Fast newtonians for remote setup
Fast Newtonians 2 replies182 views
Emilio Frangella avatar
I will be installing 3 fast newtonians (two 10", one F3.4 and one F3.8, and a 6" F3) remotely in the next months. All three require fixing collimation from time to time (maybe not so often in a fully remote setup as currently i need to uncover/cover them every time i use them which introduces unwanted vibrations). I was wondering if there is an easy way to check and fix collimation without removing the camera every time (which requires taking new flats). What i mean is if there is a way i can remotely "guide" an operator telling how to fix collimation without the need for him to remove the imaging train. I do something very similar with my RC using the skywave wavefront analyzer.
Star tests arent a reliable solution as there is always an offset to consider and the offset is different for every scope (also you cant adjust the secondary)
Aris Pope avatar
I think N.I.N.A. has a plug-in for that.
Frédéric Ruciak avatar
hi look at innovations foresight skywave collimation. It's a software based on wavefront analysis based on a defocus star that will tell you if it is collimated and what is the wavefront error. An AI based start test.
hope this helps, Frédéric
