Hey!
I'm placing a 151mm refractor at a dark site to operate remotely. At home, I notice that if I do not lock down the focuser with the focus-lock knob at the bottom of the rack & pinion focuser, the drawtube can slide toward the ground if aimed near zenith, due to the weight of the camera, filter drawer, etc.
When imaging remotely, I will not be able to lock down the focuser as that will prevent the electronic focuser from working. How do I deal with situations where the scope may be aimed toward, or close to, zenith? Is there a "middle-ground" where I can keep the focus lock loose enough so that the electronic focuser can work, but snug enough so that the drawtube doesn't slide out all the way due to gravity?
Jerry
Jerry
