Are dedicated osc astro cams more sensitive?
Björn ArnoldCfeastsideandrea tasselliScott BadgerTom Marsala
39 replies1.3k views
Cfeastside avatar
…than my unmodified canon 6d dslr to ha?   I know going with a cooled osc is significantly less noisey.  Im still pretty new to imaging and feel going mono would add a whole lot more complexity from data acquisition and processing.  I just started guiding and dont even have a electronic focuser yet! Lol!
Anyways im toying with getting a asi294 mc pro to pair with my wo gt81 so i can start shooting nebulas    My backyard is bortle 4 and i have pretty easy access to bortle 1-3.
thanks for any advice!
Björn Arnold avatar
EDIT: After writing a lot and reading your question a second time, I noticed your DSLR is *not* astromodified. Long story short: a OSC astro camera is more sensitive in Ha (reason see below).
I haven't done a quantitative comparison for DSLR and dedicated OSC CMOS cameras for astro imaging but I'd say: the sensors have the same sensitivity. Of course you'll find differences within DSLRs and within astro cameras, so you could compare the worst DSLR with the best OSC cam but I guess that's not your question. I'm not aware that CMOS sensors are developed with dedication for astro cameras. I checked a few astro cameras and I always found the sensors being used in industrial or consumer applications. In fact, the fact that CMOS cameras are everywhere made them being the now standard for astro cameras. CCDs will be phased out as some companies will stop or have stopped production. Although from a technological point of view, w.r.t to astrophotography, I'd say a CCD is preferable.
I assume you are aware that the astromod of a DSLR is simply due to the fact that they contain an IR cut filter for daylight photography, where nobody cares about only 6% of sensitivity at the Ha line. Another difference is the cooling. DSLRs have the environment temperature or a bit above, depending on much the internal electronics heats the sensor. Therefore, the control of thermal noise isn't there. For dedicated cooled astrocameras the noise level is lowered through cooling and kept at constant values which allows easier image calibration and noise reduction.
In my opinion, switching to mono makes sense once you decide to shoot narrowband. Before you do a mod of your DSLR, go for a dedicated OSC.
CS!
Björn
Arun H avatar
Bjorn makes a lot of good points; your 6D's IR cut filter will cut out about 75% of the H-alpha light. That doesn't matter so much for galaxies, but does matter for emission nebulae.
The sensors used in the 2600 MM/MC and 294 MM/MC are basically the same as would be found in modern mirrorless or industrial cameras. The astro photography market is small, so no one is going to make a sensor specifically for us. However, the sensors used in modern astro cams like the 294 and especially the 2600 are significantly better than that of your 6D simply because they are a couple generations newer. They have lower read noise, higher dynamic range, and higher quantum efficiency than your 6D.
Aside from that, the advantage of the astro cam is cooling, which reduced dark current and dark current noise. What it also does is ensures consistent image calibration (dark frame subtraction) due to the fact that temperature of the sensor is kept constant.
If you're just starting out, I'd suggest going with what you have. I spent over a year working with an unmodified 7D Mark II before migrating to an astro cam. There is a lot you can do and a lot you can learn with what you have before spending more money. Some of my earlier images are examples of what an unmodified DSLR can do.
Cfeastside avatar
Thanks for the detailed response!   I guess im wondering if the cost to benefit works out with getting a dedicated osc vs the unmodded dslr in terms of ha sensitivity since they both have similar filters over the sensor to inable that rgb color spectrum.
a tantalizing feature of mono as i was thinking about it more this morning is i could be collecting data now with the almost full moon out. At least that is my understanding.   A lot to be said for that!
Björn Arnold avatar
Mono and color cameras use the very same sensor. The only difference is that the color sensor is the mono sensor + a so-called Bayer-Matrix (i.e., tiny filters in front of each pixel to determine the wavelength to pass through, creating "red", "green" and "blue" pixels). What the DSLR manufacturers usually do is to add an IR-cutfilter which blocks all wavelengths above a certain "cut-off" wavelength. Unfortunately this filter already blocks light in the Ha, SII range of the electro-magnetic spectrum and hence the sensitivity is further reduced.
