Stock Focuser
Takahashi Refractors 10 replies295 views
Matthew Proulx avatar
I just purchased a TSA-120 and I was wondering what peoples thoughts are on using the stock focuser with a motor or does a premium-ish refractor really need a new focuser?
Tim Hutchison avatar
I've been using the stock focuser on my TOA-130 with an Optec FocusLynx focus motor attached for a year now. I have absolutely NO trouble with it. Works just great!
Tim
Well written
Miroslav Kalinaj avatar
Hi Matt,
I'm using my TSA120 with ZWO EAF focuser connected to scope with a special Takahashi mounting kit you can buy at ZWO as an optional. I have no problems at all with that setup so I recently purchased the same focuser for my Tak FS60Q scope too and it works smoothly at that scope as well.
Clear skies,
Miroslav
Miroslav Kalinaj:
Hi Matt,
Clear skies,
Miroslav
I do have this motor and I have that kit coming in the mail. I guess I should try it before I go spend a few K, but its nice to hear what other people with experience are doing.
Brice Blanc avatar
Hello Matt, I'm also using ZWO EAF with a TSA 102. I made the mounting part myself since I couldn't find no kit. Works great too, and I'm now able to refocus every 1°C of temperature change and get a very good focus. Taka focusers are really serious, I don't think there's any need for replacement. EAF is a really well made and cool device too (I found the temperature sensor very convenient). Hope this will help in making a decision. Take care and clear skies ! Brice
Andy Harrell avatar
I swapped TSA-120 stock focuser out for a Starlight Instruments focuser and Posi drive motor.  The stock one was slipping too much with my camera and filter wheel on there with the focal reducer.  I had a motor but it wasn't holding it up.
It would be the motors job to hold  the focuser up since the tak is a geared rack and pinion not a friction like a lot of focusers. If I find my eaf doesn’t work, I will likely add that new starlight posi drive motor to the stock focuser also and it has a 56lb capacity.
Maciej avatar
I am using my Tak's ( FSQ 106 and FS-128 ) with FLI focusers ( PDF and Atlas).
While with FSQ 106 it is simply a convenience and not a necessity, the FS 128 focuser is not very suitable for astrophotography . Despite many hours of efforts I couldn't get its bearings stable and the whole focuser drawtube sways under the load of the camera. And here the use of FLI PDF is fully justified.
CS Maciej
TakFan avatar
I'm using the TSA120 with ZWO EAF focuser connected to scope with a ZWO monting kit. Load: 2600MM Pro + large 7x EFW + Reducer. No issues.
Best regards,
Dirk
Vin avatar
An old thread, but just adding in case of use for anyone else.  With an old FSQ106N I have put a Pegasus motor focuser - had to get the backlash dialled in as had only used belt-based autofocusers before with other scopes, but once that's done its excellent.
Victor avatar
Hello all
Victor Beer from Tucson Arizona. Using a Tak. FSQ-106, Asiair , ZWO focuser , 2 inch filter wheel and shoot mainly with the Lpro and Antlia gold filters.
I have been using the zwo EAFi and getting very nice tight stars and excellent focus.
I adjusted the slow adjustment in the focus section of the ASiAir to 10 to get a more accurate focus .
Regards,
Vic
PS You can't beat the price and the mounting was easy.
Which scope for galaxy imaging? 8" f/4 Newton, RC8, or 5" Triplet?
Hi everyone, long post incoming - excuse my ramblings - after I finally moved to a place with a secluded and safe roof terrace where I have enough space to put up two rigs, I'll plan to add another rig for smaller Targets next to my CEM25P with a...
Discusses refractor selection and imaging; may address focuser considerations for similar scopes.
Apr 23, 2023
Best Mount for Esprit 100 and ASAIR +
Dear Astrophotographers, I am studying, learning and getting ready to make my purchases. I am a beginner (not in photography or post processing but in astrophotography). I am studying the book The Deep Sky Imaging Primer (3rd edition) by Charles Brac...
Discusses refractor equipment setup; mount selection may relate to focuser compatibility concerns.
Oct 14, 2022
