Any current users?
8 replies340 views
Piers Palmer avatar
I've recently acquired a used SXP2 mount which appears in excellent condition, works fine and gives me good tracking. However, when I compare it to my SXD2 mount, the RA axis is very stiff, which makes balancing the tube difficult. The dec axis is the complete opposite, which also makes balance tricky but in a different way.
Also, neither axes lock down very well. Well enough, it seems, but I'm surprised they don't go tighter. It does make me worry about slippage, although it's not actually happened.
Are these simply characteristics of this mount, or are there some user-adjustments I can make? I've not found any way to adjust anything so far.
Thanks
Not using the SXP2 mount but have a newly acquired SXD2 mount, so my question to you is how you connect to it in use, if at all. Especially if using NINA.
Piers Palmer avatar
I should be able to help! I connect my SB10 to my ASIair using a crossover cable. Apparently this is important…not a normal ethernet. I've never had any problems doing it that way. You do need the SB10 to be part of the connection, although I think the new Wireless Starbook might allow you to connect wirelessly. I did order one from Bresser but DHL lost it and then there was no stock!
Piers Palmer:
I should be able to help! I connect my SB10 to my ASIair using a crossover cable. Apparently this is important...not a normal ethernet. I've never had any problems doing it that way. You do need the SB10 to be part of the connection, although I think the new Wireless Starbook might allow you to connect wirelessly. I did order one from Bresser but DHL lost it and then there was no stock!
Thanks Piers. I got the cable already and updated the SB to the latest version and so far so good. What I was wondering about is what sort of setting needs to be modified once connected via the ASCOM driver and the network TCP/IP access point but if you are using the ASIair then it is likely different.
Piers Palmer avatar
Ah yeah. The asiair is pretty much good to go once you’ve chosen the mount. The only thing I’ve had to play with is to do with the meridian flip. Even now it’s not 100% successful but it mostly fails when I’m not monitoring it and I think that’s just Sod’s Law.
Jure Menart avatar
Hi Piers,
I am happy user of SXP2 and I have the same observations as you are mentioning, so I assume this is 'normal' behaviour.
I also don't see any issues or slips during guiding and as mentioned, I am really happy with the mount.
I can't comment on the SB10 connection with ASCOM/NINA, I can only confirm that it works great with Indi driver.
Supportive
Piers Palmer avatar
That’s reassuring to know; thanks.
In terms of balancing then, how fastidious are you? The dec axis is ultra sensitive so I do the best job I can with that, and I’m wondering if the RA axis doesn’t really matter too much? It’s a bit of a best guess.
Michael McFall avatar
I enjoy my SXP2 and get excellent guiding with it, fully loaded around 38lbs without counterweights.  DEC is very free moving while RA is stiffer, but not nearly stuff enough to cause balance problems.  With a 10lb and under imaging load, balancing might be a little more nebulous, but it's a non factor due to the strength of the mount and its motors.
For what it's worth, I also have SXP which moves equally freely on both RA and DEC.
Piers Palmer avatar
Thanks Michael - it seems my mount is behaving exactly as it should then!
Esprit 120 Slippage / Sesto Senso 2
Hey Guys, some time ago I was quite astonished to hear that there are tak toa users that support their focusers with rubber bands to get rid of slippage. First time hearing that people support their premium scopes with rubber bands I thought, that ca...
Discusses mount axis issues and slippage concerns relevant to author's worries.
Jan 19, 2026
Mount axes swapped?
Hi, I am trying to get started with this mount and I am getting more and more the impression that my axes are swapped, meaning that DEC changes actually cause RA changes and vice versa. This happens during three point alignment, where the RA axis sho...
Directly addresses RA/DEC axis problems and balance issues on mounts.
Aug 28, 2025
Goto mount recommendations
Hi everyone, I've been using a Skywatcher alt az goto mount that I think is pretty much designed for visual astronomy. It was all I could afford when I bought it a few years ago and got the job done (exposure times of ~30s). It's tracking has...
Used SXP2 mount comparison relevant to EQ mount upgrade decision.
Jun 26, 2022
