Temperature, Fan, Heater Pinouts
9 replies298 views
Kyle Goodwin avatar
Does anyone have the pinouts for the various temperature probe, fan, and heater connections on the scope?  I'd like to build a heating/cooling control box for the scope with a humidity sensor that will do a better job than the (very expensive) EFA + Delta-T combination, but I don't have the scope yet to test the pinouts myself.
Ani Shastry avatar
Hi Kyle,
If you haven’t received your scope yet, have you considered asking PlaneWave to wire your CDK for the Series 5 controller? That box does what the combination of the EFA + Delta T does, at half the price.
Ani
Well Written Concise
Ruediger avatar
Ani Shastry:
Hi Kyle,
Ani
AFIK, the series 5 controller has no Hr sensor. Moreover it is only compatible to series 5 focuser (5x the price of Hedrick), which is totally overpriced, and not compatible to the Hedrick focuser. Last but not least it runs at 24V and not 12V, which is a serious drawback. IMHO, Series 5 gadgets are only reasonable for Delta Rhos. It is the continuation of a faulty concept in my point of view.
Kyle Goodwin avatar
Ani Shastry:
Hi Kyle,
Ani
I'd much prefer a $40 box I can easily build myself, with 12v power, a reliable circuit board with good power management not prone to shorting, light weight, and a humidity sensor, which the Series 5 seems to still lack so far as I can tell.
blackrig avatar
I have a PW CDK 14 and was also considering replacing the overpriced ($750), closed source and failure prone Delta-T with a $25 Arduino that I can program myself. At this point I am controlling the fans and heaters with a Pegasus PB V3, but I am missing the access to the scope internal temperature sensors, so I cannot have a closed loop control.  The temperature sensors are connected to an RJ12 connector.
If somebody knows the type of temperature sensors used in the CDK14, I am happy to look at the spec sheets and try to reverse engineer the RJ12 pin out.
Well Written Helpful Insightful Concise Engaging
Kyle Goodwin avatar
The temperature sensors are DS18B20. That would be awesome if you could figure out the pin outs!
Ani Shastry avatar
Ruediger:
Ani Shastry:
Hi Kyle,
Ani
You don't really need to pair the series 5 controller mandatorily with a series 5 focuser (IMO, the Hedrick focuser is kinda junk anyway). Most people use either an Optec Gemini or a Moonlite Nitecrawler WR35 from what I gather. I had the option to wire mine with the series 5 controller (only) completely orthogonally to my Optec Gemini, but I didn't go with that option due to logistical challenges.
Ani
Ruediger avatar
Ani Shastry:
Ruediger:
Ani Shastry:
Hi Kyle,
Ani
Ani
Same did I. Kicked out the Hedrick and got a Gemini.
Kyle Goodwin avatar
I haven't been able to determine the pinouts, so I haven't yet been able to design a better thermal management solution.  I'd still like to do so if I acquire a CDK14.
Kyle Goodwin avatar
I've determined the pinouts for my CDK12.5.  I'm not sure if they're the same on other CDKs.  I'm currently working on developing a stand-alone system that can read all the temperature sensors (both via the EFA port and the Delta-T port), use humidity data from an attached sensor, and control both heaters directly, eliminating the need for both boxes and replacing them with a much less expensive single device in a much smaller form-factor.  If anyone is interested in giving me feedback on what they'd like to see in such a device if it were to become more generally available please message me directly.
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Discusses dew prevention solutions relevant to scope heating/cooling control systems.
Nov 28, 2025
My review of the Planewave CDK14
Adding a review to the CDK14 forum for those interested: Link: https://astrogeartoday.com/the-planewave-instruments-cdk14-tested-and-reviewed/
Relevant for CDK14 users wanting to customize heating/cooling systems.
Aug 12, 2022
