Large / Fast / Diffraction-spike-less telescopes for ultra narrow-band ... do they exist?
John Stoneandrea tasselliMaksPowerWim van BerloJon Rista
56 replies2.2k views
John Stone avatar
Hi, I live in a Bortle 7 (SQM 18.7) city and I have limited imaging time due to light pollution and limited open sky.
 I own a C8-A XLT with a HyperStar IV and a 0.63x SCT Corrector IV.  The Hyperstar gives me 394mm focal length and the 0.63x reducers gives me 1475mm focal length.
Both are a pain to use due to collimation problems (especially the HyperStar) and edge of field star distortions because my ASI2600MC Pro's APC camera's sensor size is at the maximum published image circle for the two reducers.
I'd like to move over to monochrome imaging and I've settled on the the Antlia 2.5nm HSO filter set (but the LRGB is up in the air, but probably will be from Antlia as well).
http://www.antliafilter.com/pd.jsp?fromColId=146&id=140#_pp=146_647
These filters are spec'd:
Focus Ratio of ≥ f/3.5 for best optical performance
 I have an EQ6-R Pro mount and I want to find the largest telescope I can put on that mount that gives me F3.5 - F4 performance (at full-frame) WITHOUT diffraction spikes.
The only ones I have been able to find are F4/F4.5 Newtonians with coma reducer/correctors which would be great (Like the ONTC 10"/250P) but they have spider veins which produce diffraction spikes.  Check out https://www.astrobin.com/zlc8g6/ to see what I don't like.   Do such large/fast/diffraction-less telescopes exist?
Also, it would be nice for such a scope to have a set for flattener/reducers that would provide a few options of focal length (where the fastest/most-reduced version would have a F-ratio of >F3.5) Please let me know if you can help.
Mine. Or here: RH Veloce​ TELESCOPES – Officina Stellare Otherwise you are looking into specialized optics like Matsukov cameras.
IrishAstro4484 avatar
John Stone:
*** Not entirely clear on why you want the biggest telescope that you can get? Bigger isn't always better.
And, as far as I'm aware most of the very fast scopes are some form of Newtonian design.
If you don't like diffraction spikes then consider that some people will use a fast scope for capturing narrow band data that will also have a rig with a small refractor to capture RGB data.
You can remove the stars from the fast scope and replace them in post processing with the RGB stars.
If you can find it, a Vixen VSD100 might be able to do it.  It looks like it was recently discontinued.  It does have quirks, it's more of a camera lens design.  But it does fit your criteria.  AP110GTX is a little slower (f5) but it is fully illuminated.  I don't know if your hyperstar is fully illuminated, probably not. There are efficiency losses with most fast aperture scopes as you move off-axis, so while the f-ratio may be fast, the entire frame isnt necessarily realizing that.   Epsilon e160ed for example has 45% light fall off in the corners of IMX455.  The scope can fully correct the full frame chip, but while it's f3.3, that's only for a small portion of the frame.  Additionally, you lose efficiency with scopes that have a central obstruction.  I did the math a while back, and IIRC the epsilon e160 loses 20% due to the secondary obstruction.   AP110 has almost no light fall-off in the corners… the only problem is that it is near impossible to get unless you are already on the list.  But there are other refractors in the f5 range that do a decent job.  The FSQ106 has it's issues but is a very large image circle that fully illuminates a full frame sensor.  It's relatively easy to find and is a fast (true) f5 lens.    The fsq is probably the best choice for what  you are looking to achieve.
John Stone avatar
I'm pretty sure that StarXterminator can't remove spikes that go like 1/2 - 1/3 across the image and you're left with a giant 'X-s' in your starless images.
Otherwise, great idea.
John Stone avatar
These look great ... except they're F3 which is too fast for the filters which need >=F3.6
Even under the best circumstances there are phantom traces left by SXT (or even worse, SN) so that isn't a 100% proof method.
John Stone:
Well, then any f/4 telescope should do, assuming it has no visible diffraction spikes. Unless you go for the very fast filters that are good down to f/2. Or get a 6" lens capable of  FF corrected field of which there are a few. Or a modified spider as it is in my case, in which case the sky's the limit.
John Stone avatar
@Chris White- Overcast Observatory Thanks for these suggestions but they're a little on the small side at 100mm - 110mm objectives.
I think a F3.6 RASA type telescope would be perfect, but they're only made in F2 which is too fast for ultra narrowband like my HyperStar.
I've also looked at the SkyWatcher/Orion MN 190 which seems pretty good except it's a little slow at F5.3 doesn't have reducers/extenders and is limited to APS-C cameras.   I also wonder about how well corrected off-axis as I think the marketing blurb I've read says it's 10x better than an uncorrected Newtonian...  how does that compare to a good coma corrector like the Paracorr?  I've never seen a spot diagram for one either.
