Correct White balance for 585MC to avoid green tinge output
ciskjeOscar H.dkamenChris Sulyma - SeaWolf Astrophotographyandrea tasselli
28 replies687 views
Abhijit Juvekar avatar
I have been using ZWO ASI 585MC for a few DSO imaging sessions with various filters like UV/IR cut, Orion Skyglow, Optolong L-Pro etc.
While using filters I found the stacked images from DSS come out heavily Green tinge saturated.
Even when I try to manually adjust the Grey point using Photoshop for RGB alignment the star colors still have weird Red+Magenta tint.
What should be the issue?
I tried both RGB Alignment & Per channel alignment settings in DSS but issues remain for both options.
It becomes difficult for me to fix those star colors even in Siril as it does not recognize stars to do Photometric color correction.
Need help to fix the issue of White Balance or Green channel setting for the Camera itself instead of fixing it in post-processing.
This is how I get as DSS stacked output -
This is after manual Grey point curve adjustment on the above image
Please help...
Thanks
Oscar H. avatar
(deleted)
Oscar H. avatar
In siril, it's super easy to do color calibration.
What I do is I select a small box somewhere on the image where there is no DSOs or stars and I color calibrate the whole image using that one spot, then I do a background extraction, and I get perfectly flat image; it works every time.
@Aaron  ages? ages to you too sir!
@Aaron
I done as you mentioned.
Got this patchy background.
Star colors are also more like faint Magenta.
Oscar H. avatar
Well, I think you need flat calibration frames.
And about the magenta-ish star colors, I think that has to do with both, not having enough integration time, and not doing enough processing; it happens with me and I get stars that brownish or with no color, but I've never gone past one hour integration.
I suggest you decrease the brightness of the image to see more clearly the colors of your stars
dkamen avatar
Sensors record green at twice the intensity of other colours, when you stretch this small difference ends up in an absolute domination of green.
This is primarily corrected with background extraction/neutralization, color calibration on its own will also give a more neutral result but it will be unnatural.
Calibration subs should have no effect, unless DSS also does background neutralization alongside calibration (I think it does but calls it differently).
Oscar H. avatar
I was recommending flats to remove the donuts from his image (assuming they're removable), not fix any colors.
Aren't those donuts from sensor dust?
ciskje avatar
Use background extraction first!!!
You don't need any calibration frame on IMX585 (it's a new type of sensor).
NAG avatar
You "don't" need DARKS with the new sensors (although a still using them with mine QHY268 because of the hot pixels).
You defenly need flats flrames, no mether the sensor you use, especially if your sensor have dust spots, and not shooting in a very dark site.
ciskje avatar
It is much better to clean the sensor/lens than to use flats just for dust spots. It is a very long and tedious way to use the nights. And since dust can move around, doing 3minutes x 25 times flats each time can be really time consuming!
I would consider BIAS instead since the IMX585 has a high level of shot noise.
But to return to the issue at hand, the green is normal to be evident before erasing the background.
No, it's not, even if it this "cleaning" were practicable which isn't. Flats are taken either as dusk/down flats or using a flat panel and the time required in either cases is a tiny fraction of the actual exposures carried out through the session. Most importantly, flats needs taking to correct for PRNU as well as vignetting. Frankly, I'm not reallly even sure we are talking about the same thing here.
Bias signal shall not be confused and does not address "shot noise", which is intrinsic to actual process of capturing quantized data, such as photons. Bias correction only addresses the electronic bias error and relevant noise intinsic in powering the detector's electonics.
ciskje avatar
Cleaning is always a better idea (for a Refractor), and with a tiny sensor like a IMX585 vignetting is CLEARLY not a problem.
If you have a Newt IMX585 is not a good Idea.
Chris Sulyma - SeaWolf Astrophotography avatar
Agreed wholeheartedly. Even if I spend plenty of time carefully cleaning my sensor, scope lens, etc, etc, there will still be dust on -something- by night's end, especially living in an urban environment. I take my flats immediately after shooting to compensate for anything that has built up on the lens throughout the imaging session, and it makes a substantial difference in image quality during stacking and stretching.
