Installing Moonlite Focuser on Vixen R200SS
5 replies290 views
Andrew Ford avatar
Hello all, this is a dump of all the info I learnt while looking for a replacement to my Vixen R200SS focuser.
I began looking for a new focuser because I was running into the limits of the stock focuser with my imaging train setup: a QHY294M-Pro, CFW3M-SR, OAG-M with ZWO ASI120MM, and the Vixen Coma Corrector PH weighing in at nearly 3.2kg hanging off the focuser. I had issues with collimation shifting as the stock focuser had some slop in it and could visibily flex when loaded sideways, even with the focuser pointing downward. Adjusting the PTFE strips in the focuser did little to help this as it just pushed the collimation off or made the focuser so hard to move that my ZWO EAF or QHY Q-Focuser couldn't handle the additional load reliably. There is also some backlash but that calibrated out using the "overshoot" method in NINA well enough.
The stock Vixen focuser drawtube features an M60x0.75 thread and is supplied with a T-ring with a female M56x0.75 thread on the inside, into which the coma corrector is installed. The t-ring then adapts to M48 for the rest of the imaging train. Frustratingly, the Vixen coma correctors (CC PH and Extender PH) are slightly larger in diameter than a standard 2" accessory (being 56mm in OD) which means I would not be able to use the existing Vixen coma corrector or Extender PH if I went with an aftermarket 2" focuser. Judging from several forum posts regarding coma corrector options, the Vixen coma corrector PH and the Extender PH seem to perform very well, so I was loathed to have to look for another 2" coma corrector when I already had a perfectly good one. I also wanted to be able to use the Extender PH which adds a 1.4x barlow characteristic.
The Vixen focuser is very low profile, measuring only 56mm from the top of the focuser body to the scope tube, and my drawtube protrudes approximately another 10mm when achieving focus with a 55mm backspacing setup for my QHY294M-Pro. The stock focuser has about 37mm of travel. The vast majority of aftermarket focuser options that were short enough (e.g. TS optics had a few, Baader Diamond steeltrack, Feathertouch, etc) were only 2" which would necessitate purchasing a new coma corrector, and furthermore many did not have the lifting capacity I was after. There are limited 2.5" focuser options, and the Moonlite 2.5" CRL was the only one I could find that was both short enough and had an acceptable weight capacity. A 3" focuser is frankly overkill, many were too large anyway or too tall to achieve focus.
My scope in this writeup is the newer variant of the R200SS ("white tube version") with a 232mm OD tube.
So I ended up purchasing a Moonlite 2.5" CRL with the 1" stroke and the V3 mini integrated motor. I also purchased the M60 Vixen ring adapter from Moonlite. The parts arrived to me in Australia rather quickly, even with having to pay the customs import fees. The focuser came with an 8" and 10" flange adapter, USB cable, temperature probe with a 3.5mm 3-pole plug, instructions, 2" compression ring, and an M68 spacer ring.
I had a custom M68 T-ring machined by PCBWay, which incorporates the M56x0.75 thread for the coma corrector and adapts to M54. I had hoped to fit a Gerd Neumann CTU-XT tilt corrector into the mix, however I just cannot get a stackup that works - the Gerd CTU is 99mm OD and the largest object that fits under the QHY OAG-M is about 94mm OD. I might possibly be able to get it to work if I replace the filter wheel with the CFW3M-US, however I am considering just selling the whole QHY setup and replacing it with the PlayerOne equivalent which has a rear-adjustable tilt plate built in.
Prior to disassembly, I had collimated the scope one final time with the Catseye autocollimator system. Removal of the Vixen focuser was trivial, it is just 4x screws with nuts on the inside of the scope tube. The Vixen focuser hole spacing is four 4.8mm holes in a 72m x 72mm square, and a 80mm hole to clear the focuser.
The stock focuser looks tiny when compared next to the Moonlite. This thing is a beast and is a beauty to behold. It feels incredibly smooth to use by hand.
Mounting the Moonlite was rather straightforward, I just had to match drill the 4x 5mm holes into the scope tube. The Moonlite drawtube is 70mm OD so I did not need to cut a larger hole into the scope tube. I lined up the focuser using the Catseye collimator fitted into the focuser, and just nudged it around until the collimation was "close enough" by hand. I then marked the four screw hole locations with the focuser in place.
With the focuser installed, it was a simple case of collimating again and reassembling the imaging train. I also painted the fasteners with black paint inside the scope tube.
Of course it is going to be cloudy and rainy for the next week so I will report back once I have first light and can confirm everything works as intended. Driver installation was simple - I just downloaded the VCP driver, ASCOM driver and single-focuser program from the Moonlite website, and everything connected and worked just fine with NINA.
