M51 - how to acquire or process the red nebulosity ? Are HA pictures useful for galaxies ?
12 replies347 views
mousta avatar
Hi All,
So thanks to learning in this forum, I improved my image processing game (PixInsight)  a lot and finally got an image I’m partially satisfied with
https://www.astrobin.com/full/bwmj3z/0/?real=&mod=
I see is most really good  M51 pictures that the galaxy has a lot of red nebulosity. How to capture that do I need to take it with an HA filter and integrate on the RGB? Or this is an image processing trick and I don’t need to actually take HA pictures ?
thanks / looking forward for any constructive critique on the image too to make it better
Björn Arnold avatar
It depends on what your actual goal is. You're using dedicated OSC camera which records the Ha data that is there. If you use an Ha filter, you get a much higher contrast and could distinguish Ha data from "other red data". Hence, if your goal is to highlight Ha regions, it's helpful to collect Ha data and add this.
Otherwise, if you want to have a "balanced" color representation, I wouldn't add Ha data.
As a general point to your image. There's a strong background gradient which I would remove. In addition, I would apply a high pass filter or other technique to emphasize some finer detail to the galaxy.
Björn
David Moore avatar
I don't know if this helps but I have been having the same questions. I have an OSC camera and have wanted to enhance the Ha regions so I bought an L-Enhance narrowband filter for Ha and O3 and enhanced an image I had already taken of M51. I then overlaid the data from a mono camera I used to use for guiding for luminance to improve detail. I am no expert and have little experience having only started a year ago with astrophotography, so I am just trying to help. If you go to the big wall, type in Moorefam for search terms and M51 for subject you can see the before and after images. A Ha filter would have produced a similar results I suspect. I am just starting with anything other than an OSC camera so a novice in this area of filters and B & W.
Supportive
mousta avatar
wow!! What a difference it made. Your image looks amazing!! I have a mono guide camera, so I should try with it too to get more luminance data!
I will try the HA filter with OSC and see if I can integrate it nicely. Never done it before so will be interesting. Any tutorials you have on how to do it will be super helpful!!
Thanks
Engaging Supportive
mousta avatar
Björn Arnold:
Björn
Thank you so much for the feedback.
what is a high pass filter ? Is that a masking technique?
Björn Arnold avatar
"Kind of" (non-technical answer): A high pass filter determines the areas of strong gradients and will increase contrast in these areas. These filters are typically adjustable (i.e., what is a strong gradient? and how strong should the contrast increase be?). Through a mask you can select on which pixels and to what extend this operation should be applied.
There are several techniques to sharpen an image. Using a high pass filter isn't the only one. There are others like unsharp masking, deconvolution etc. etc. And each program may use different sets of sharpening techniques.
BJörn
PS: Don't know about your image processing background, so sorry in advance if my answer's either too basic or too technical.
Helpful Respectful
Björn Arnold avatar
Thanks
In the data sheet to your M51 image, you're using a color camera for guiding. With a colour camera, there is no point in trying further. If you have a mono camera, you should use the mono for guiding and not the color camera (given that the resolution isn't off and compromising your guiding).
One idea: If you shoot Ha data, you could add it as a mask to a saturation adjustment to saturate the red tones. In the end: experiment with different approaches.
IMHO, the goal isn't to replicate an image that you've seen somewhere else but to create an image that gives you satisfaction.
GalacticRAVE avatar
You need the narrow band to get the Halpha pop. On an OSC you also can use a dual-band filter and extract the R for Halpha. When you go for nebula, a combination of G and B gives you Oiii. Together with RGB for the stars this can give you quite nice shots, as you find a considerable number here on astrobin.
Regarding M51 and postprocessing: in PI you can combine it with the NBRGB script. Getting a good color balance is non-trivial and the different noise levels between NB and RGB can be challenging. What works nicely for galaxies is to create a composite with NBRGB, than use the Halpha as a mask to blend the HaRGB image with the RGB. Certainly still lots to learn and play with …
Tom Marsala avatar
I use the high pass filter in Photoshop. Just be careful and use it sparingly as it will bring out
noise in your photo as well (I speak from experience!)
Well Written Concise
noodle avatar
you have to use the Ha filter to get the small "red patch" in the spiral arm
here is my M51's Ha  data:
https://www.astrobin.com/full/lsyk8h/B/?nc=user
Niels V. Christensen avatar
FYI, an example on Ha narrowband info. applied to the red channel of galaxy M51,
https://astrob.in/368165/B/
Björn Arnold avatar
Tom Marsala:
Where exactly did you have problems with the noise?
I strongly recommend using a layer mask to apply the high pass only on the areas/details that should be enhanced and especially background should be excluded.
Björn
Tom Marsala avatar
Thank you! I've done it both ways. I've applied it to the whole framee to sharpen for large fields and I've done the layer mask, which is much more controllable, I agree.
[RCC] Carina Nebula
Hi All… I'm looking for some tips and critique on my Carina Nebula. It is my favorite image so far that I've processed but wanted to get your views on where I can make some improvements. This is the only image that I've taken from a...
Processing techniques and feedback on nebula image improvement.
Apr 17, 2020
[RCC] On my latest mono images and processing.
Hello, I recently moved to mono and upgraded my scope to try take my images to the next level. One day, like most everyone here, I would like to be good enough to earn some Top Pick Nominations or better. I have always found a constructive critique a...
Mono imaging and processing techniques relevant to capturing nebulosity details.
Oct 27, 2022
[RCC] IC1805 SHO
Hello, Finally got some clear skies and what better target to use my new camera and filters on than the first target I ever imaged, IC1805. Processing was done using Pixinsight and some of Russell Croman's tools. Pretty happy with this result alt...
SHO filter processing demonstrates Hubble palette technique for red nebulosity.
Jan 17, 2023
RCC - M51, 4 hours from Bortle 5, is there more possible?
Hi, this is round about 4 hours at data, at 450mm reduced with an Apo 80mm f/7 natively. My usual equipment. I shot around 4 hours of data at Bortle 5, and I'm just not content, there's no H-Alpha visible at all (okay I didn't use a H-Alp...
Direct M51 imaging discussion with similar equipment and data integration questions.
Apr 25, 2023
