Hello AB community.
I have been trying to figure out what is going on with my 135mm setup. I'm not sure if this is internal reflections, light leakage, or something else. The imaging train consists of : A ZWO 2600MC pro - ZWO filter drawer to lens adaptor - Rokinon 135mm lens. I have attempted to find any place light could be leaking in from with nothing that I could see. The lens adapter to lens does have a slight amount of play in it. I have also removed the camera and places the rest of the train on a light panel to see if I can find any reflections, and there does not seem to be any. I'm running a dew strap at the point where to hood meets the lens if this matter for leakage issues. I am running at F2.8 no filters in Bottle 4.5 ~. Calibrating with flats and flat darks. Current light exposure time is 180 sec. I have tried to search the internet for anything and haven't found too much to help. I can't really find any examples of this at all. This has not happened in every single situation, but most since I started using this in about October. Find below some sample image... please bear with the "ugly" images as they are meant to show the problem and have had minimal steps done. Number 1,2,3 have all been taken with about a 25% moon but many degrees away with about 50 mins each on each image, and the last image is a short 20 mins, but no moon was present.
Initially, I thought it might be my filter (Baader Neodymium Moon & Skyglow 2") or my adapter. However, I obtained the same result with and without the filter. I even tried using another Optolong L-Quad Quadband filter and borrowed an SVBony Duo-Band OSC from a colleague, but the result remained unchanged. I also considered the possibility of flat frames; I stacked images with flat frames (using panel, sky, and manual) and without flat frames, but unfortunately, the result was the same.After reading various posts and responses from other colleagues, I realized that lenses for DSLRs struggle to capture optimal photos at F8 or lower in Bortle 7 conditions. I conducted various tests with many exposure (i.e., 30, 60, 120, 180, 240, 300) in different scenarios with both full moon and new moon phases. Another issue I encountered was that, currently, I can only capture photos from my balcony starting at 40 degrees elevation. To test this theory, I took a comparison shot at F11 versus F8 (both at ISO 800, 40 degrees elevation, 300mm focal length, without filters, and without calibration), and this resolved the issue. I experimented with different focal lengths (70, 100, 135, 200, 250, 300), and F11 consistently produced optimal results.
On another hand, I had around 2 hours of data with this issue, but yesterday Pixinsight released a new version with gradient correction, as neither DBE or GrapXert could resolve the aggressive gradient and donuts. After conducting various tests with my data, this issue was resolved using this new feature.