I will note, however, that the Moonlite 2.5" CRL has some substantial light leaks between the drawtube and the red machined body. I will need to solve this somehow, probably with a fabric sock.
I will update this post when I get some clear weather and can test the scope.
Andrew Ford avatar
Update, it works!
My first light was delayed by some teething issues having moved to a new laptop, PHD2 and NINA had to be set up from scratch again. After battling with PHD2 due to some very large backlash issues with the GEM45, I finally achieved the below 60s Luminance frame, near a 45% moon, straight out of the camera without any calibration data. The focuser has stroked outward about 8.5mm from the focuser body to achieve focus, so there are definitely no issues achieving focus with the Moonlite 2.5 CRL on the Vixen R200SS. NINA's Hocus Focus aberration inspector shows there is definitely still some tilt (about 70-100 micron corner-to-corner), however the Moonlite focuser seems to be working as advertised. The tilt values didn't seem to shift as I slewed around to different regions of the sky, so I am satisfied that the Moonlite focuser is much more rigid and achieves a more reliable focus position after autofocus runs.
Values used for NINA's autofocus routine were:
  • step size = 75
  • initial offset steps = 4
  • 5 second exposure time
  • Backlash compensation method "Overshoot" with zero for in and out travel
 This resulted in decent autofocus curves which demonstrated zero noticeable backlash from the Moonlite focuser in the autofocus curves.
NGC 5713 and friends, near the equator and meridian:
Stars are mostly round, I was achieving about +/- 1.5" p-p guiding with PHD2. There is definitely still some tilt I need to address, however
The Moonlite focuser definitely introduces a light leak into the scope tube. Light can leak between the focuser drawtube and the red focuser body. I will have to address this with a fabric sock or a 3D printed shroud. However, so long as I don't point any bright lights at the focuser during imaging/darks/flats generation, it doesn't present any real issues.
Charles Bracken avatar
I have the same scope and focuser, though I use a Paracorr with mine. Installation was easy, as you've shown here, and I've been happy with the focuser (other than its ridiculous weight!).  Thanks for recording your experience here for others to learn from. You make me want to verify I don't have any light leakage–how did you notice yours?
The R200SS is an underrated Newt. Glad to see another out there.
Andrew Ford avatar
Hi Charles, I noticed the light leak by shining a torch at the focuser body, and my OAG and imaging camera screens went white. During assembly, I could also see straight past the side of the drawtube when I had the focuser upside down on my bench.
Andrew Ford avatar
I'll also upload the manufacturing files for the M68-M54 T-ring I hade made. It has M68 threads to suit the focuser, and adapts to M54 with the M56 thread for the Vixen correctors on the backside. Hopefully someone else finds these useful. I had the adapters made by PCBWay and they came out beautifully. Cost me about $170ish and they took about a week to machine them.
M68-M56-M54 Vixen Adapter.zip
Ulli_K avatar
Excellent work, Andrew
im using a quite old second or third hand R200SS. I was thinking about replacing the focuser with a Moonlite several times, but so far it still does his job.
CS, Ulli
Field Rotators
I'm planning on purchasing a 155mm refractor with a focuser that accepts M92 and M63 threads. This will be for remote use so I'm looking for a field rotator that can go between the focuser and m63 reducer as the reducer doesn't have enoug...
Discusses replacement focuser options and compatibility considerations.
Jun 12, 2022
Looking for a small (60-110 mm) refractor to piggyback on a C11" for Imaging
I currently have a Stellarvue 80mm apo triplet (old version) piggybacked on a C11" EdgeHD to image from my observatory. I am not pleased with its performance, so I am looking for a new scope to replace it and pair it with my ASI2600mm. Weight is...
Installing focuser on scope; author specifically needs autofocuser installation advice.
Aug 10, 2022
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Discusses OAG and coma corrector setup similar to author's imaging train configuration.
25 days ago
CC6 + adapters
Hi, Does anyone in here have a CC6 and could tell me how you solved the adapter/extension part to achieve back focus? My current setup is by using all three (3) M90 extension tubes that came along with the telescope, which gives me merely 100 mm of o...
Extension tubes and focuser adjustments for achieving proper back focus.
Sep 10, 2022
Considering Drilling Holes In My New CDK?
I have been working on my current CDK14 scope with very good results. Here is a review of the scope: https://rouzastro.com/reviews/ The CDKs do come with fans on the rear backplate that blow air into the OTA. The larger scopes and newer versions have...
Focuser installation relevant to telescope maintenance and upgrades.
Sep 12, 2022
