Looking for a good windscreen solution
3 replies120 views
Photon_Collector avatar
Hi all,
I just moved to an ocean-side site that has beautiful views but also comes with quite a bit of wind.
It is still an apartment so I would have to be able to set up/break down pretty much every night. Is there a windscreen/guard that you could recommend or if you think its better to DIY, how did you build yours?
I have a small refractor right now but would love to buy a big Newtonian or a RASA, which I know will be worthless as they'll act like big wind sails if I don't protect them.
Thanks for any help!
Brian Schumacher avatar
When we visit our winter home, I use a 10x10 dog kennel with privacy slats. It has a few advantages: it's lockable, and most people can't see the equipment very well. I purchased it secondhand for $100. With my C-8 telescope and an EQ6-R mount, a 7-mph wind is the maximum limit."
It is however a bit to move around so it may not work for you, but they do come in a verity of sizes.
Bob Lockwood avatar
I would be very cautious setting up a wind block unless you are absolutely sure it's anchored down extremely well. The last thing you want is having
the wind block coming loose and on your equipment. As stated above, a 7-mph wind is nothing, and you probably see that all the time. Can you just
setup on the opposite side of your apartment and use it as a wind block.
In my place a 7 mph wind wouldn't be consider more than a gentle breeze so it won't affect imagining even with the 12" (5' long newt) let alone the 6" or the 8". Up to 11 mph you can still image with the 8" f/4 or the 6" f/4 and beyond that up to 14 mph only with the 6" f/4. If it blows harder you use only the 300mm lens.
Concise
Looking for a suitable telescope for a mobile setup
Hi! So, I have a spare EQ-5 pro mount, which I used the past year in my backyard observatory, however, I got an upgrade and I thought I should make a mobile, smaller setup around the mount. I have everything, except a telescope. I have a newton in th...
Discusses mobile telescope setup considerations relevant to portable windscreen needs.
Jan 20, 2026
Celestron edge hd 9.25 is Perth, Australia too windy for it?
Hi guys. I've started taking interest in some small galaxies etc and i’m pushing the limit of my 683 focal length. I’m looking to get a celestron edge hd 9.25 but wanting to know from real life experience if it’s going to be a waste of money for me. ...
Addresses wind challenges with larger telescopes in exposed locations.
Nov 26, 2025
