Zwo ASI 533mc settings
17 replies931 views
Dave B avatar
Can anyone using the zwo533mc tell me what  gain settings you use , and is the sensor size 25.4mm x25.4mm , the size I need to input into APT .
regards Dave
Carsten Theves avatar
Moin David,
Gain 100 and 11,31 x 11,31mm.
CS Carsten
Michel Makhlouta avatar
I use Gain 100 Offset 70 (unity gain), as for the sensor size, you can check zwo's page, it has all the info (11.31x11.31)
https://astronomy-imaging-camera.com/product/asi533mc-pro-color
Dave B avatar
Carsten:
Moin David,
CS Carsten
Michel Makhlouta:
Thanks guys👍 Now just need the skies to clear .
Prea avatar
Hi Dave
The settings I use with my ZWO 553 MC Pro are,
Gain for galaxies, star clusters etc. is 100 even with filters, LPRO etc.
I use a Gain for Nebula with narrowband filters at 120/125 because of the amount of light getting through the filters.
I have some image with these setting on Astrobin user name Prea.
Hope It helps
Peter
Dave B avatar
Hi Dave
Hope It helps
Peter
Thanks prea very helpful .
Björn Hoffmann avatar
I am also using gain 100, but for offset I use 15 instead of the 70 many mention here. Reason is a very interesting thread in a german forum which I cannot find at the moment. In a nutshell it came out that already at offset 5 to 10 (at gain 100) you will not have any zero values anymore. By setting your offset too high, you are losing dynamic range.
Dave B avatar
Björn Hoffmann:
That is interesting bjorn if you find the post please post it.
falke2000 avatar
I am using Gain 100 and offset 10 as I have analyzed the bias frames for different offset values and above like 6 or 7 there were no black pixels anymore, so no need to sacrifice dynamic range by increasing the offset any further.
Elmiko avatar
I use 100 gain 20 offset.
Dave B avatar
Some great comments thanks guys , is it possible for someone to Dropbox a raw light so I can check my platesolving i use a sw200pds 920mm fl and a techno sky 70ag 350mm fl  .
regards Dave
Björn Hoffmann:
I found it, but it's all in german. Here is the pretty long thread: https://forum.astronomie.de/threads/asi-533-mc-pro-austausch-thread.283037/
And this is the relevant post in it, where someone measured the ideal offsets for different gains:
https://forum.astronomie.de/threads/asi-533-mc-pro-austausch-thread.283037/post-1474630
Dave B avatar
Thanks Bjorn google will soon translate 😁👍
Dave B avatar
A good  first light session on m27 see my latest upload  , now posted thanks guys, I have now acquired an l-extreme filter too .
Björn Arnold avatar
Björn Hoffmann:
I've also made the experience that the native offset setting is pretty conservative. I did a quantitative analysis of dark frames for my new ASI294MM Pro where I captured 600s dark frames with unity gain using a cooling to -10C and it turned out that the offset could safely be set be lowered to 5. Common values that I've found in the web for the 294 are usually 30+.
However, I am questioning the loss of dynamic range by putting the offset too high. From what I see, the offset value translates to intensity levels through the following rule: the median dark frame value is the maximum intensity value time the offset in per mille , e.g., offset = 5 is equivalent to 65535 * 0,005 = 327 (the ASIs scale up to 16bit no matter of the A/D-converter). Assuming that we put the offset to higher values, e.g., offset = 40 which gives 2621 median dark frame intensity, the dynamic range for a 14-bit A/D is still 13,94 bits. I'd say that this isn't a game changer, isn't it?
Curious to hear your opinion.
CS!
Björn
Dave B avatar
image taken using zwo533mc and a L Enhance 120Gain 10 offset 162 x180 sec exposure
Rafał Szwejkowski avatar
Also try gain 0 for broadband, it lets use the full well and actually has very nice noise characteristics.  Many people are discovering this about 533mc and 2600mc.
Dave B avatar
That seems interesting I’d like to see the  with and without for comparison
Cooling Temperature
Hello, I have an ZWO ASI 533MC, what temperature do you use generally to cool the camera ? thanks William
Discusses ZWO ASI 533MC camera settings and operational parameters.
Mar 20, 2023
