Gain and Offset settings for ASI585MC Pro
17 replies1.3k views
kalax avatar
Just did first light on Bode's galaxy with my brand new ASI585MC Pro. Came out pretty nice!
I was using the recommended gain of 252 and I set the offset to 8.
Seems like 180s exposures are over exposed, should I be reducing the gain and allowing more noise? I set exposure to 60 seconds to get a better histogram but was hoping to do 180 or 300s exposures.
Any advice??
Chris Sulyma - SeaWolf Astrophotography avatar
I shoot with the 585MC, as well. Gain 252 almost always.
What Bortle conditions are you shooting under? I shoot in B8, and generally do 30-second exposures and have decent results on Bode's with that. That said, I rarely go above 30s on any target because of the light pollution. Even with an L-Pro, the sky still starts to saturate out at around the minute mark.
Mateusz Bogucki avatar
I always shoot at 252 gain and 50 offset. At dark skies I use 180s and in the city skies mostly 60s subs.
Here you can check my last image from this camera. I love it!
https://www.astrobin.com/m9uocd/
Best,
Mateusz
Brian Puhl avatar
While I still have yet to put much time on my 585 personally, I'd be pretty impressed if you're overexposed with that exposure length.     You should be looking at the image in the linear with no stretch applied.    Is the core of the galaxy visible, or blown out?    Blowing out stars isn't all that big of a deal, as long as it's not too excessive.
Here is not stretched, just raw stack view. 180s subs gain252
Brian Puhl avatar
Looks just fine to me.
kalax avatar
I'm going to run some tests tonight with offset 50 and verify that it's overexposed at gain 252 and exposure 180s.
I am in bortle 5-6
kalax avatar
This is the image I took last night with gain 252, offset 8 and 60second exposure
https://www.astrobin.com/po4lzh/
I am in bortle 5-6
*** This might be too long for this sky quality. I would recommend 120s or even 90s ***
kalax avatar
Going to give M 13 a shot.
kalax avatar
So M13 was pretty bright, 120second exposure was resulting in a completely white photo.
I went with 30second exposures with this target:
https://www.astrobin.com/0b7nec/
I guess the question is now, do I stick with very short exposures, or lower the gain?
Will changing the offset help?
*** Definitely 30s subs. Lower gain will not fix too saturated stars ***
dkamen avatar
Lowering the gain *does* reduce star saturation because the same number of electrons collected (i.e. the same amount of light) will result in a lower value read by the pixel. Saturation is simply the value hitting the maximum, so anything that makes it more difficult to achieve the maximum helps with saturation. Of course fainter signal suffers and read noise becomes more significant, otherwise we would be using only gain 0. It's a trade off.
Based on the manufacturer's diagrams, lowering gain below 100 will give you better dynamic range than gain 252. And you will need 5 times as many electrons to reach the same signal intensity, which is important if your stars are blown.
However, it would be a good idea first  to make sure your stars are indeed saturated, because 30 seconds seems like awfully short time to manage and clip the tiny stars in the outskirts of M13. Maybe it is just your processing, especially BlurX if it is too aggressive, and of course the stretching done. Try reading out a few pixels on stars in the (unstretched) image after background removal. Does it say 65535 or whatever the maximum value is? If not, then they are not saturated. Proceed to stretching with MaskedStretch, leaving everything to default. You should be able to discern two star populations (blue and yellow). That's what you are aiming for, in the main.
Dimitris
Helpful Insightful Engaging
kalax avatar
Dimitris
Thank you! Great advice!
Hey, has anyone figured out which offset is best for this camera?
Best,
Mateusz
kalax avatar
Mateusz Bogucki:
Best,
Mateusz
Cuiv the lazy geek's video came out to "8" but I am set at "3" now which is what ASCOM showed as default and it seems to work well. Maybe others can chime in with their experiences.
Dave B avatar
Mateusz Bogucki:
Best,
Mateusz
 Offset of 20 should be fine with gain 252 check the histogram and make sure your not clipping the data I think any lower than 15 then your likely to far to the left of histogram, I’m using 252g /off 30 , obviously if you use different gain then recheck your histogram so offset isn’t to far left .
Dave
kalax avatar
So update. I couldn’t do anything with offset to 3. In fact I was having trouble polar aligning because the stars were so weak.
I am back to offset 8 for now but will test some higher settings.
ASI 585MC Air gain and exposure clarification
My new setup just came in, and im kinda new with the zwo cameras. I have a ASI585MC Air and i was wondering how to setup the gain. I currently have an Askar 71f (without the reducer) as telescope and i use an Optolong L-enhance filter for nebulae sho...
ASI585MC gain setup guidance directly applicable to your camera model.
Jan 22, 2026
Parameters for the ASI2600MC Pro
Hi everyone, It seems to be that I'm the first one who create a forum of our camera using the new implementation of Astrobin forums of equipment. Basically, there are two important questions about how to configure the parameters of this camera. O...
Directly discusses gain and offset settings for ASI camera configuration.
Aug 10, 2022
Tips on my processing of bode's galaxy!
Hey everyone! I got out last night and decided to shoot bodes galaxy and the cigar galaxy, I also just got a filter and was able to use it tonight. My filter is a svbony cls eos-c clip on. I shot bode’s galaxy for an hour and 30 minutes of total expo...
Processing tips specific to Bode's galaxy imaging you just captured.
18 days ago
