Daniele Borsari avatar
Hi, I have this question:
I have a motorized go-to mount (HEQ5 PRO), let's say I'm doing a mosaic and I want to image one panel before the meridian flip and another panel after the meridian flip.
What instruction should I use to do this in N.I.N.A.?
​​I would put one instruction set for the first panel and another one for the second panel with slew and center commands, but what trigger/loop condition should be used between them?
Daniele
Christian Großmann avatar
Hi Daniele,
you could use the "Loop until time" condition in your instruction set of the first panel. In there you can set the time to "Meridian". Then you could do the flip manually (I mean by command, of course not by hand) and put another command set for the next panel afterwards. This should work, although I never tried it.
Here is the link to the documentation of the command
https://nighttime-imaging.eu/docs/master/site/sequencer/advanced/conditions/
I hope this helps.
Christian
Thank you, I didn't remember that loop until time also had the "meridian" option.
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Rotation shift after meridian flip relevant to mosaic imaging across meridian.
Oct 28, 2025
DST with StellaVita and Skywatcher mount.
Hello, I am having issues some issues with meridian flip not working and I believe it has to do with the mount settings. In my SV I have this in the mount information. We’re in DST time currently in Canada which is why there is a 1 hour difference be...
DST with StellaVita and Skywatcher mount addresses meridian flip issues with mounts.
Sep 12, 2025
Possible NINA Mount Control Issue
I connect to my Tak EM200 mount using The Sky Pro 64 and control my imaging through NINA. This has worked well many times with the same sequencer templates. However, last night I had imaged up to the meridian, manually done a meridian flip and then s...
Possible NINA Mount Control Issue discusses NINA mount control relevant to sequencing.
13 days ago
