI a little too much in my previous post. Any IP software, once "Mastered" generally will provide decent results...
Thanks
Tim
Thanks Tim I'll definitely look at that article as well.  I have SiriL I just haven't done much with it as I preferred the layout of Affinity.  I think I'll give it another go before biting the bullet on PI.  Gold standard is right, but from what I gather on here--you get what you pay for.  It's such a vast program that I found it easy to get lost.  If I can get the kind of images I want from SiriL for now I'll be satisfied with that.  Between flying for a living, school, and kids it's tough to find the time even to image--not that the weather has been all that conducive to it lately.  I appreciate the advice!!
--Aaron
Respectful
Tim Ray avatar
Good luck Aaron juggling all of that! It is a wonderful time of life. I am probably a few years ahead of you in the life cycle. Kids are grown and gone. A 1x grandparent upgrading to a 2x shortly around October. I drive over the road so I understand the lack of time and opportunity with the gear. While I am not familiar with Affinity. A process is a process. So the workflow most likely will port. Ask any questions at anytime, I wont be able to help specifically with the tools of Affinity but an image has to work its way thru some sort of workflow with measurable results at each step… Enjoy the journey…
Tim
Tim Ray:
Good luck Aaron juggling all of that! It is a wonderful time of life. I am probably a few years ahead of you in the life cycle. Kids are grown and gone. A 1x grandparent upgrading to a 2x shortly around October. I drive over the road so I understand the lack of time and opportunity with the gear. While I am not familiar with Affinity. A process is a process. So the workflow most likely will port. Ask any questions at anytime, I wont be able to help specifically with the tools of Affinity but an image has to work its way thru some sort of workflow with measurable results at each step... Enjoy the journey...
Tim
Having spent 12 years driving for Fedex I feel your pain.  I had to get off the road.  I appreciate your advice and willingness to help!
Both of these programs are far less obtuse than my old friend PixInsight.
Obtuse is a good way to put it!  I'll look into StarTools as well.  I am starting to see how using several programs could be beneficial to process.  I like the one-stop-shop feel of Affinity, but I'm open to trying new things.  I'd like to get this process streamlined as much as I can due to my current limitations.  Thanks for the advice!
Aaron
Fornax LT2 Review
I love this tracker Background: I rapidly progressed from a full frame DSLR wide angle on tripod, to an Omegon tracker, to a Skywatcher tracker, to a Fornax tracker and Vixen SXD2 mount I bought the LT2 after banging my head against a wall in trying ...
Tracker review; not relevant to post-processing stacked data issues.
Jul 1, 2023
SPCC Thoughts and Questions
After reading a related post on some problems using SPCC, it gave rise to some questions I have sort of assembled upon my recent adoption of this feature in PI. Please feel free to dump on me over these questions and challenges below, but I am not an...
SPCC is post-processing tool relevant to stacking and data processing workflow.
Mar 10, 2023
Imaging Time -- OSC filters vs. Sky Quality
I currently use an L-Enhance filter from a sky on the darker end of a Bortle 6 (~19.4 SQM); Bortle 5 is just a mile or so away. My most used local sites are in the 20.7 - 21.3 range. If I recall correctly, requisite imaging time is proportional to 2....
Filter and imaging strategy discussion relevant to L-eXtreme filter usage.
Apr 21, 2023
Photoshop tutorials
Can anyone recommend a good place in getting started with photoshop? I use a stock DSLR, stack in nebulosity, and then go to photoshop to stretch and post-process, and I feel like that last bit is the weak link in my workflow (other than figuring out...
Affinity Photo workflow relevant as alternative post-processing software for astrophotography stretching.
May 12, 2020
Adding true color onto dual-band OSC data
I've taken several images using a OSC camera (533MC-Pro) and a dual-band filter. I have the L-Enhance, but it'll soon be getting a new home as the NBZ just arrived. My only complaint about dual-band filters is the star colors. I'd like tr...
Combining filter data with OSC camera directly addresses author's stacking workflow.
Apr 28, 2023