If you want to shoot under full moon, just do it. You can take a look at some of my images and check the moon phase. Quite often, they were shot under heavy moon light. I'm certainly not the best photographer but I'm inclined to say that full moon doesn't mean that the result must be garbage. What you should do is to select a target far away from the moon (angular wise of course :angelsmile
The alternative is to shoot with narrowband filters. They only let a very narrow range in the em spectrum pass (order of 10nm and lower) and therefore block most of the broadband spectrum of the sun-/moonlight. If you shoot narrowband, you should use a monochrome camera as otherwise usually 3/4 or 1/2 of the pixels are inactive as they won't receive any light.
But as Arun has said, there's so many things that you can do with you current DSLR which you should give a try. With the experience that you'll gather on this path, you can make a more informed and confident decision for your next upgrade.
CS!
Björn
PS: Even the best camera won't help if your weather is like the one we've got here in Germany for the last 5 months. Your best purchase might be a radio dish for radio astronomy.
John Hayes avatar
You’ve received some good answers here so only I’ll add a few comments.  First, if you want to stick with a DSLR, the best thing you can do is to have the camera modified.  The difference in sensitivity to signals in the red, including Ha, is significant.  Going from an unmodified to a modified DSLR makes a very significant difference in the results you can achieve.
Having said that, a DSLR is not well suited to narrow band imaging for one big reason.  The Baeyer filter that sits on top of the sensor only allows the light passed by the NB filter to pass through to only one out of four pixels.  With a mono camera, every pixel produces signal.
Like Arun, I started with an unmodified 7D and then quickly moved to a modified 6D and that camera was fantastic.  Then I moved to a FLI-ML16803 mono sensor and that produced another leap in capability.  High quality mono cameras with relatively large sensors are priced in the same range as a DSLR so it’s a lot less expensive to make the leap but you still have to buy filters and a FW so it’s more pricy to get into mono imaging.  If you aren’t sure about how far you want to go with it, my advice is to get a modified DSLR and stick with RGB.  Get that process dialed in and you’ll learn pretty much everything you need to know to make the jump to mono down the road.
Doug Summers avatar
Taking nothing away from the dialog above, I'll comment on your access to Bortle 1-3.   If your backyard is B-4, and you have easy access to better, then I would definitely recommend an OSC.   You said "Im still pretty new to imaging and feel going mono would add a whole lot more complexity from data acquisition and processing", and this is definitely true.   You can get *very* nice results from an OSC in low Bortle conditions.
Where OSC begins to fall apart (rapidly) is in high bortle.   Bortle 4 is borderline.     Processing is *much* easier with an OSC, and the rewards more gratifying (quickly).   For an example, see my page at (users/dmsummers).    I'm not taking anything away from the appeal of narrowband imaging, but if you're happy to learn the ropes doing RGB broadband, then you might want to consider that OSC if for no other reason simplicity.   I doubt you'd be disappointed, especially if you get to those low Bortle skies often.    CS  Doug
Doug Summers:
It is not. I routinely shoot under Bortle 6/7 skies and feel none of the limitation you suggest. Just add a decent LP filter and off you go...
Cfeastside avatar
Thanks for all the great advice!   Not really planning on modding my 6d as i also use it for landscape photography. Plus id rather put that money towards dedicated astro cam.  I have read up on this a bit about the osc vs mono cams, ie online , The Deep Sky Imaging Primer, etc.  and my take away seemes to be osc cams have reduced sensitivity to narrow band wave lengths but if you,re in dark skies you can kinda make up for that by exposing longer.  Also some references online have certain nebulas that are more osc/unmodded dslr friendly but that list seemed short.
Last winter i tried shooting a few frames of the rosette nebula and came away with nothing.  It wasnt a serious attempt and i wasnt guiding yet then so my exposures were probably way to short, likely less than a minute.   So i havent tried yet with my guiding setup.  Hoping to next week at my bortle 1 location on the lagoon nebula just to see what i can get.
i really appreciate everyones comments!
Respectful Supportive
Björn Arnold avatar
Then I would recommend going for an OSC. It will show you the Ha regions with much more ease than your DSLR. If you gear up one day with a mono, you‘ll have the option to use the OSC to capture the RGB data and the mono to capture additional data (Luminance and/or narrowband).
