Hello Friends,
I am looking to build a battery pack to run my and my friend's equipment out in the desert.
I have created the following mock up before beginning and would like somebody to double check everything will work.
What suggestions or changes do you have? Anything I should be concerned with?
None of the stuff we are connecting to the power poles use more than 5amps.
We decided to use the victron smart shunt for battery monitoring on our phones, rather than adding a screen for the box.
I have the following questions:
Here is the list of items in the picture:
- For the wall charger, does the battery positive go before or after the fuse?
- If I ever added solar in the future, does the MPPT positive connect before or after the fuse?
- Is the fuse on the radio sized correctly? I couldn't find any where on the manufacturer's page.
- Smart Shunt - https://www.victronenergy.com/battery-monitors/smart-battery-shunt
- Wall Charger - https://www.victronenergy.com/chargers/blue-smart-ip65-charger
- Battery - https://battlebornbatteries.com/product/12v-lifepo4-deep-cycle-battery/
- 80 Amp Breaker - https://www.amazon.com/dp/B07FF75V3X/
- Battery Disconnect - https://www.amazon.com/dp/B07MQ54KKH
- Fuse Block - https://www.bluesea.com/products/5026/ST_Blade_Fuse_Block_-_12_Circuits_with_Negative_Bus_and_Cover
- USB Panels - https://powerwerx.com/backlit-red-panel-mount-usb
- Power Pole Panels - https://powerwerx.com/panelpole-panel-mount-powerpole-housing
- Cigarette Lighter Panels - https://powerwerx.com/panel-mount-cigarette-lighter-socket-automotive
- Radio - https://herdiotech.com/collections/car-audio/products/herdio-12v-marine-fm-am-boat-bluetooth-radio-stereo-3-boat-speakers-antenna
- 3 Way Switch - https://www.amazon.com/dp/B07MV5K2JV/
- Red Lights - https://www.amazon.com/dp/B019MS9KRE/
- White Lights - https://www.amazon.com/dp/B07H1CFK8B/
