Does any one have any experience taking apart their ZWO Camera
10 replies560 views
Glen M avatar
I'm just wondering if anyone has experience in disassembling a ZWO cooled camera and doing any service or repairs, and if so, what to expect.
I have an ASI1600MM Pro camera which I purchased new a little over a year ago.  I used it for months with no issue, everything worked fine.  However, back in October, about 8 months after purchase, I started having problems with the sensor. I was getting weird interference patterns, which got progressively worse until the camera was completely unusable.  I contacted the retailer who contacted ZWO on my behalf, they asked me to ship it back to them as ZWO would have to service it.
I sent it off to them and after 4 months, I finally received my camera back.  They had to replace the sensor as the old one was defective. Unfortunately, right out of the shipping box, there were major issues with the camera.  The sensor was now working fine, however the camera would not cool.  The light came on, the fan worked, but the cooling percentage would increase from 0% to 90% without the temperature changing, then it would shut down and disconnect itself.  I tried isolating the power supply, tried different power supplies, with no difference.  After troubleshooting I have concluded that it looks like ZWO completed a major service of my camera but failed to test it to confirm it was in proper working order before shipping it back in disrepair.
I have since contacted the retailer again multiple times, however have only received one response from them indicating that ZWO "would not engage" with them on the matter.  The retailer has now gone silent as well.  It seems at this point I'm stuck with a broken, defective camera, which ZWO is refusing to replace or repair despite the fact that it appears they caused the latest issue during their prior service.
My choice at this point is to use the camera uncooled, or attempt to try and figure out what the problem is and fix it myself.  Both options are unappealing, however I would really prefer to have a camera that functions properly.  I'm a relatively handy person, I have completed a full spectrum modification on DSLR camera in the past. It would be intimidating, however if it's possibly just something inside that didn't get reconnected during service, it may not be too bad.
Thoughts?
Well Written Helpful Engaging
Dan Kearl avatar
You can purchase a new motherboard from ZWO and have it installed or install it yourself and that may fix the problem.
I have a 2600MC that has a bad power input and I get no help from ZWO other than to buy a new motherboard which will not fix
the input. I am trying to find one.
Glen M avatar
Dan Kearl:
Cooling was working fine prior to the sensor being replaced.  I don't think it's the motherboard.
If the Peltier unit is screwed then is though to get a replacement and even if there would be one is tricky to put everything in place nowadays that everything is so tiny and the thermal paste is a mess to handle. If it is just the wiring then isn't too bad.
Tim Ray avatar
I would take the camera case apart a see if the plug (if it has one) for the TEC is plugged in. I changed the fan mounts with shock mounts and reassembled the camera and forgot to plug in the fan….
Concise
Roger Nichol avatar
I had the cooler fail on mine after it got wet one night. I debugged the motherboard as far as possible and found a power supply that had failed, but there were no markings on a chip involved with that so I could not repair it. I ordered a new motherboard from ZWO and that resolved it.  Do check that all of the internal cable connections are in place first before going down the motherboard route.
Well Written Helpful Concise
Dan Holler avatar
I have a ZWO camera issue I must deal with at present.  Have all these issues been resolved satisfactorily?
Glen M avatar
ZWO and the retailer finally got back to me and asked me to send it back to them again a second time.  Repairs to the cooler were completed and it was returned to me.  Took a year and a couple of attempts, but in the end I got it back in original working order.
Dan Holler avatar
Thank you Glen for getting back on this.  While my camera still should be under warranty, with everything going on with tariffs, etc., I am very worried about mailing the camera out of the country.
Additional to that, I am very handy when it comes to astronomy cameras, so, I may just see if ZWO is willing to diagnose the problem, and then I'll try to fix it myself.  It definitely depends on what parts are broken and what is needed.
Dan
Drew Hackney avatar
Dan Holler:
Dan
If you're in the United States, ZWO has a service center in New Jersey that I shipped my 2600mc to in early 2024 when it had an oil leak. My camera was returned to me in working order after about two weeks.
Well Written Concise
Dan Holler avatar
Thanks Drew.  I have the dreaded green only channel problem and 'am praying to get an RMA to send it to New Jersey.
Warranty – EQ8-R Pro irreparable, Warranty delays
Hello, everyone. I am having a really frustrating experience with the repair of my EQ8-R Pro mount. This week marks three months since I sent it in for repair because the tracking/guiding was terrible. They returned it to me, and it was in worse cond...
Author experienced warranty issues; relevant to camera repair/service questions.
Jan 13, 2026
My ASI6200mm is acting up again
I had an issue last night in that a perfectly round black dot appeared on individual frames hours after the ASI6200mm had been running at its usual settings: 100 gain at -5 degrees with the dew heater on. It did not look like the oval-shape black dot...
Similar ASI camera model experiencing problems; directly relevant to troubleshooting.
15 days ago
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
ZWO camera connectivity issues; relevant to ASI camera technical problems.
Nov 25, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
ZWO cooled camera fan issues; relevant to camera disassembly and repair.
Nov 18, 2025
QHY9: cooling no more working
Hello I have a quite old (2013) QHY9 mono (sold under the name "CP8-MS") whose cooling does not work anymore (although the camera itself works). I was wondering if there is any way to have it repaired (and where?) regards jean-pierre Lees (...
Relevant experience with disassembling and repairing cooled astronomy cameras.
Oct 3, 2022