Also agreed, here. I find a noticeable difference using darks when shooting in Bortle 8+ conditions. If the sensor doesn't benefit majorly from darks in ideal light conditions, that'll be great in the future (moving to Bortle 4 skies in August).
ciskje avatar
Maybe I'm very fortunate, I have cleaned sensor 2 times, and NEVER cleaned refractor (maybe with a Newt there is lot different experience), and I leave my telescope out the whole night (minimum 9 hours).
Dust on sensor with a closed refractor are nearly zero. (with a IMX585 I don't have to switch sensors).
But I don't live in a urban environment, in a bortle 4 sky near my house, and a 3 not so far away. smile
To be fair, the dust ends up on the scope lens, and not the sensor, since I'm shooting with refractors and SCTs. Might get a tiny bit of dust when I transfer from the Evostar 72ED to the C6, but I check for it before putting it on the scope.
I almost always have some dust/dirt on the scope lens by night's end, depending on wind conditions. Definitely an advantage for you living away from the city!
ciskje avatar
SCT with IMX585???????
Only for planetary/lunar, but yeah. Haven't noticed any issues with vignette or anything else.
dkamen avatar
Yes. I was not referring to your recommendation (with which I agree).
Well written Respectful
dkamen avatar
You don't need anything, doesn't mean it won't improve the result.
In this photo about half the subs are with darks while the other half are with bias. There was no noticeable difference. But that was at 0 degrees with a f/6 instrument, and a rich background.
Only two days ago I was doing M97 at f/12. Was like "why is it so noisy" (despite the darks), then realisedI had forgotten to switch on the TEC so temperature was 12 degrees. So darks taken at 0 degrees would not correct adequately, and neither would a master bias.
I too used to be of the opinion that you can do without calibration subs. There are cases that this is possible, but overall, I was wrong. Of course, they must be done correctly (which can be quite tricky, especially for flats). Otherwise, it is a very real possibility that they will harm the result. But when done correctly, they really do improve it. And it's not like you have to take them every time. In a closed system with controlled temperature, you can go months with the same master calibration subs.
Dimitris
Looks like discussion diverted from main topic.
Still not got the solution for removing Green tint from image capture process?
In Siril is subsky 1 to subtract the background
Rafael Amarins avatar
To anyone who says IMX585 doesn't need darks, these stacked images disagree with that statement
See the walking hot pixels? Yeah, not a bad idea to take your darks just in case. Both cooled down to -5c btw
https://www.astrobin.com/euoofc/
https://www.astrobin.com/hvotb1/
Helpful Concise Engaging
Furthermore, select Color Calibration from the menu on the left (Image Processing) and click on Background Neutralization and you are done.
See also:
Colors — Siril 1.2.0 documentation
ALWAYS READ THE HELP FILES!
ciskje avatar
Rafael Amarins:
These are not hot pixel, but stuck pixels.
Your camera have some serious problem, I have two IMX585 and A LOT of hot pixel but I haven't taken in the last one and a half years a dark, and don't have any problem such yours.  (Touptek and ZWO).
ciskje avatar
Abhijit Juvekar:
Use grafXpert.
UV/IR Block at F2
Hi, I shoot with an ASI533mc and have always used a UV/IR cut filter when taking RGB images to help with star bloat. Does anyone out there use a UV/IR cut filter along with a Hyperstar or RASA and if so could anyone please recommend a suitable filter...
Addresses UV/IR cut filter use with ZWO ASI camera for DSO imaging.
Sep 11, 2022
Diagnostic help, please
Hello, I have searched many sites looking for similarities regarding a worsening issue I have been fighting for some time. I hope that posting here and attaching some photos will help with the diagnosis. Essentially, my stacked light frames using the...
Diagnostic help post may address color/alignment issues in stacked astrophotography images.
Oct 19, 2025
