I was almost ready to do some real imaging, but a new problem seems to be my last necessary obstacle to overcome.
Basically I was about to go outside in my backyard, but then at the doorway, I had a feeling I should first check if I can reach focus; thankfully, I didn't ignore this feeling, and I found out I couldn't get enough inwards focus travel, but I was like an inch away from reaching focus.
To @V.M Legary, and others who are interested,
I got the UV-IR filter installed, and my Askar OAG; both look high quality. One thing that was exciting was that I was even able to see colors in the defocused star, which I could have never seen without my UV-IR cut.
My only complaint (which is not very important) about the OAG is that what holds the camera and camera holder from wriggling off the prism and hitting the ground is a tiny black screw, that is a little tough to tighten maximally with just 2 fingers, but I'm able to do it; 2 screws would've been safer in my opinion.
And, I did not buy the filter drawer, because I thought I might get away without it; with a filter drawer, my focusing problem would've actually been worse.
This is the "accessory train" and the accessory lengths (in mm) from the tip of my focuser to my sensor, maybe someone could help me cut down on the adapters somehow, or, recommend a more low profile focuser:
0. The length of the focuser, excluding the focuser tube protruding into my newt - about 64mm length
1. Large male thread on the focuser tube itself, and I know it's bigger than M54, but I don't know what size it is; manual doesn't say - 0mm length when connected to No. 2. (I contacted Celestron about the thread size of this "large male thread", but they haven't responded yet.)
2. Focuser to 2 inch eyepiece adapter/holder - about 33mm
3. M48 spacer with 2 inch filter installed, inserted into 2 inch eyepiece holder - 0mm
4. M54 male to M48 female OAG adapter - 0mm
5. M54 OAG - 18mm
7. M54 male to M42 male OAG adapter - 0mm
8. ASI533 M42 black ring - 11mm
Hopefully someone can mentally visualize that
If a photo is required for something, I'll take one.
So, the total minimum length from the outside of the Newt to my sensor: about 126mm, which is too much for me to reach focus; I would say that needs to be reduced by about 25-40mm.
Also, another problem is, if I remove my M48 spacer, I will not be able to use my filter, so then I also need to add in a filter drawer?
I was this 🤏 close from reaching focus!
It looks like this hobby is filled with seemingly unavoidable and perpetual problems. It's like you lockpick a locked door, and it takes you forever, then once you finally open the door, you see another door in front of you, and this repeats for 10, 20, 30, 40 times, some doors harder to pass than others, and at the end you finally reach a room called perfection, or is this room reachable? Are the doors infinite in number? 🤔
But by far, the first 5-10 doors are the most necessary to pass, if you know what I mean…
Pardon me, I always have to type something that sounds unordinary in many of my posts, and this is mostly an unconscious decision.
I have been eyeing the Baader Diamond Steeltrack focuser, as a possible fix to my problems, but I will wait for advice.
5. M54 OAG - 18mm
