Asiair plus
5 replies171 views
Mark Worthington avatar
Does anyone use this to capture data for planets or prefer use of laptop. I've read some issues concerning fps rate not being high enough.
Looking forward to your experiences.
Thanks
Mark
Ashraf AbuSara avatar
I am by no means a planetary imager. Mostly DSOs. I have used it. It worked but yes the fps was limited. The highest I got on the ASIair was about 60-70fps with the 533mc pro which is not the ideal planetary camera.  On a laptop I was getting well over 100 fps.
You can drop your ROI to 480p or 320p as long as you can keep your planet within the frame during capture.  Of course if your seeing is above average you may not need the super high frame rate. Here is Saturn from last summer captured with the ASIair.
https://www.astrobin.com/vw3gph/D/
Thanks Ashraf,
Nice photo. Your experience is in line with others. I will be able to track, so perhaps I can reduce the roi. I have heard of some people linking their asiair to a ssd directly and getting higher fps. I've also heard people say using sharpcam with asiair, is better than asiair's capture software for planets.
Frank Lothar Unger avatar
Hi folks,
for Sun, Moon and Planets I use sharpcap,……………ASIAIR for me is fpr DSO.
Frank
Thanks Frank, it seems that one size doesn't fit all.
Arny avatar
As convenient the AsiAir is, I find I get better results with firecapture on a laptop wired to the mount, as its tracking feature for planets is great and it has no problems collecting full frame videos of the Asi 2600mc camera, whereas AsiAir is limited to 1024p and runs lower fps. For planets lower resulotion is ok, but for moon its sometime nice to get a larger canvas.
250p QUATTRO Carbon Fiber version on EQ6R PRO mount??
Hey everyone, I’m looking for some advice. I’m planning to buy the 250p Quattro telescope, but I’m concerned about the weight. With all the imaging equipment attached, it will be close to the load limit of my mount for astrophotography. I’m wondering...
Discusses equipment setup concerns relevant to planetary imaging capture systems.
Feb 6, 2026
Source for quality USB cables?
Hi, I'm moving a couple telescopes to a remote site and while testing in the back yard I've had some USB cables stop working. At least things cleared up when I replaced them. I'm looking for a supplier of high quality, outdoor rated, gold...
USB cable reliability issues directly relate to data capture equipment problems.
Nov 14, 2025
Advice on Next Upgrade
Hi AstroBin community. I am an amateur astrophotographer looking for some advice as to what I should upgrade next. My current setup is: ZWO ASI533MC ProWilliam Optics New ZenithStar 61 IIWilliam Optics New ZenithStar FLAT 61AOptolong L-UltimateEQM-35...
Equipment upgrade advice may address fps rate and capture performance concerns.
12 days ago