Morian avatar
You could also use your 6D for RGB and combine with mono ccd with luminas or narrowband, it is best with a sensor so close to 6D, so a FF or close on it. I Have my self thinking of this combination as a project at some point.
morian
dkamen avatar
In my opinion the extra sensitivity in Ha is overrated. Certain cameras cut all of it but many others, your Canon 6D included, don't. It is practically the same as an OSC astrocam.
Now, to answer whether it's worth the money, the pros are:
- Ergonomics: It is designed to connect to a telescope, it is lighter, smaller, sensor is accessible to clean. You can simply swap the IR cut filter with an IR pass if you want to image in near IR and then put the original filter back, it is not a $200 modification.
- Flexibility when controlling the sensor: change gain, offset, binning, bit depth, region of interest at a whim.
- More accurate calibration and less noisy long exposures to begin with (if cooled)
- Truly raw image to work with: no star eaters, no in-camera preprocessing. Although this is not really an issue with Canons.
And the cons are:
- Probably less capable/lower quality sensor than the DSLR
- Needs a computer
- Needs a power source (if cooled)
Extra sensitivity in red is not really a factor, especially for giant bright nebulae such as the Lagoon or Rosette. If you do not see red with the Rosette, chances are you need to look at your post processing or increase integration time, either way I doubt it is a matter of 30% less sensitivity in red or so.
Narrowband imaging of faint emission targets is something else and you need a mono camera, filters and quite long exposure times for that.
Dimitris
Scott Badger avatar
I’m also looking at my own camera next step and am considering an astro camera (probably mono) or maybe first modifying a dslr i have now. My question, is a a modified dslr no longer workable as a regular (i.e. landscape/wildlife) camera?  I’m using a 5d iv and would like to continue using it for both but i also have a 7d in the closet that i could modify instead.
Scott
Arun H avatar
I will disagree a little bit here. Canon cameras specifically will cut out about 75% of the H-alpha wavelength, letting in 25%. That certainly was the case with my 5D Mark IV. This difference matters. If you take an image of the Eagle nebula or even the Horsehead, an astromodded DSLR or a dedicated astro OSC will capture a great deal more of the H-alpha detail. So too, if you take an image of the Ophiuchus region. The red is really hard to get with an unmodded DSLR which only lets in 25% of the H-alpha light.
Cfeastside avatar
and this speaks to my main concern, if the osc dedicated astro cam is only marginally more sensitive to Ha vs unmoded 6d then in just those terms it probably isn't worth purchasing the osc cam.  but if considering much improved noise performance of osc then ya, if you have lots of funds available it is a good choice.  i wish the manuf would publish that specification of Ha sensitivity for their osc.
Björn Arnold avatar
For the OSCs the data is usually available. Check the website of ZWO for example. You‘ll find the peak quantum efficiency and also the relative response for each channel as a function of the wavelength.
For DSLRs it seems more difficult but some web research should give you some information, e.g.
ResearchGate.
For this specific DSLR in the article the Ha sensitivity is roughly 5%.
Compare this to the relative response provided for the 294MC.
Roughly speaking, the DSLR is „blind“ to Ha if compared to the OSC.
Yet, one can still collect data, e.g. my horse head was captured with an unmodded EOS250D. It’s more difficult but still possible. An OSC would do that with ease.
NGC2024, Flame Nebula and Horse Head Nebula
Björn
Tom Marsala avatar
Agree with you all, here.  I have used the 6D exclusively umodded, and now modded.  The Ha sensitivity was not too bad before I modded it, but the difference now after modification is enormous.  By the way, the SII spectrum is pretty much obliterated on the stock 6D, but wide open now on the mod.  With the OSC's you get less noise if they are TEC cooled, but there are ways around the noise with the uncooled 6D; you just have to get creative!
Björn Arnold avatar
Tom Marsala:
Nowadays CMOS sensors have very low thermal noise even up to room temperature compared to older sensors or to CCD sensors.
I recommend people trying to find the thermal noise data of their sensors before they cool it to -15 deg C. The major advantage of TEC cooling is the constant sensor temperature which makes generating dark frames much easier.
To talk about some numbers: the IMX183 sensor in my camera has about 0.01 electrons/second of dark current at around 10C. That means to get in the order of read out noise, I need to expose for more than 300 seconds.
