Reason for those linear image artifacts
3 replies203 views
Christian Großmann avatar
Hi there,
during the last nights, I collected some data of M51. Today, I stacked the images and in the master frames, i realized a linear halo through all of them. I could not detect those issues in the subs, but I guess they are there and just can't be seen, because they are really faint. The Luminance master I attached is the worst one. I guess it is because I had more subs for it than for the other channels.
I used PI and the WBPP script to create the master lights using the same settings as ever. I also used the same darks and bias frames as for my latest projects. This is the first time the problem occured, so I assume the issue is in the lights. The master flats look good to me, so far. The attached image is a screenshot with just the stf applied with standard settings.
In the past, i had some issues with halos, as well. But these ones are strange, because the are all parallel. I have no idea what causes such issues, because in the image path of the uses ES 127ED refractor, I can't find a straight edge other than those of the sensor window itself of the ASI183MM Pro I used. I can't think of a light source around my place which creates those strange halos.
Do you have any idea, what's the problem here?
Thanks in advance.
Christian
Helpful Respectful Engaging
Die Launische Diva avatar
You have probably forgot to turn off Linear Pattern Subtraction in WBPP. This script/setting tends to create such artifacts around bright objects when used with images acquired with CMOS cameras. This setting is more suited for CCD cameras having linear defects (as far as I know).
Double check that your calibration frames match you light frames with respect to gain, etc and that readout mode is the same (if applicable).
As mentioned above, it does look like it is only around the bright areas of the image, so maybe wpbb setting??
Thanks for your replies. That's at least a hint. So I will check as soon as possible.
Issue in ASIAIR autostretch preview, or actually FITS corrupted?
Good morning everyone. For some time now, I’ve been experiencing a strange issue during acquisition with ASIAIR PRO using the ASI678MC on long exposures. The phenomenon is particularly easy to isolate and observe by acquiring dark frames, so I’m shar...
WBPP script settings may cause artifacts in stacked master frames.
Aug 14, 2025
Circular artifact in WBPP processed image, suspect flat frame issue
Hi everyone, I’m seeing a circular artifact in my image after running WBPP. I used dark frames and the attached master flat. The artifact closely matches the flat frame, so I suspect it may be an issue with my flats. If that’s the case, I can reshoot...
Circular/linear artifacts in WBPP output suggest flat frame or processing issues.
Sep 29, 2025
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Gradient artifacts in frames could indicate camera or calibration problems.
Mar 5, 2026
