ASI 533 MC Pro Uv/ IR cut
2 replies279 views
Peter Sellen avatar
I would appreciate any feedback regarding the use of a UV/ IR cut filter on an ASI 533 MC Pro camera. If I add a  Baader UV/IR cut filter as 'semi-permanent' screw-on to camera does this equate to the 2600MC out of the box? The screw in filter does not affect the back focus train so I can still use the filter draw to easily change filters in the train ie adding either the L Pro (for Light Pollution) or L Ultimate 9 (for NB). This would then be similar to using these filters with a 2600MC. My question is should I remove the screw in UV/ IR cut when adding these filters on the 533MC Pro. This would also add complexity in using the camera in the field and the additional calibration files etc. It would all be much easier if I could leave the UV/ IR cut filter in place. The bad weather this winter has prevented any objective testing so would appreciate if anyone has advice or experience on this matter. Thank you.
Apart from the small light loss incurred there is no downside to have it permanently installed so, yes, you can keep it.
Peter Sellen avatar
Thank you - reassured.
UV/IR filter (L-Pro or Astronomik L-3) + L-Extreme in the same optical train
Since I have an ASI 533MC Pro without any UV/IR filter, I was thinking of permanently mounting an Optolong L-Pro filter in the dedicated thread of an ASKAR SQA55 (Petzval design). I would then also use a ZWO filter drawer in the optical train to some...
Discusses UV/IR filter mounting on ASI 533MC Pro camera with filter wheel compatibility.
Jan 6, 2026
Would you replace the Built in UV/IR cut on a 2600MC with AR glass?
Hello All, I am looking to replace the built in UV/IR cut window on a 2600MC-Pro with AR window and using a better UV/IR cut filter with better cutoffs in the UV and IR (Baader cmos optimized UV/IR cut filter) so i get less UV and IR and better glass...
Addresses UV/IR cut filter replacement options on 2600MC camera model.
Sep 18, 2025
Combining OSC 2600mc with 2600mm Mono Data
Hello, I have the following camera systems that cover 3 scopes and 2 mounts. ———————— Camera 1 system: 2600mc Pro ZWO EFW Antlia ALP-T 3nm HaO3 Filter Antlia ALP-T 3nm S2O3 Filter L-Quad ———— Camera 2 System 2600mm Pro ZWO EFW Antlia LRGB + 3nm SHO F...
Combines OSC 2600MC data with mono camera; relevant to multi-filter workflow discussion.
Dec 27, 2025
Pixinsight Help - Processing OSC data plus mono camera Luminance data
Hello, I recently acquired a mono 533mc camera. I captured luminance data on ngc 7331 with a uv-ir filter. I already owned a 533mc color camera and had some OSC data on the same target. I want to add the luminance data to my OSC dataset to improve th...
Uses UV/IR filter with ASI 533MC; addresses similar camera and filter configuration.
Sep 1, 2025
ZWO ASI533MC Pro - UR/IR blocking filter needed?
Hi guys! I'm sorry for this newbie question, but I'm a little confused - is it necessary to use a UR / IR blocking filter with an OSC camera like ZWO ASI533MC Pro?? If I understand correctly, a dual narrowband filter like L-extreme will come ...
UV/IR cut filter use specifically with ASI 533 MC Pro.
Apr 14, 2022
