I have tried several routes processing 17h of integration time, but never end up with a satisfying result, as the image below shows:
the fine details in the galaxy arms are always coarse and somewhat bloated. I tried reducing denoising to a minimum without effect.
As I have had that with most of my galaxy images I wondered whether I have a flaw in my process or setup.
What could I do better?
Setup:
- EdgeHD 11, well collimated
- Asi2600mm pro camera at -10 degree cooling
- EAF for focus and EFW 7x2“ with Zwo RGB and Ha filters
- AsiAir plus controlling the setup
- 200 images of 180s and 300s in RGB and Ha
- bortle 4 sky at 2-4 degree celcius
- excellent guiding of 0.2-0.3“ on my AM5
- good automatic focus usinf EAF with fwmh of 1,31“
- raw images look ok, even though not too strong of an SNR from what I can tell visually …
Process in Pixinsight
- thorough deleting of suboptimal frames before stacking
- WPBB stacking with 100% images being processed
- Autohistogram on to red channel for RGB subframes
- continuum extraction in Ha channel (Toolbox Script)
- Channel Combi RGB
- Graxpert gradient reduction for RGB and Ha
- BlurxTerminator for RGB and Ha
- NoisexTerminator for RGB and Ha
- StarsXTerminator for RGB and Ha
- LRGB Combi of Ha into RGB
up to here everything looks fine, the issue start during stretching when trying to eliminate background brightness
- GHS stretching of starless and stars RGBHa
- Curves adaption increasing color contrast and making the image pop
- screen blend re-integration of stars
Here some revisions of the image representing several processing alternations, where I changed
- the order of when to integrate Ha (early vs late)
- stretching simpler with autohistogram
- integrating Ha only towards final end of process
https://www.astrobin.com/wrouwh/
Any ideas or recommendations of there the cause might be in the process or where I need to look in the raw images?
Especially @Gary Imm never seems to run into these problems even taking shorter exposures in a similar bortle 4.5 sky … :-)
Arny
Setup:
- Channel Combi RGB
Arny
