Newtonian problem with spikes
13 replies723 views
Astroneck avatar
Hello. If you see my last image of M101(link below) you can see spikes in the small stars. This spikes are diferent (I Think) that the  typical spider spikes of all newtonians in big stars.
https://www.astrobin.com/4m79f2/B/?nc=user
I don't know what cause this rare spikes. If you zoom in, you can see this problem in all my astroimages with dslr and now with my new qhy294mpro.
I image some small deep sky objects with a televue powermate 2x2" combine with mpccIII... And I don't see it, the small stars looks better.
Maybe the mpccIII coma corrector is the problem? optolong Lpro filter? Bad Collimation?
Can somebody help me?
Thanks. Clear skies!
And sorry for my English ;)
John Hayes avatar
Your English is fine!
At first I expected to see a problem cause by the micro-lens array on the sensor but that's not it.  I can see clear evidence of vibration in your system that's causing double imaging.  It could be caused by wind gusts or a bi-modal guiding error, but that seems less likely.  Check that everything is rock solid tight and then tap your system to see how much it rings.  It should have rapid damping (<1 sec) and a high resonance frequency (>5-10 Hz.)
That's not to say that you don't have problems with your coma corrector as well.  You do.  I see pretty significant coma in the edges, which probably indicates a spacing error somewhere.
Astroneck:
Having looked at your image I think your problem is bad collimation (it's way out). So your extra spikes comes from that, comatic PSF right through the center.
Concise
CCDMike avatar
Doublespikes are often caused by focussing or tilt. Especially when just one spike is double (which seems to be the case on your image) this is due to slightly tilt in the image train and/or sensor.
BTW: I would suggest you should study the use of an aperture ring, which makes your stars rounder, too (but this has nothing to to with your question)smile
Mike
Paul Ecclestone-Brown avatar
I am having the same issue with my photon 200 F4 - my research is pointing at the focuser tube sticking into the telescope and causing diffraction and the clips on the primary mirror.  I have just had a set of aperture rings made will post the results of that soon when the clouds go
If your German is good  Tommy Nawratil's collimation primer has been really useful for me
https://teleskop-austria.at/information/pdf/FN25010c_Photonewton_Justage_Primer.pdf
Julian Mochayedi avatar
Hi Mate,
First off nice image nevertheless.
To your issues:
Those secondary smaller uneven flares are from mirror imperfections towards the edge. A simple solution is a 1-2 cm Ring that covers the edge of the primary mirror hiding the mirror clamps. You will loose minimal aperture but your image will improve.
Parallel double spikes would be from non perfect focus, or if they diverge from each other the spikes themselves are not 100% parallel.
In general you still seem to have significant coma (unround Stars) towards the edge which amplifies any imperfections. Play with the distance between sensor and corrector. In general the Baader isn't too great. Look into the GPU 4lense aplanar or the skywatcher rebrand thereof
Hope that helps!
Julian Mochayedi:
 Yep, but in its defense it is more effective on the F5.  Agree with the 4 lens CC, but with everything at F4 it is fussy about spacing!
astropical avatar
Hello!
If the problem persists after checking the optical train and collimation I also vouch for an aperture ring over the primary mirror clips.
The loss in aperture is negligible. I noticed much improved star spikes after attaching a ring on my PDS150 Newton.
Also, the focuser protrusing into the tube is a potential problem. Mine is silver ex-factory, so I painted it black 😎
In my desperation, I also put a black cloth over the back of the Newton to rule out stray light entering from the rear.
Robert
Astroneck avatar
Hello. Thanks to all for your answers.
I modified two things on my telescope and I found the solution.
The focuser not was the principal problem, but It obstructed the primary mirror when the camera was in focus.
The solution for me was to romove a 35mm focuser extender. After I adjusted the screws of the primary mirror to put it some millimeters inside the tube…
I can focus the camera without the extender. Maybe change the focuser is better solution, but for the moment, this can solve the problem.
The principal problem was the collimation. Now, after five or six years that I took my first astrophotography with a dslr and a newtonian, I know what is
the offset of the secondary mirror in this telescopes… (something essential for  take good images, you will agree with me)
I my case with a 200mm f4 newtonian, I found in an internet forum that the offset is 4,5 mm.
¿Is a good distance for my telescope?
Last night I recollimate the TS Photon 200F4. To offset the secundary mirror I used a ruler above it, and to get the telescope collimated I used a laser collimator. I remove the focuser extender too…
Then I started to imaging… And in all my lights finally the stars looks better, are round stars whithout this rare spikes smile
In adittion, now I have a aperture ring, but I have not install it yet. I expect this improve my images too.
