Jerry Gerber avatar
Hello,
I'm about to purchase the Stellarvue SVX 140T refractor with a Feather Touch 3.5" focuser.
Might anyone know the best electronic focuser for this gear?  I'll be imaging remotely only in a permanent observatory.
I know the ZWO EAF might work, but the bracket is machined for a flat, rather than a curved surface, so it's not ideal.
I can spend up to $500 or $600 for an electronic focuser and it must be able to be controlled through ASCOM/Windows.
Jerry
Arun H avatar
I'd recommend the ones made by Optec which are used with three Feathertouch focusers I have on three scopes.
Jerry Gerber avatar
Thanks Arun, that's exactly what I am going to get.
Reg Pratt avatar
I pair my FT with the Sesto Senso 2 and its been amazing. Zero backlash. Another option for you.
Scott Lockwood avatar
I use the MicroTouch autofocuser by Starizona with a Microtouch motor on my TEC160FL with the Feather touch 3.5 focuser for years with no problems.
Bill McLaughlin avatar
The Optec systems are very reliable. I have used them on a Tak 130, an FSQ 106, and currently on a Stellarvue SVQ 100. Nowadays there are two styles, the original that uses an external control box and a standalone USB motor. I prefer the box since it allows two scopes to connect. for futureproofing.
Rowan Prangley avatar
Hi Jerry,
Starlight Instruments make a PDMS focuser for Feather Touch 3.5". It's very sturdy and rated for higher payload weight.
Worth checking out! Though, lead times will be applicable.
If you imaging train is lighter in weight, than Optec or even Starlight Instruments FSM series (which are made by Optec) are excellent.
Hope this helps.
Best Regards,
Rowan
Jerry Gerber avatar
Thanks everyone for sharing your experience with me!
I ended up purchasing the PrimaLuce Sesto Senso 2 and the 37mm adapter for the Feather Touch 3.5" focuser.
Jerry
I'm using the optec ft40 focusers with and without the integrated controller.
The only thing that you should be aware of, is that over time I've had the gears disengage.   You twist the body of the focuser to disengage, which is convenient when you want to rack the focuser manually but this can be a problem in a remote setting. You may want to tape it so it can't work itself loose.
Tom Dinneen avatar
+1 for Sesto Senso 2. Solid fit. Much better than EAF which doesn’t fit all that well because of the curved bottom and lack of mounting holes for the bracket. Optec would undoubtedly work great as well. With the FT you want a motor that clamps onto the focuser rather than via a bracket. In my opinion.
Malcolm Park avatar
Jerry Gerber:
Hello,
Jerry
Starlight Instruments Posi-Drive Motor System - I have it paired with my Feather Touch and TEC140
Ernst Arnold avatar
Jerry Gerber:
Hello,
Jerry
Hi Jerry,
I'm using an Optec QuickSync FTX30 on my Tak TSA120 with 3.5" Feather Touch focuser. Works precise in a wide temperature range. It's controlled with linux and INDI driver. A nice feature is that it can be disengaged and used manually vor visual observation, but for only remote usage I would fix it.
Best regards
Ernst
Riccardo Civati avatar
Hi everyone
I’m bringing up this topic because i Need to install an autofocus motor on a feather touch FRF3545A-B.
I’ll Need to clarify: i’ll Need to move a moravian C3 26000 pro with 10×36 mm filters wheel and the original 1x TEC FIELD FLATTENER with and OAG.
I’m worried that if i use an HSM35 or an optec( since they attach to the micrometric pinion), i Might experience slippage in the planetary reduction gears with variable backlash.
Does anyone have experience with this COMBINATION?
The only solution would be the feather touch posi-drive motor
Bob Lockwood avatar
I use the Optec version (FT40) the FTX40 is just their newer version and pretty much the same as the FT HSM35. It's attached the fine-focus side of the AP focuser and will
lift my Moravian C3-61000 Pro with the 7x 50x50 filter-wheel. The image-train ( TCC-camera-CFW-OAG ) comes in at about 15lbs and the FT40 has no problem lifting it with zero slipping.
Note: As far as backlash, I don't notice any while reversing directions viewing the guide star, but there could be some, I just don't see it.
Peter avatar
Hello Gerry.
On my 3” Feathertouch I used a lakeside focuser. Unfortunately I can’t replace the control box, I’ve been looking at the Pegasus or ZWO motor focus units.
They have a good lift capacity
Bob Lockwood · Oct 3, 2025, 04:37 PM
Did you notice any drift in the counts at the focus point?
To be clear: the FT40 counter was ‘X’ when you First focuser on the star. The following year, were the counts more o less the same value, or did you notice a progressive reduction over the year?
Bob Lockwood avatar
Riccardo Civati:
To me, drift would indicate movement, so no. The count or focus position changes over the night just because the temp changes. As for keeping track of where the scope comes to focus over a year's time, I don't keep track of that, I don't see the point.
Software and drivers needed for PDMS Feather Touch motor with Pegasus
I recently purchased the PDMS Feather Touch focus motor, which you can find at the link ( Posi Drive Motor System for the Feather Touch and Astro Physics focusers ) I also purchased the Pegasus Ultimate Power Box V3 ( Ultimate Powerbox v3 – Pegasus A...
PDMS Feather Touch motor system directly relevant to author's focuser model.
Jan 8, 2026
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
NINA software integration with focusers may help with ASCOM/Windows control setup.
Sep 3, 2025
