Dennis Spender avatar
Hello all. Using a SeeStar S50 to capture the eclipse. I am able to create timelapse images of the sun. I managed to capture 331 images on one run recently.
What do I use to separate the individual images of the capture event from the timelapse video SeeStar created? I would like to save some, reject others, etc.
Well written Engaging
Claudio Tenreiro avatar
Hi, If the format is AVI or SER you can use Autostakkert and select the best % you want. Normally for details of the surface of the sun or moon, something between 5 to 10% of the best ones is fine. But it depends on how many of the images are above the 50%. Hope it helps. If you want to get all the individual images, you can do that using PIPP.
PD: I am assuming that you want to stack the best images to get one final good quality image.
I want to capture images of the eclipse from start to finish. I could take individual photos over the course of 3 hours. However I was going to set SeeStar on time lapse, say 60 sec between shots, and at the end of the eclipse expect to have over 300 images. I presumed then I’d use some software to review that time lapse video, extract out the images I want to keep, and store them in another file to be individually processed.
Well written
Ok, if you don't want to stack at each moment you can use Sony Edge, that is free, and allow to select images, even you can apply a process to one image and apply to the rest before doing the time lapse. I believe that Photoshop also has that capability.
THe program from Sony is a set of three programs, and they're linked, so you don't need to open the three separately.
I'll look into Sony Edge. ty
Dennis Spender:
So this is my intent, as noted above. I have found if I take a time-lapse, with photos shot every 20 sec, I can aggregate well over 300 photos in no time, enough to capture all the phases of the eclipse, without running out of memory. I have a supplemental battery to power the SeeStar so power exhaustion will not be a factor.
I have found with PIPP, I can stretch out that string of over 300 photos and see them individually.
Now the ask: I would like to individually review those over 300 photos captured during the time-lapse episode, and extract those images I want to preserve, for example 25 before totality, ten during totality, and 25 after totality.
How do I use PIPP to extract those photos  I want to preserve from the photo shoot, place just those photos into their own file,  and work later with those extracted photos?
I believe that if you select, in the output options, TIFF or FITS it will save all the individual frames.
Well written
