Issue with QHY294M - Camera won't connect or finish exposure
2 replies72 views
Pablo Petit avatar
Hello everyone
I am experiencing a strange issue with my QHY294M, the camera won't connect through ASCOM, only directly on Sharpcap and when it does, it will never finish an exposure. I can't get a single image.
The camera is detected, the cooling works, but that's it. I've reinstalled everything, including ASCOM and Sharpcap, tried 3 different USB cables, 2 computers,  tried on a USB2 and USB3 connection, tried with and without the 12v power supply, nothing works.
Has somenone had the same problem ?
Any help will be a lot.
Clear skies
Pablo Petit avatar
Thanks Allan for your response.
I finally found the solution. I post it here in case it happens to someone else. I simply had to remove the four screws on the bottom of the camera to open and tighten the white data cable that for some reason came loose.
Well Written Helpful
Camera failing to download
So I'm loving the 2600mc pro and I think my last couple of images came out really nice (Orion and Pleiades please to have a look and any comments/feedback would be much appreciated.) However, I've had issues with my camera sporadically failin...
Camera failing to download — similar camera connectivity and image acquisition issues.
Jan 8, 2023
