ASI2400MC best GAIN and OFFSET values (Doubt about my masterdark image)
3 replies101 views
Thomas LELU avatar
Hello,
I have just purchased this superb camera.
Before being able to use it on the sky (while waiting for a fixing ring for my Wynne corrector) I start to make my library.I'm a little surprised at the hot pixels shown on the master image (50x300s at -10 ° C Offset = 40 GAIN = 145)
Attached you will find my master image and I would like to know if this is normal.
With simple STF in PIXINSIGHTLink to MasterDark : [(https://wetransfer.com/downloads/19b7da7e05983bfdd293c0be5ff79b2220210711162222/c7e391e8fc5e2830d78940a892e2736220210711162241/ce8385)]Do you have a master image to provide for comparaison?What values ​​do you use for GAIN and OFFSET?!Thank you very much
dkamen avatar
Hot pixels should be close to 100% brightness and you have only a handful of those. The pixels you see as white  are only 15% brighter than your average pixel (2.1% brightness vs 1.9% in the average). You see them as white because that's how STF stretching works, by definition: the brightest pixels (2.1% brightness) are mapped to white. In your case, the difference is grossly exaggerated by stretching.
The correct way to evaluate a dark using PixInsight is with the histogram shown e.g. in HistogramTransformation if you simply select the image and/or with the Statistics process.
To me this looks like an excellent dark frame for 5 minute subs.
dkamen avatar
Oh, with regards to offset, look at your histogram:
As long as your histogram doesn't "touch" the left edge, it means you are good because no values are clipped to zero.
Maybe for fewer than 5 minutes you would want to consider a larger offset, but for 5 minutes 40 is obviously okay.
Dimitris
Thomas LELU avatar
Thank you so much Dimitris for your complet response smile
Fullwell Capacity – Does it really matter?
Hi! With CMOS cameras you are being told to use a readout mode with a high fullwell capacity (FWC) for deep sky objects, so your stars won’t burn out that quickly. This is one of those things you usually don’t question, because it sounds plausible. H...
Discusses fullwell capacity relevant to CMOS camera settings and deep sky imaging.
Apr 15, 2023