So, it's looking like the only telescopes without diffraction-spikes are:
refractors:  small aperture (100-140mm), fast (esprit 100 F3.6 reduced/APC, F5.5 flat/FF,  Askar 140 APO F4.5 reduced/APC, F5.6 reduced/FF, F7 flat/FF)
SCT: large aperture (203 - 235mm), slow (F7 reduced/APC 203, FF 235)
Mak-Newt: moderate aperture (152 mm, 190 mm), moderate (F4.8, F5.3), no reducer available
Mak-Cass: moderate aperture (90 - 180mm), very slow (F12 - F14)
any others?
Of these:
the largest is the MN190 from Orion/Skywatcher, F5.3, APS-C
the most flexible is a 140 APO with (0.65x - F4.5 - APS-C), (0.8x - F5.6 - FF) and (1.0x - F7 - FF)
the fastest is the Esprit 100 with (0.65x - F3.6 - APS-C) and (1x, F5.5 - FF)
I'm leaning towards the 140 Apo as the best compliment to the C8 - XLT I currently own.
MaksPower avatar
I can think of three ways to meet that spec and up the aperture too.  An EQ6 can manage a C9 with reducers, or 10” f/4.
1. Use an SCT - you need:
-  C9.25 Edge HD;
- A Starizona Hyperstar V4 for the above scope.
- A DSLR Teleconverter 2X, designed for f/2 lenses, I think Canon made one.
- Adapter rings for the Hyperstar to mate with the teleconverter, and to mate the teleconverter to a Astro camera (ASI533 or 2600 maybe).
Someone tried similar with a 1.4X Tele converter and it worked fine at f/2.8, it was on CN recently. Using a 2X will give you f/4.
So, in all you’d have choices of f/2, f/2.8 (with a 1.4X converter), f/4 (2X converter), f/6.3 or f/7 using the C9.25 with a reducer, f/10 natively, or say f/15…f/30 with Barlows for planetary.
2. Schmidt-newtonians - Meade made a few Schmidt-Newtonians - notably a 10” f/4 and an 8” f/4 that would do nicely; the challenge is finding one -about 1 per year appear on Astromart or CN. Optically ok, the most you’d need to do is upgrade the focuser to a modern one. I’m a bit surprised these aren’t more sought after for imaging.
3. A mak Newtonian can do it too, with no diffraction spikes, but the ones to look for are as rare as unicorns - notably the JMI 203mm f/3.5 (707mm focal length), or Intes MN65 (165mm f/5, I own one). Or the Skywatcher MN190.
the MN65 with ASI2600 produced this in 5 minutes:
https://www.astrobin.com/full/e1v757/0/
Spoiled for choice, I suggest.
Daniele Borsari avatar
You can get a Takahashi FSQ-106 with the 645RD reducer.
It's costly but it's also f/3.6 (perfect for your filters) at 380mm focal length (maybe a bit short for you). The declared corrected image circle is 60mm but you may have to check some reviews.
Daniele
MaksPower avatar
There's a Meade SN10 - 10" f/4 - for sale on AM. $600. Up to you.
Jared Willson avatar
I have an Astro-Physics 305mm Riccardi-Honders. I think that would meet your requirements–no spiders and f/3.8. No longer made, hard to find, and expensive. I believe Officina Stellare still sells their RH Veloce series of telescopes, ranging in aperture from 8" to 16" and having focal ratios from f/2.2 to f/5.6. Those would be possibilities if you want something larger than a 6" Mak Newt. Expensive.
- Jared
Well Written Helpful Concise
MaksPower:
It is not FF corrected. In fact I doubt it is 4/3" corrected.
MaksPower avatar
There is no free lunch…. fast, wide field, low cost… you can choose any two, but not all three
You can't always get what you want (Rolling Stones©)
John Stone avatar
Is there any information on the performance of that Meade SN10?
looks like it’s pretty old
John Stone avatar
Jared Willson:
I have an Astro-Physics 305mm Riccardi-Honders. I think that would meet your requirements--no spiders and f/3.8. No longer made, hard to find, and expensive. I believe Officina Stellare still sells their RH Veloce series of telescopes, ranging in aperture from 8" to 16" and having focal ratios from f/2.2 to f/5.6. Those would be possibilities if you want something larger than a 6" Mak Newt. Expensive.
- Jared
I looked at the Stellare scopes and their 10” looks great (not too heavy for the EQ6, short/compact) except it’s F-ratio is too fast.
The AP scope looks great but I’m guessing a 305mm primary scope is quite heavy.
Yes, the AP is around 65 pounds before you add dovetails and guide scope.
V avatar
Best thing I can tell you is that the RASA 8/11 exists. Either that, or get over a fear of slow scopes.
