Advice on How to Process Stars
2 replies237 views
Andre Vilhena avatar
Hello Everyone,
One of the things I most like to preserve is star colours. However, in the majority of the photos there are always some stars whose cores are burned, in a lesser or greater extent.
Which would be the best way to avoid star core saturation and keep its colours? I am thinking that maybe taking some subs with much smaller exposure time and blend the cores of these subs in the main subs. Does this make any sense? If yes, how could it be achieved in PI?
Thanks.
André
Doug Summers avatar
Well, the primary issue of course is not to over saturate in the first place.  So, finding an optimal sub calculator (check CN or other on-line sources), and verifying against your setup is the best first strategy.   Afterwards, I like to use the color clip script during linear post-processing for those special saturated cases (not without some sacrifice in peak intensity at the star's very core).   Transition from linear to non-linear using masked stretch has worked better for me than the classic STF/HT method as it relates to retaining star colors.   Others may have good advice for pixel math blended solutions, but for the most part, I've found good fundamentals (starting with exposure calculators) go a long way.    CS  Doug
Hi Doug,
Thanks a lot for your feedback. I usually have a look at Sharpcap exposure calculator but usually the recommended exposure is too small and I'd be ending up with hundreds of frames to process. But from your answer, I suppose that having a set of really small exposures to blend may make sense - "just" need to figure our the best process.
But still, I'll have a look into that script.
Andre
Which scope for galaxy imaging? 8" f/4 Newton, RC8, or 5" Triplet?
Hi everyone, long post incoming - excuse my ramblings - after I finally moved to a place with a secluded and safe roof terrace where I have enough space to put up two rigs, I'll plan to add another rig for smaller Targets next to my CEM25P with a...
Discusses telescope selection for imaging; not directly relevant to star core saturation.
Apr 23, 2023
SPCC Thoughts and Questions
After reading a related post on some problems using SPCC, it gave rise to some questions I have sort of assembled upon my recent adoption of this feature in PI. Please feel free to dump on me over these questions and challenges below, but I am not an...
About SPCC color correction; potentially relevant for preserving star colors in post-processing.
Mar 10, 2023
