TiffsAndAstro avatar
Hope it's ok to ask here.
How do I rate my light frames? Once I do, how do I decide the cutoff point?
At the moment I use dss to give a score. Is this score relative to the session or across all of the sessions?
also in siril the plot graph. Frames under the line should be rejected?
Is it even possible to rate the snr of my lights?
When I am imaging, a low hfr in Nina image pane suggests a higher quality generally?
Shun-Chia yang avatar
I would suggest using your eyes to determine whether something is good enough to include. Scores or HFR can help you organize images, but relying solely on them to judge image quality can be risky.
Rating light frames is part of the journey toward better astrophotography. Using DSS for scoring is a solid approach, and the score usually applies to each session, guiding your frame selection for stacking.
will carry on as usual then, ty
What subframes do you keep / How many subframes?
I know this question is very subjective, but I am trying to better my processing. I will use NGC6960 (Witches Broom) as the image to discuss, as we all know it. I have collected images for the last 2 months on nights that I could. I am imaging it for...
Addresses rating light frames and deciding quality cutoff points for stacking.
Jul 22, 2022
Culling choices
This is something that I’ve been observing for awhile now and wanted to share. My usual culling routine would be to reject images with both high eccentricity and high FWHM. But when taking a closer look it seems that a lot of my subs with high eccent...
Discusses frame culling and rejection criteria for astrophotography light frames.
Feb 17, 2026