Roger Nichol avatar
I can't speak for the 6D, but my experience of attempting the North America Nebula with my unmodified Sony A7Riv vs an ASI2600MC was that 4.5 hours on the Sony gave me much less Ha than a single 10 minute sub with the ASI2600MC - there is just no comparison.
Tom Marsala avatar
Agreed,  Roger.  In a similar way, I got more color data on a 10 second sub of the Ring Nebula with the modified 6D than I did with a 3-hr integration when it was unmodified! Pretty crazy!
Well Written Insightful Respectful Concise Engaging
dkamen avatar
Björn Arnold:
ResearchGate.
Björn
Hi Bjorn,
The figure in your link is for the 5D not the 6D. The 6D was released in 2012. The 5D is a 2005 camera and has much bigger problems than its spectral reaponse.
dkamen avatar
Like I said in my original message there is a difference between using a sensor without the relatively restrictive IR cut window normally integrated in every general purpose camera and using a sensor with a Ha filter which is the recommended way to image Ha targets. You do get a lot of red when the sensor is without the filter but it is not just Ha, it is the entire spectrum of red things above 600nm or so (where the stock window starts cutting) plus a great deal of near infrared.
Will things look spectacularly redder? Absolutely.
Will that be Ha detail? Extremely doubtful.
Ha is but a tiny line, less than a percent of the extra red that you are now more sensitive to. The stuff that is 1nm to the right of Ha in the spectrum for instance and the stuff 1 nm to the right of that and pretty much everything else all the way up to 700nm? It is guaranteed that the camera's sensitivity to those increased more than it did to Ha. And they all look red.
I have taken two pictures of the Lagoon. One is with a stock DSLR:
https://www.astrobin.com/413954/?nc=user
The other is 4 hours of OSC to which I added 4 hours of L with a mono sensor. Both cameras have better response to red than the D7500 because the ZWO IR filters cut at 700nm, almost 50nm above the Ha line. 4 times better in the mono sensor's case.
https://www.astrobin.com/9y4s1j/?nc=user
Ignore the fact that the detail is better (different scopes,  different integration times, guiding). The thing is the clear separation between the blueish core of the Lagoon and the pink periphery which was captured perfectly by the stock DSLR, is almost completely gone in the second picture where all colours are shifted towards red and that was after very painful post processing to make the parts that are supposed to be blue appear at least a little purple. I was actually quite disappointed at the second picture from a chromatic point of view.
if you remove the effect of the IR cut window then the difference between OSC and DSLR is a matter of chance, because OSC astrocam sensors do not have any magic properties. They are the same sensors that you see in mobile phones, security cameras, action cams and of course DSLR and mirrorless general purpose cameras. For example Sony A7 R IV and ZWO ASI 6200MC use the same sensor (IMX455) and so do ASI 2600MC and Pentax K-3 mark III (IMX 571).
Assuming the sensors have similar tech (i.e. are not separated by a decade) it is the window and only the window that has a serious impact on spectral response. And there is a good reason stock DSLRs have that window, namely it makes it easier to obtain a natural (to the human eye) color balance.
Dimitris
Helpful Insightful
Björn Arnold avatar
It was just to illustrate an example. I knew it wasn't the camera that was in question. Certainly to be exact, one needs to research the 6D or my EOS250D. I once found the data for the EOS250D but once I had checked it, I didn't save the data. However, I'm not expecting a change in an order of magnitude.
Nevertheless, DSLRs (in unmodded form) are designed to record the light in such a way that a true color representation for the human eye will be done. Btw.: Our eyes' response in Ha is about 5-10% compared to around 560nm where our "red" response is largest.
Mike Mulcahy avatar
Scott Badger:
You can use your modified DSLR for landscape by using a custom white balance.  This is done by shooting a white or gray card in even sunlight and saving the white balance as custom.  It works very well.
Well Written Concise
Scott Badger avatar
Thanks Mike! If I go the modded route, i’d like to continue using the 5d for both. Of course, not sure I can remember the last time it was attached to the back of a lens.....
cheers,
Scott
ASI 533MC vs ASI 533MM, what compromises for broadband ?
Im starting this as a question im still asking myself, I have both experience with OSC and Mono cameras (all high end) and I am fully aware that going mono will always yield the better results but I am also aware of how good OSC cameras are especiall...
Directly addresses OSC vs mono camera decision author is actively considering.
Apr 19, 2023
