Kapil K. avatar
A quick question: I have a celestron focus motor attached to my Nexstar 8se. I do all my imaging through ASIAIR. I am curious if the focus motor is compatible with ASIAIR?
I use ZWO filter wheel and Asi1600mm pro camera. My mount is eq6 r pro. Everything works well with ASIAIR except for focuser. That’s why I was wondering if anyone has tried to make it work or have any suggestions/pointers.
-Thanks,
kapil.
Bob Rucker avatar
Sadly it’s not. The ASIAIR is a closed system and with the exception of some DSLR cameras, is only compatible with ZWO devices. That being said, I managed to modify the ZWO EAF to work with my 6SE. Their focuser is superb and they do have a mounting solution for the 8SE.  It has really improved my imaging and I recommend it as a great solution if you have the ASIAIR Pro.
Well Written Helpful Concise Supportive
Optimising a C8 for APS-C. - Drawtube v Celestron Focus Motor
I am currently using a Celestron Focus Motor and getting pretty good focus runs in NINA, good enough for imaging purposes but always looking for ways to improve. My focus runs just aren't consistent enough for the miniscule tilt adjustments I'...
Celestron Focus Motor compatibility with imaging software; similar setup experience.
Feb 16, 2023
EQ6R stops Tracking with ASIAIR PLUS
Hi everyone, i have an issue with my EQ6R-Pro+ASIAIR PLUS setup. Everything is working fine except one thing: the mount stops tracking in various situations, e.g. when a plan has finished or was aborted. Sometimes it feels just randomly. When navigat...
EQ6R Pro with ASIAIR setup; troubleshooting hardware and software integration issues.
Sep 21, 2022
