I can look if I can find something where I can change it to true.
When I start guiding, phd2 calibrates and starts guiding, sometimes it actually guides for not more than 30 sec, but that's pretty rare. Most of the time though it just doesn't guide at all or just loses the star, because i don't know why. As I already said sometimes it corrects for a little bit but most of the time there are no corrections shown. That means it doesn't try to keep it on the axis.
I already shared a some guide logs, but here is one, where I really tried a few times. This is also the guide log where you can see the Ra drift while the Dec stays the same.
PHD2_GuideLog_2024-08-15_213752.txtFor example, at No. 18 in the guide log, you can see that it does make some corrections in the beginning but then stops.
I also think that No. 35 is really interesting. You can clearly see corrections in the beginning. Then the correction stops and every time the graphs move to 0 on the axis again, I starten guiding over. What's really strange is, that in the beginning it says MountGuidingEnabled = false and after stopping it (5x Star lost) it says MountGuidingEnabled = true.
At No. 37 - the 14 min long one, you can see that it made no corrections in the first place and said MountGuidingEnabled = flase, but after stopping it it wrote MountGuidingEnabled = true (below the calibration assistant data).
(The numbers are the numbers when opening the log in phd2 log viewer)
The only thing I could imagine is that there is something that inverses the MountGuidingEnabled command, because when I start it sets to false and when I stop it becomes true.
Maybe I should try disabling the Enable Mount Guide output option in the brain settings
Jokes aside... I just have no idea what the problem could be.
