Dark Filter for Making Darks, Making Flats Remotely
12 replies479 views
Jerry Gerber avatar
Hello!
I am considering putting a telescope in a remote hosting site.   I am thinking about many details, including how to make darks and flats.  I could get a Moravian camera that has a mechanical shutter, but it has the same sensor as the ASI6200 which is about $2000 less and has an electronic shutter.
Has anyone used a dark filter (opaque to make darks) in a filter wheel?  Does it work well or are there light leaks?
As far as flats, I'm not sure the scope I'd put there, an Askar 151PHQ, has a dew shield that can handle an automated LED panel that opens and closes in front of the dew shield.  I'm hoping the remote side has a flats panel on the wall that I could use.
Jerry
Helpful Concise Engaging
Nick Grundy avatar
Hi Jerry, there's loads of good advice on here, but i've been prepping for this myself. I'm going with a TOA-130, asi6200mm, and have been using the deepskydad Flat panel with for a bit now. It does flats as well as anything I've used (sky, giotto, amazon led panel)
I haven't tried darks with it, but I suspect if you do those on a night when the roof is closed for whatever reason and the flat panel closed, that should have leakage. (could be wrong though)
Francesco Meschia avatar
I have a "dark filter”. It does work for taking flats at night, but in broad daylight my ZWO EFW leaks enough light to be visible in the darks. In other words, the limiting factor is not the filter (which is a piece of aluminum, so perfectly opaque), but the rest of the hardware.
John Hayes avatar
My camera doesn’t have a shutter and I don’t have enough slots in my filter wheel for a blocking filter so I use the SIi filter to take darks.  I usually wait for a cloudy night when the roof is closed to take dark data and it works well.  My two current scopes have mirror covers and that’s even better.  A shutter is the best solution but you still have to take dark data at night so a shutter isn’t at all essential.
Byron Miller avatar
I'd recommend a flip-flat for any refractor. It will keep dust levels down, allow for fantastic automatic flats which you need to take for every filter that you use so not relying on a wall panel is a nice thing (also allows for a rotator to be used).
I never took remote darks without paying for remote hands to do so.   I left a heavy duty outside capable telescope cover in my gear basket, and I had them cover everything when parked.  With the flip flat cover closed, camera on cool and the scope cover strangled around the mount i was able to take darks If i needed too but I only did this once and never again… big expense for no reward on a cmos camera.  I did this on a cool winter night when the observatory wasn't open so residual heat from tec cooler didn't make the entire thing warm up.
your remote obsevatory if hosting with one of the commercial ones probably has a pretty standard way of helping you achieve remote darks and may even remove camera and put it in a box to assist if you go that route.
Reg Pratt avatar
My obs is pitch black at night when the roof is closed so I only do Sii filter. Never had to cover the tube.
For flats, sky flats are the most cost effective option but they can be tedious.
Emilio Frangella avatar
For the darks just use the HA or SII filter at night when the roof is closed (eg bad weather) and there wont be any light leaks.
For the flats, skyflats work fairly well, actually most of the times better than with a led panel for me.
edit - wow didnt notice the last comment gave my exact same advice
John Hayes avatar
Emilio Frangella:
Yeah…three of us have given the same advice so it must be a good way to go!
Robert Majewski avatar
Jerry Gerber
I do use a dark filter in my filter wheel.   I have not seen any big problems with light leaks.  I only take them at night, not during the day time.  However since the  exposures I take tend to be fairly short, a small light leak would not be a big problem for me.  Also, it is nice to be able to get fresh dark frames any time I want.
bob
Kevin Morefield avatar
I use a dark filter in my 8 position wheel for shooting darks.  As others have noted, there are too many light leaks for daytime dark shooting, but that was true of shutters too.  With remote set-ups it is a nice convenience not have to ask staff to put a cover on.  But on roof closed nights, John's SII filter approach can work.
Bill McLaughlin avatar
I have used the DSD on my Epsilon in a dark home observatory during the day and with an S2 in place. It works fine since it has a very tight seal compared to other flip flat devices. At F3.3 that is a pretty tough test.
OTOH, I also have a Moravian at my remote site since there is nothing better than an actual shutter….
Chris Strang avatar
I have a Dark Filter in a ZWO 8 filter wheel. I have blocked the .3” holes and the small holes for unmounted filters. It does not even come close to work in any light level.. If you made your darks at night in an unlighted observatory it may be OK. Chris
Seung-Jun Kim avatar
I use motorized flat panel with my remote set up.
When the panel is closed it serves as the telescope cover.
There is some gaps where light leaks can occurs. For that reason, I typically take dark frames during night time when the weather is not good.
In addition, when I am taking dark frames, I set my filter wheels on one of my narrowband filters.
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Stray light issues relevant to remote telescope setup and imaging quality.
Mar 1, 2026
Simple way to take flats
I've found the simplest way to take flats with my 8" Newtonian is: * I use an A3 LED tracing pad bought from Amazon (about $35) * I put two white vests/T-shirts between it and my OTA (about $10) * I set the tracing pad to its lowest setting ...
Remote hosting site needs flat/dark frame procedures; similar DIY approach applicable.
Sep 9, 2022
Soliciting experience / opinions on sharing a remotely hosted telescope
I’m giving some preliminary thought to placing a Sharpstar EDPHIII (360 mm focal length) scope out at a remote site such as Starfront, probably sitting on a yet-to-be-purchased ZWO AM3 or AM3N mount. Given the upfront costs of buying the mount and va...
Directly addresses remote hosting telescope setup and operational considerations.
Feb 1, 2026
Flats in remote imaging
Hello - I am exploring what it would take to set up an extra scope/mount I have for remote imaging, and specifically looking at flat generation. I'd like my flat frames for all filters to be 4s or longer. I have the following questions: How many ...
Specifically discusses flat generation for remote imaging setups.
Aug 7, 2025
