I am planning to upgrade from an EQ6-R Pro to either an Astro-Physics: Mach2GTO or 1100GTO
The Mach2GTO would end up costing less considering the portable pier I would be able to use. I haven’t found a portable pier for the 1100GTO outside of the Advanced Telescope Systems 8” which costs $2,795 plus shipping.
That being said, my preference is leaning toward the 1100GTO. It has the portability factor which is very important to me. I know that you can remove 4 screws from the base of the Mach2GTO, which weighs 11lbs, dropping the weigh down to a manageable 31lbs.
1. My biggest concern is guiding. I know that the absolute encoders on the Mach2GTO work very well. My hope is that the 1100GTO without encoders will effectively be almost as good.
2. Can either mount be polar aligned with N.I.N.A.? That is what I currently use.
3. Currently I have 2 telescopes. A William Optics FLT 132 and a ZenithStar 61II. The Mach2GTO would handle both without any issues. The cost of this upgrade would limit the purchase of a third telescope for a while. So even that the 1100GTO has a much higher weight capacity, it isn’t a concern, but I wouldn’t want to limit myself.
I’m currently on Astro-Physics waiting list.
