ASI AIR PRO + Nikon Z6ii Image Problem
4 replies192 views
Jonathan Hill avatar
Hello!
Tonight I tried imaging with my ASI AIR Pro and my Nikon Z6ii, but had some problems with how the images appeared on the display. It appeared that every photo I took was delayed by 2 photos. Ex: I took a preview pic of Jupiter for a sanity check, but it loaded the last picture of a random star field that I used to focus. It wasn't until I took 2 more photos of Jupiter that the first Jupiter image I took showed up on the ASI AIR display. I was able to repeat this with every object I slewed to and it was always 2 pics behind. I tried restarting the camera and ASI AIR, recycling power, etc and nothing helped.
This problem obviously messed up the plate solving because the mount was pointed at the correct coordinates, but the ASI AIR was plate solving the photo taken at the previous position (3 photos earlier), so the solution showed a different pointing position.
I've looked through all the settings in the Nikon and can't find anything different from my Nikon D5500 (which had no problems) that may be causing this. The only difference is that I have to use a USB-C cable for this camera instead of the micropin connector for the D5500.
I can't find anything online about this problem either. Has anyone else experienced this problem and have you found a solution?
Jonathan
Oscar H. avatar
2 things come to my mind:
1. Is your Nikon able to save an image as both Jpeg and RAW at the same time? If so, you need to turn off Jpeg and only use RAW; A similar lagging/freezing behavior happened to me with my Canon because of this issue.
2. Does your ASIair show any warning prompt or symbol anywhere? Because many times it gives some sort of sign when something is not right.
EDIT: by "ASIair display", I was assuming you meant your phone, am I right?
Hi messierman3000,
Thanks for the reply! Yes, it is able to save as both JPEG and RAW. The ASI AIR actually gave me a warning about this when I plugged it up (and wouldn't let me take a photo), so I changed the setting to RAW only and that's when the problem appeared. Could it be related to having 2 SD cards in the camera?
It doesn't give me any warning symbols or lights or anything, unfortunately. The only thing it has prompted me with is the RAW+JPEG correction.
And yes, ASI AIR display is referring to my phone.
Thanks,
Jonathan
Oscar H. avatar
Jonathan Hill:
Hi messierman3000,
Thanks,
Jonathan
So, stay with just RAW mode, and keep one of the SD cards inside of the camera instead of 2, and see what happens.
These types of problems are what caused me to buy an ASI533MC Pro, and, I don't regret it one single bit.
Jonathan Hill:
Hi messierman3000,
Thanks,
Jonathan
I'll give it a shot and share the results here when I get a chance.
I have a 2600MM, but don't have LRGB filters yet. Otherwise, I would have used that camera. I'd like to invest in a cooled color camera at some point just for shooting comets, but we'll see! The 533 is a great camera.
Problem ZWO ASI 662 and SW 150/750
Hi everyone. I'm new to this, and yesterday was the first time I tried attaching the camera to the telescope. I have the Skywatcher Newton 150/750 PDS and the ZWO ASI662 camera. When I tried it with the camera and its original head, I was able to...
ZWO camera setup issues; may share similar hardware compatibility problems.
Jul 26, 2025
ZWO 2600 MC 2025 Version Troubleshooting - Missing frames and exposure failures
Hello to everybody, I need help to solve a strange problem with my new Zwo ASI 2600 MC Pro. I bought the 2025 camera and when I first tested it I noticed this problem: sometimes it did not save the sub in the memory but the asi air kept saying that i...
ZWO camera troubleshooting; addresses frame/exposure problems with ASI cameras.
Dec 1, 2025
CEM40EC Handset: "Unknown Position" - What does it mean?
I may be a little paranoid after suffering a tripod collision due to a known (but not to me) software compatibility issue between the ASIAIR and the CEM40 series of mounts. But I just noticed that as soon as I begin to slew after setting the mount ze...
ASIAIR software issues; directly relevant to ASI AIR Pro problems.
Jan 28, 2026