Jon Rista avatar
John Stone:
Have you considered a Canon "white" telephoto lens? I used a Canon 600mm f/4 L II lens for years. It had some slight issues with the IS (image stabilization) group, however right near the end of my use of that lens as a telescope (I needed to repurpose it back to bird and wildlife photography for which it was originally purchased), I picked up an Astromechanics EF adapter. This powered the lens, allowing me to use its built in focus, and seemed to resolve the slight IS group float.
The lens, for its size, is very fast, EXCEPTIONALLY sharp, and as far as refractors go has a whopping 150mm aperture. It is not super long, and it supports a 44mm image circle with excellent performance nearly from corner to corner (due to field obstruction you can end up with split star halos in the periphery stars). These days, the lens is a lot less than I purchased it for (a bit over ten grand at the time, IIRC 2012 or 2013). I think these days you can find them between $6k to $7k.
I ended up picking up an FSQ106 for my astrophotography. I spent a lot of time debating between the FSQ106 and VSD100. In the end, I kept finding things about the VSD having slightly bluer halos on stars, and it has its own unique focusing system. I ended up getting the FSQ106 so I could also attach a Nightcrawler focuser, which is a match made in heaven. The FSQ106 is a great scope...however it is actually not as good as the Canon 600mm lens. Its spot size is less ideal, spot aberrations increase more to the periphery of the field, and the details are just not as fine and sharp. I will probably be using the Canon 600mm lens again for AP, doing full color with an EOS R5 camera at a dark site for a while here before I put the FSQ106 back into action. The Canon "great white" telephoto lenses are great options for light guzzling refractors, if you have the dough to get one. Thankfully with the shift to the EOS R system, and a whole new set of lenses specially designed for that system, the EF versions have been coming down in price a lot for used or refurbished, so they are becoming more accessible as a result.
IMO, you would be hard pressed to find a scope as sharp and easy to use (at least, with the Astromechanics EF adapter, which is powered and supports ASCOM) as the Canon 600mm f/4 L II. There are probably some newer refractors that are sharper, but they are also a lot more expensive. The L II series of great white lenses made use of nanocoatings on the internal surfaces of some of the larger optical elements. These nanocoatings are part of the reason the images from these lenses is so exceptional...it helps refract the light with practically no reflection and better refractive characteristics. I've never had stars as small, with any scope (RC, Newt, Refractor), as what the 600mm lens produced, nor details as sharp.
Wim van Berlo avatar
Have you considered a Newtonian with custom bent spider vanes? Vanes without straight edges won't give you spikes. Although, anything in the light path will diffract light in some way. "There ain't no such thing as a free lunch."
I am the happy owner of a SkyWatcher 190MN,  and I chose this scope because of its focal length and lack of vanes. This scope performs as well as a much more expensive APO.
cs,
Wim
Alex Nicholas avatar
How BIG do you need? Like, you know a 10" f/3 is not faster than a 4" f/3? So unless you want the focal length of a 10" f/3 (750mm), size shouldn't really be that big of a deciding factor.
I'd be looking for a Tak FSQ106N with the 0.63 reducer giving you 106mm f/3.9.
thats going to give you speed, sharpness, no spikes, flat field over MASSIVE sensors, way bigger than 35mm sensors…
Alex Nicholas:
Except it is.
If you're REALLY keen and your pockets are ridiculously deep. Astro-Physics Ricardi Honders Astrograph. 305mm f/3.8, no spikes, almost refractor level sharpness.
binning, f-ratio, pixel-scale, drizzle, onag vs oag and the consequences for my next imaging setup
Fellow friends of the night sky, Just two months ago, I opened a thread asking for your opinions on which scope to buy. Today, I’m back with a similar goal. I’m willing to invest a significant amount of money to either complement or replace my existi...
Both posters are seeking advice on telescope equipment choices to improve their astrophotography capabilities given specific constraints or limitations.
Dec 15, 2024
How do I choose a camera sensor/barlow combination that will approximate the view given by a particular eyepiece?
I know that, for example, a 9mm eyepiece has a focal length of 9mm. Dividing a telescopes focal length by the focal length of an eyepiece used gives approximate magnification. We don’t think in terms of magnification when using a camera sensor instea...
Both posts discuss how focal length relates to the optical performance and capabilities of telescopes for different observing purposes.
Dec 31, 2025
Help me pick a new mount
I'm just looking for another mount I'm selling my Celestron AVX, 'cause it's a piece of junk; guides roughly between "1 and 2" and no better I tried many different things: moving one CW closer to the head, changing guide agg...
Both posts discuss challenges with Celestron telescope equipment and their limitations for astronomical imaging.
May 22, 2024
Optimized Newtonian - Is it worth it?
There are a lot of ways I can think of that the current crop of Newtonian Astrographs can be improved. Lets restrict the conversation to apertures between 6 and 10 inches. 1.) Lowering the focal plane relative to the side of the tube (eliminate the f...
Both posts discuss practical modifications and equipment configurations for optimizing telescope performance for deep-sky imaging.
Jul 28, 2025
