Problems locating objects
5 replies159 views
Enrique Ojeda avatar
I just bought my ZWO AM5 but I can't get it to move to the coordinates of any object and when I do (with M81) it positions itself in a very wrong direction. I don't have Asiar + so I control it with ASCOM and ASI Mount. The mount connects without problems to my APT software. I do the polar alignment with PoleMaster (adapt a 3D printed part to hold the pole). I think I have everything configured correctly in the ASI Mount and in APT, I mean location, date and time, etc. I attach images with the errors that the ASI Mount shows me. These errors appear when I click Sync in APT after doing the process to determine where in the sky my telescope is pointing. They also appear when I manually capture the object's coordinates and click GoTo in APT. I didn't do any prior configuration with the mount, I simply took it out of its box and connected it to my setup. I would greatly appreciate your suggestions please. I haven't been able to use my expensive new toy 😭 Thanks and clear skies!
Michele avatar
APT's PLATE SOLVING doesn't resolve the object?
dkamen avatar
It seems like the mount (or APT) has the wrong idea about which way the business end of the telescope is pointing to.
Is the telescope mounted the way the drawing on the mount indicates ?
Michele:
Thanks for your answer. I already solved the problem. Incredibly, I didn't realize that the Longitude parameter in ASI Mount was positive and must be negative for my location, I was in China for the mount and must have been in Mexico 🤣 Clear skies.
Michele avatar
My typical setup sequence in the backyard
Just sharing for any beginners out there. This is typically how I go about setting up and capturing for the night from scratch: 1) Take the tripod out, put it on my patio and point it as near to north as I can 2) Level the tripod using it's leg e...
Relevant for troubleshooting mount positioning after setup completion.
Jul 14, 2022
ZWO EAF - Help Wanted
I've had a couple of ZWO EAF for about 6 months now and have been very pleased with their function. I switched one to a new scope recently and have run into issues. In short it can't auto focus. Couple of key points: I can focus the scope man...
ZWO equipment issues; similar hardware troubleshooting experience applicable.
Apr 7, 2022
Why do I get the error message in NINA?
Hello, today for the first time when working with NINA I got the error message: "SyncToTarget() RaDec sync was rejected". Several times NINA drove to the destination again, but always the same error message. Can someone please help me?
Mount fails to sync/move to target coordinates, similar positioning issue.
Apr 17, 2022
