Not enough alignment stars error
7 replies290 views
Abhijit Juvekar avatar
How you stack frames with less stars to register in alignment process?
I used DSS for such tiny FOV it throws error not enough stars for alignment and discard all frames only stacks 1.
Solution for that problem?
Particularly when using small exposures there aren't any bright stars in frame.
and when FOV is too narrow for targets like galaxies or planetary nebulae.
Use Siril. You'd still need at least 1 star bright enough to register in all the frames. And no rotation between frames nor change of image scale.
Adel Kildeev avatar
Totally agreed: Siril is a head over DSS. I DSS you may try to play with options and change per centage of stars needed, but be carefull -if you go to far-stupid DSS may find 10000000000000 stars, mistakenly using pixels ibstead real stars and the process nay take few hours or never end…. Outdated program, switch to Siril -much better option
Kevin Proctor avatar
Drop the star detection down as far as you can. I think it’s 2 percent. I used to have this same problem. Usually when I bring it down to its lowest setting it would stack all the frames. Unless focus is really bad or trailing is really bad.
Rob avatar
You can also adjust the brightness of your raw/fits to 'bring out' more stars if they're there, just too dim to detect.  I had to do this recently when doing lucky imaging with my planetary camera.
Rob:
Thanks will Try this next time
Herbert W Hamber avatar
What he says …
Lower the star detection threshold (minimum is 2%) so DSS can detect more stars. Around 100 stars is a good number.
Also, if that does not work, increase star brightness in the RAW/FITS settings to 3 or 4.
I have used DSS for many years and it works very well, just experiment with the parameters.
Later I use Siril for other tasks, like extracting and compositing.
Thanks for all the Useful replies.
How to stack images with very few stars?
Hi, I use DSS for stacking. Sometimes while using short exposures, particularly for imaging Planetary nebulae I find the DSS don't register more than 2 stars and hence don't stack more than 1 frame despite having the lowest star detection 2% ...
Directly addresses DSS alignment issues with insufficient stars for registration.
May 21, 2022
ONTC Tube Foam Sandwich Compression and Solution
I’ve been using a 10” TS Optics ONTC Newtonian as my primary imaging scope for a few years now. Overall it’s a great scope and I’ve been very pleased with its performance. It is, however, not without some issues. One issue which has plagued me from d...
Not relevant to frame alignment or stacking issues.
Oct 22, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Not relevant to alignment registration or star detection problems.
Nov 18, 2025
HyperStar and FLATs
Hi everyone, I’m looking for your experience with using HyperStar. How do you handle flat frames when imaging with HyperStar? have you noticed any particular challenges, i wonder how reliable a setup can be with flexible cables in front of the mirror...
Not relevant to alignment registration or insufficient stars for stacking.
Feb 13, 2026
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
Not relevant to DSS alignment or star detection in narrow FOV.
Sep 28, 2025
