GTom avatar
I am upgrading my travel mount, with the following criteria:
- 8kg photography payload (105/735 refractor, reducer, heavy Moravian camera)
- can work at the Equator
- reasonable wind resistance
- reliable workhorse
- second hand, budget ~£800
So far I shortlisted 3 candidates. The HEQ5 is easy to get, currently see 4-5 offers in the UK, quite heavy though. It also needs to be tricked to work 10° latitudes that might compromise stability. The AZ-EQ5 reportedly doesn't like wind. The CEM26 is rare but I haven't found any cons. Being the lightest of the three it is very transport-friendly but stable enough to carry my heavier setup?
Helpful Concise Engaging
David Clayton avatar
I bought a used CEM26 and love it.  I use it with an Askar V scope system, ASI2600MC Pro, ASIAir+ and an Askar 30mm guide scope and ASI120MM guide camera.  Only issue was I had to adjust the worm gear on the EQ axis for backlash.  Customer Support helped me and it went well.  I live in the mountains of Colorado and therefore deal with cold temps in winter.  It has worked without fuss down into the singe digits F.  I like the iPolar camera for doing my PA.  When temps are in the 20s, I will take a 2 minute PA versus 10 minutes with the ASIAir.  Even using the iPolar, I get between 0.5 and 0.8 arc-seconds guiding.
Rafael Amarins avatar
CEM26 should be your best option but be aware that with 1"/pix you will discard lots of subs
I own a CEM25 which is very similar to CEM26 and it struggles to guide with no peaks of over 1.5 for longer than 2min
For some reason mine likes to carry weight and it guides better with 8,5kg than with 4,5kg of gear
I quit 3d balancing mine to perfection and again for some reason it guides better without the OCD level balancing. Still it is important to balance it since is very delicate and lightweight compared to EQ5
Ioptron Commander is very easy to use
GTom avatar
Thank you for the feedback!
There is a new guy in town, the AL55i. I was wondering where it stands. Seems stronger than the SA GTi, lightweight, meaning probably the same balancing and wind protection precautions needed as with the CME26.
Mount upgrade advice from HEQ5 Pro
I'm thinking about upgrading my mount (HEQ5 Pro - Rowan belt modded and I've tweaked the worm gears) to something that could maybe handle about twice the payload for AP. I currently have about 11KG payload on my current mount (Skywatcher 200P...
Directly compares equatorial mounts for similar payload and budget requirements.
Apr 29, 2022
HEQ5 Pro - Guiding with 11Kg payload?
Just looking for advice on what can be achieved on an HEQ5 Pro (belt modded) from a guiding point of view with an 8" Newt, camera, filter wheel etc. I'm getting 0.6 arc secs regularly now with an 11Kg payload in a suburban location. I'm ...
Discusses HEQ5 alternatives for similar payload and guiding performance needs.
Apr 23, 2022
Which equipment to buy with 15-30k budget for nebulaes / deepsky object photography
Hi, I want to gift a really nice next generation exuipment to my dad`s round birthday. While Astrography is new to me, as an engineer I am not hesitate to learn and contribute my part to that, hopefully common new hobby. My dad so far has done solely...
Discusses mount selection criteria including payload capacity for astrophotography equipment.
Aug 30, 2022
