Hi everyone!
My latest image is M101: https://www.astrobin.com/na7n09/I am quite satisfied with the final result, but this is why I need to know what else is needed to create an even better image. Therefore, I would appreciate it if you could help me improve in the aspects you believe are within the reach of my equipment: I have used a Vixen R200SS at F5.6, the antlia V-Pro filters and an ASI2600MM Pro. Regarding this camera, I don't take dark frames because at -10 degrees Celsius, the dark current is so low that I don't see them as necessary. I haven't found any difference between calibrating with and without dark frames for my images. I don't know if you have any opinion on this matter.
So I understand that with more exposure hours, my SNR would improve, but I don't know if this would help create a more appealing image, it would maybe be more detailed (if my Bortle 4.5 sky allows it!). I am also aware that I need to add Ha signal to highlight the galaxy's nebulae. Are there other things to consider? I am convinced that I still have a long way to go in terms of my processing technique. For now, I only use PixInsight. Maybe I could improve my results by using Photoshop at some point in my workflow? Is the composition aesthetically striking? How do you see the stars? What do you think of the image's color palette? And its intensity? And what about the background color?
My workflow has been based on a stretch using the MaskedStretch process for both the Luminance and the RGB image. I did this to achieve an image with low contrast, making it easier to apply color to the entire image without encountering overly saturated areas. I also applied the HDRMT and LHE processes to add some contrast to the galaxy in general. Additionally, I used MMT to highlight star-forming regions and other small features. Regarding noise, I applied NXT, and for the deconvolution process, I used BXT. As for the rest, I used the typical processes of Curves, Saturation, etc.
And that's all. I thank you in advance for your help and advice. Clear skyes!
