Strange Artifact I've Never Seen Before
7 replies177 views
Jerry Gerber avatar
While processing M106 this afternoon I came across this weirdness:
Does anyone know what might have caused this?   I was able to process it out, but it's still concerning to not know what might be causing it.
Thanks,
Jerry
Oskari Nikkinen avatar
Need more details.
What processing software, what calibration worfklow, is this an autostretched image with just an STF applied?
Without details, i have seen something like this but not exactly like this, with a 16-bit stack produced with under exposed subs.
Jerry Gerber avatar
Hello Oskari,
Thanks for replying!
Pixinsight for calibration, pre-processing, image registration and integration.   I have played around with the histogram transformation and can see the artifact in the stretched image, but barely.  It's when I import the TIFF file into ACD Photo Studio Ultimate (my photo editing program of choice) and start applying different versions of LIGHT EQ (it's like an audio EQ but for light frequencies) that I really begin to notice it.   I've managed to remove the artifacts in my final (maybe) image but I'm still perplexed as to what caused them in the first place.  The artifacts are definitely not on the integrated unstretched image.
Attempt to create finished image:
Helpful Respectful Engaging
Did you export as 16-bit? Or is ACD photo studio (unfamiliar with this one) doing some sort of data conversion to reduce the precision to 16-bit on its own?
My bet is this is some sort of 32-bit to 16-bit gremlin.
What you should do is do all linear processing in Pixinsight, which means gradient removal, colour calibration and initial stretch. After you have stretched the data to a point where 32-bit is no longer necessary you can convert to 16-bit to further work on the stack with any software.
Jerry Gerber avatar
I exported as 16 bit, as I always do as my photo editing program doesn't read 32-bit files.
Strange thing is that I tried exporting a second time the 32-bit XISF file in PI to my photo editing software in 16-bit and the artifacts disappeared…
Weird..
Brian Puhl avatar
Enable 24 bit interpolation in pix.   Should fix it.
Jerry Gerber avatar
Brian Puhl:
Thanks Brian, I'll try that.  I've been processing images the same, or similar ways for a while now, I wonder what's different about this one, I've never seen this before.  I started over with the unstretched integrated image and repeated the same processes, only this time the artifact didn't show up..
Brian Puhl avatar
Jerry Gerber:
Brian Puhl:
This article explains why it happens pretty well for you.
https://pixinsight.com/tutorials/24-bit-stf/
Green banding issue in WBPP when using flats
Does anyone know what might be causing this green banding? I’ve never encountered this issue before, and it disappears when I exclude flats from WBPP. I have inspected my flats, and they seem normal. I’ve yet to try retaking the flats or do more test...
Green banding issue similar to unknown weirdness; both involve processing artifacts.
Feb 7, 2026
Help, strange artefacts in my images…
I just got a new camera (6200MM, use to have the 2600MM) and never noticed something like this before. It seems at the beginning of a session it starts to show this weird blob, and it gets worse as it gets cooler, if i turn the cooler off it gets bet...
New camera session artifacts may relate to processing issues encountered.
Aug 3, 2025
What could cause this bizarre diffraction spike effect?
I was doing some testing tonight to get a target framed(it’s too windy to actually image tonight), when I noticed in my test shots, that the brights star, Ain, has a very bizarre appearance, with multiple spikes coming off in many directions. I have ...
Diffraction spike effect is an artifact type similar to author's concern.
Dec 9, 2025