Yes, and my camera backfocus are not correct, I can see. I bougth a M48 rings kit to fix this problem.
I have read that the good backfocus for the mpccIII is 55mm, but without the T2 ring is 57,5mm. ¿Is it correct?
¿Someone knows whats the correct backfocus for my configuration?
Between the camera and the mpccIII I have an Altair filter changer… for RGB filters. I use the optolong Lpro on the mpcc for all the lights, Lpro afects to the RGB lights. ¿Is this a good idea?
And Another question I have is if the filters affect the backfocus ¿?
Too many questions may be asked. but if anyone can help me, thank you very much!!!
Joaquín.
Clearskies!!!
If you remove the T-ring the backfoucs needs recover these extra 3mm of distance to achieve the optimum distance. Yet again, with a tolerance of +/- 1 mm so don't get stuck on being too precise in that. If it is 2mm or 4 you still are within the working distance. See the instructions here:
https://www.baader-planetarium.com/en/downloads/dl/file/id/483/product/3004/mpcc_mark_iii_instruction_manual.pdf
The offset number you are using feels like being in the right ballpark, off the top of my head. Using a L-PRO (I do) for all the Luminance lights is fine as well as having it on when taking the RGB lights, if you are concerned about light pollution. If have access to pristine dark skies having it on won't help much or at all (except with a very bright moon). Introducing glass in the optical path is going to modify the back-focus distance as the extra thickness will shift the focal point outward. This depends on the optical thickness of the filter and its distance from the original focal point when inserted. Nothing to really to worry about as it won't change the back focus requirements for the MPC.
Reza Hakimi avatar
Hey my friend had your exact setup and had the same problem
after a long search and trail and error, we realized that the coating on the edge of primary is not so good. you can either use an aperture ring or just simply cover the edge of your primary for 5 mm or so with a non reflective duct tape
FiZzZ avatar
unfortunately I had bad correction with TSGPU and the TS ONTC f4 6" at 1 mm difference ...
despite calculating several times the distance with adapters (it felt I was not able to sum numbers...) to exactly 55mm from the sensor, I had coma...
At the end (useful also for @Astroneck) the filters were extending the optical path by 1mm (by a general thumb rule of half of the filter thickness).
Newtonian f4 are over sensible to everything by my short experience... sometimes I really think I should have stick to the f5 ... nowadays CMOS sensors can very easily recover the difference among a fast f4 and a "less fast" f5...
The f5 can hold winter temperature changes of 6-7 degrees before to need a refocus, the f4 barely 3...
I am pretty specific that this refers to Baader's MPCII/III (I have the former). In my tests that was the tolerance (+/- 1 mm). The filter only increase the focus position moving it outward. If the position of the filter is, as it should if it is a permanent installation, ahead of the corrector then nothing happens. If you have filter wheel or a filter holder in between corrector and sensor then obviously the filter optical thickness needs to be accounted for.  If we assume that the typical refractive index of the substrate is around 1.6 then given that thin lens formula for the focus displacement being:
displacement = filter thickness * (n -1)/n, with n the refractive index (centred on whatever wavelength it is you require, say green)
 which gives .375 mm per mm of filter thickness. For a 2mm thick filter (2") this yields .75mm optical thickness which falls within the tolerance.
Dave B avatar
Your issues are common
1/ draw tube protruding into ota trim to suit but not too much .
2/ primary clips cause the uneven flaring  , fixed using an aperture ring easily resolved by ordering a washer  sized to suit in 1mm aluminium and painted Matt black and I blutacked  mine to clips order from a cnc shop I used laser master, here in the uk
3.baader cc make sure you utilise the m48 thread and have a back focus of 57mm not 55mm that is m42 thread only , space to suit .
4, collimation ,double  check without cc in imaging train so not to get confused incase cc causing issues .
im currently tweaking my sw 200pds just waiting clear skies to verify .
regards Dave
Imaging near bright stars
I've taken a couple of images of the Horsehead Nebula, and I get a bright blue spike intruding on the image from nearby Alnitak (see this image for example: The Horsehead Nebula - B33). I see plenty of other similarly framed images that don'...
Newtonian spikes differ from bright star diffraction spikes; may explain Alnitak artifact.
Nov 25, 2019
Large RA spikes and Oscillations with CEM70
Unfortunately the perfomance of my mount has taken a dark turn. I started getting massive spikes in the RA of several arc/secs and then PHD corrections result in oscillations. Here you can see a typical PHD session. At the moment I am using PEC with ...
Mount tracking issues can cause star spikes similar to those described in post.
Feb 19, 2023
