SWSAGTI Polar Alignment hacks for the unguided and beginners
2 replies352 views
Michael Gehrisch avatar
I purchased a SWSAGTI a few months ago, and overall have been quite happy with the unguided results, even using my Canon 600/4 lens. But there are a few things that might make polar alignment easier and more accurate for beginners.
  1. Check the scope alignment, mine came quite a bit out of alignment which resulted in less than optimal results. This is easily corrected during the day by loosening and tightening the three tiny grub screws on the polar scope while focusing on a target in the distance and making sure it remains centered while rotating the RA axis
  2. Check if the cross hairs are level when the mount head is level. Mine was off by 1.5 ticks on the clock, so I need to compensate every time I polar align.
  3. Add a bubble level to the mount head, since it's difficult to be sure the crosshairs are level in the dark, a bubble level on the mount head makes this super easy.
  4. If you regularly shoot from your own backyard (like I do) you may be able to orient the mount on your tripod so that it automatically faces north.
  5.  We have tiles in a perfectly straight pattern, so I have aligned the SWSAGTI on the tripod so that when the back two legs of the tripod are on the line of the tiles, I am pointing directly North. So now as long as my tripod is level, Polaris is immediately in my field of view, needing only minor adjustment.
  6. I had an old 90 degree Canon angle-finder that doesn't fit any of my new cameras, but it did fit on an $39 adapter for the Polar Scope, so no more bending over when polar aligning, and this makes PA much easier and faster
  7. I use the Synscan Pro Iphone app, and I have found that in order to keep the SWSAGTI and the app in sync, if you make any adjustments by loosening the clutches it is best to turn off the mount, kill the app and restart the mount and then reconnect the app. Before realizing this I frequently had problems with the mount pointing being off when I used "GOTO". I recently had to uninstall the app and delete all data and reinstall, because I mount kept crashing into the hard stop. After resintalling it worked perfectly again.
TiffsAndAstro avatar
Wish i had read this 4 months ago. I found polaring aligning my swgti a really pain in the proverbial. Since i've started using nina, its 3 point polar alignment feature has been amazing. (apparently) very accurate polar alignments in under 15 minutes smile
RBerthoud avatar
This is great info, thanks! I wish I could find a way to go in there and fix the crosshairs' misalignment, though. Like, rotate them to make them level when in home position, so I don't have to be compensating for it every time.  Anyways, your post solved a huge problem I was having with my SWSA, thank you.
Respectful Supportive
Experience with Juwei-14 from Aliexpress
Hi all! the reason behind this post is to make avaliable some real world experience with the Juwei-14 mount, as there is so little info online, so i hope its usefull for few of you looking for an alternative to more expensive mounts. So, i got my Juw...
Different mount model; author discusses SWSAGTI-specific alignment issues.
Oct 15, 2025
Polar alignment produces absurd correction angles
Hi, I am using an ASIAir Mini with a Skywatcher EQ AL55i mount connected via the serial cable (could not get any other connection to work properly). I can control the mount from the ASIAir app and I got my camera and focus set up. Plate solving works...
Directly relevant; discusses polar alignment challenges with equatorial mounts.
Aug 18, 2025
SA + ZWO ASIAIR
Hi everyone Did anyone here tried the ASIAIR on a star adventurer and a DSLR? Is it worth it? My concern are the extra weight and the fact that the SA (not GTI) can only be corrected along one axis. I also wonder whether the ASIAIR really makes a dif...
Addresses Star Adventurer GTI polar alignment; relevant to SA polar alignment concerns.
Sep 10, 2022
Polar Alignment with Star Adventurer 2 w/o Polaris in sight for DSO Imaging
Hi All, Hope you all are doing well. I am planning on testing my equipment at home from where the view to Polaris is blocked. The equipment I have is: Sony A7III ZWO Guide Scope and Camera Star Adventurer 2 Stellarmate OS on RPi4 w/ EKOS/KStars and P...
Covers polar alignment techniques relevant to drift alignment method.
Jul 21, 2022
