Doubled bhatinov spikes.
8 replies179 views
Sean Mc avatar
An interesting thing happened last night. I got double bhatinov spikes on my edge hd 8.
my backspacing was previously 104-ish, and everything was ok for the most part but i figured i would try to increase backspacing to the more reported 105ish. To do this, i bought an aluminum anodized set of extension tubes off amazon. 3mm, 5mm etc. it came with a 12mm, so i used it to replace the 11mm celestron extension tube I had been using in my imaging train.
noting else was changed.
well.. it looked like collimation was off ¯\_(ツ)_/¯   Except… i was getting double spikes with the tri-bhatinov mask. Also, i couldn’t get the scope to collimate. The star shapes were horrible, and bright ones had triangular skirts…without the bhatinov.
2 hours of fiddleing, focusing, recentering…. I gave up and went back to the celestron 11mm tube. Instant round stars (needing a little collimation because i was messing with it).  No more double spikes with the bhatinov.
1mm difference of backspacing isn’t going to do that right?  I’m assuming it was the fault of the extension tube?  Maybe the treads are off axis slightly?
John Hayes avatar
Does your scope have fans?  I once had distinct double imaging from a C14 due to thermal layers inside of the tube.  Turning on the fans immediately cleared the double imaging and produced a pretty good image.
Well Written Concise
Sean Mc avatar
No fans.  like I said, the only thing changed was the spacer.
That's something quite wrong in all this. I wonder what it is.
John Hayes avatar
Nothing you did should have caused a double image!  Without fans, there is no way to tell if you had an index gradient inside the tube.
Sean Mc avatar
The scope was outside for weeks. It’s an edge hd, and it has the reducer on it, so no air changed inside the scope.
John Hayes avatar
Sean Mc:
Right…that might present just the right conditions that you need to develop a stable gradient index variation inside the tube.  When I saw it happen, the scope had been outside for many hours and it was very well stabilized.  I don’t know what happened with your scope that it would produce double images, but a stable thermal gradient inside the tube is one way for that to happen.   Remember that radiative cooling to the sky can cause such a gradient.  The best way to test for it is to turn on fans to mix the internal air to see if the double imaging quickly disappears.
Well Written Helpful Insightful Respectful Supportive
Sean Mc avatar
But how would it disappear completely just by changing the extension?  It wasn’t there before I changed the extension either.
John Hayes avatar
Without knowing exactly what you did, I can't explain how it came and went.  IF it were due to a internal thermal index gradient, that condition is pretty fragile.  Merely opening up the tube could cause the gradient to rapidly dissipate.  Again, I'm not saying that is for sure what happened.  I am merely pointing out that I've seen it before and it's a possiblity.
Bright stars seem to have some kind of flare happening
Can anyone give any advise as to what I may be doing wrong to get this flare/spike happening in my bright stars? I'm not sure if this normal or if this is due to seeing or atmospheric conditions or if I am stretching the image too much. I would j...
Double spikes suggest focus or collimation issues affecting star quality.
May 21, 2022
Hyperstar 8
I am trying to figure out backspacing with different filters. I've used IDAS filters and it seems that 1mm spacer works well. I recently purchased some astronomik filters but my stars changed for the worse. I have used an optolong clear focusing ...
Backspacing issues affect star quality; directly relevant to spacing problem.
Jun 17, 2022
Don't assume that triangular stars mean pinched optics
I posted a few times on here about my horrible star shapes … almost triangular with some square edges etc.. Many people suggested it was pinched optics. In the end, it just turned out to be my bad collimation; particularly the focusser position...
Doubled Bhatinov spikes relate to backspacing issues affecting star shape quality.
Sep 15, 2022
Mysterious diagonal star spikes
My setup is the Celestron 8SE+Starizona SCT Corrector IV+ASI2600MC Pro. I collimated the OTA and checked for tilt, yet all my stars have this weird oval shape. Looking at the focused star image, it appears that I am too close, even though I am exactl...
Backspacing and focus distance problems similar to your spacing concern.
Sep 10, 2022
