Got the first light with my new camera yesterday and noticed a weird reflection in the lower part of the image:
The equipment is as follows:
Collimation was pretty good, shot in B3 new moon, no streetlights or similar. This is 3 hours of 180s subs @gain 100 with a Baader UV/IR cut 2" filter, stretched in PI after ABE.
There still is some tilting in the upper left corner and the backfocus is slightly off.
Can this be a reflection from some of the bright stars outside of the FOV?
Or is this caused by an internal reflection / light leak? Any help would be appreciated.
Max
- Zwo 2600 MC DUO
- M54 Tilt adapter
- 5x2" EFW
- ZWO M54 to M48 (2mm Thick)
- 1mm Spacer and 3 M48 Extension rings (6, 5 and 4 mm), attached to a Baader MPCC Mkiii coma corrector.
- Scope is a Skywatcher 200PDS with an Aperture Mask and CNC secondary spider (Slightly misaligned to the focuser).
Max
