Nikon 180mm ED AIS vs Nikon 300mm ED f/4.5 version
2 replies•90 views
John W Colby avatar
Hello,
I'm new to astrophotography and I'm looking to purchase a lens. I've narrowed it down to the Nikon 180mm ED AIS f/2.8 and the Nikon 300mm ED f/4.5 AIS. Has anyone had experiences with these lenses? I'm also open to suggestions on lenses up to the $300.00 range. I'm on a tight budget, so I can't afford the nice gear. My camera is a Nikon d7000, but I will soon be getting an astromodded Canon 60d. My mount is a celestron slt that I put on a wedge. I'm able to do 60 sec subs with a telephoto lens at f5.6. Any advice would be appreciated. Thank you.
I've tried both and own the AF version of the 180mm. The 180mm is a very nice flat lens with minimal aberrations but some lateral chromatic aberration and just little axial chromatic aberration when used wide open. The subsequent AF version is just a little better with regard to that but otherwise about the same. The 300mm f/4.5 was a fine lens in its heydays but now shows its age. My sample was well corrected (all this tested with APS-C sensor) across the field but with significant lateral chromatic aberration and visible chroma shifting (not corrected well in the NIR). Some astigmatism and more than a hint of spherical wide open. Field-correction-wise I found the 300mm f/4.5 Olympus OM a better contender. Obviously that won't work on a Nikon but would work on a Canon. If you plan to stick with Nikon lens then your best bet is an astro-modded D7500, way better than a 60D.
Helpful Insightful Respectful
John W Colby avatar
Thank you for the feedback
What lens for DSOs?
Hello, I'm new to astrophotography. I have a question. I decided to use Nikon d3200 for Deep space like nebula. I found this telephoto lens to be good for my budget Nikkor 55-200mm f/4 vr. There is one same but with 70-300mm and f/4.5. Is there s...
Compares telephoto lens options for astrophotography, directly relevant to lens selection.
Jun 7, 2019
Advice for Newcomer
Hi! I'm fairly new to the astronomy and astrophotography game. I am looking to purchase a new telescope as I want to begin deep sky photography, but I'm a little intimated and over stimulated by all the options and I don't want to make a ...
Relevant for beginner astrophotography gear advice and equipment recommendations.
Feb 9, 2023
Ritchey Chretien vs Edge HD
Hello everyone, Please share your opinion. I'm looking to buy a scope or scopes to add wide field imaging and also long FL imaging for galaxies. I currently use an 8"f/6 newt with a Canon M50 mirrorless, which I'm very happy with. For th...
Discusses lens selection for astrophotography; relevant to wide-field imaging equipment considerations.
Feb 20, 2020
